Question about Car Audio & Video
Interior carpet where can i obtain - Car Audio & Video
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 155 Answers
Look at some low rider magezine you can almost get any thing from it
Posted on May 12, 2010
Need to know where fuse link on 1999 ford pickup location
there are many...first set of break outs is right after battery positive
Sep 29, 2013 | 1999 Ford Ranger Pickup Truck Carpet 2 or...
Has a water leak somewhere,causing the interior carpet to get wet & even have standing water, seemingly after every rain
If its cold during your rainy weather and you need heat to warm the interior of your car. You might want to have your cooling system pressure checked. The heater core might have developed some corrosion which will eventually lead to leaks. If you have radiator coolant in your cooling system, touch the wet carpet then rub your fingers together. There should be a film left on your fingers. Hope this helps.
Apr 05, 2013 | 2004 Dodge Intrepid
I want to know how to change the interior carpet in a monte carlo ss. I've already purchased the interior carpet
Just remove the front seat, mid console box, and door plastic trims. If everything is taken off, you are ready to put the new carpet.
Hope that helps you out.
Aug 06, 2011 | Chevrolet Monte Carlo Cars & Trucks
Sound proof the interior of my car
how bad do you want this?if you remove the seats,rocker panel kick plates,carpet,door & quarter panel covers you could install padding from a supplier like jc whitney under the carpet and where space allows,adhere to door & fender panels from the inside.pad the back seat from inside the trunk.how about installing a loud stereo?!
Sep 21, 2009 | 1989 Honda CRX
2002 Olds Aurora.All interior lights are out. Found blown fuse.
Your Interior lights share a fuse with alot of other circuits and if I remember correctly the switches are built into the door latches.On some of the models the cigerette lighter is on the same circuit and if your element is bad it can short out,also you could check wiring between doors and body to see if any rubbed thru.
Aug 23, 2009 | 2002 Oldsmobile Aurora
For 2002 Monte Carlo LS need to replace carpet
try contacting the dealer.I did this about 10 years ago with an 85 nissian 300zx and they sent me new carpet and it fit perfect. Also try contacting auto part stores. You private small auto parts store usually know more. Also check into restoring car websites2.gif. Carpet stores really cant help.
Jul 04, 2009 | 2002 Chevrolet Monte Carlo
Leifheit Rotaro Manual Carpet Sweeper
Do you know where brush cleaner attaches to the leifheit carpet sweeper. or do you have a pamphlet with instructions for carpet cleaner
Nov 20, 2008 | Leifheit Rotaro S Canister Vacuum
Interior Carpet Getting Wet
It sounds like a plugged drain line from the air conditioner. Most cars now run in the a/c mode whenever u turn on the climate control (even when heat is on). The passenger side front is where it would be wet, and the carpet and carpet pad act like a sponge and will soak up the water. Let me know how u make out.
Oct 25, 2008 | 2003 Honda Accord
Gas spill odor in auto carpet
some cars have the fuel lines in the interior under the carpet
Sep 19, 2008 | Toyota Highlander Cars & Trucks
Car Audio & Video Logo
13 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
