Question about Rancilio Silvia Espresso Machine
Old machine need manual
I need a manual for an old Rancilio expresso machine model    z11/omicron 2          can anyone help?
SOURCE: rancilio silvia
Hey Folks. My Silvia was doing something similar to this after no less than 2 weeks of operation.
Not being too worried about the warranty for just opening the case and looking inside......I did so. Be careful. Unplug as you remove various panels. Just don't touch anything with wires. You can see your problem if it is the same that I had.
Remove water res. Remove SS top. To view the pump, I had to remove the SS shield separating the reservoir from the boiler area. You will find the pump attached to the bottom of the chassis. It is supported by a rather flimsy rubber mount. Mine was collapsed to one side.......and the pump was literally banging against the chassis. Yes.....that will rattle your cups sitting atop the machine. To prove that your pump is not held securely in its mount, actuate the ON switch and observe the pump. Use only short burst of power when viewing your pump as you are NOT pushing water thru the assembly....and of course, all those electrical shock hazards that exist.
If it is shaking side to side......that is your problem.
I took a piece of hot water pipe insulation that I had out in the garage and cut it to the length from pump fitting to exterior wall of cabinet. IU think that might have been about 4.25 inches (I fixed this problem over two months ago and can't remember the actual length). The insulation piece is very light and holds the pump quite securely in place precluding the side to side vibration and the terrible noise. The split in the insulation allowed for the water line to be held securely as it comes out of the pump.
Reinstall all shielding parts, etc.......and you should be back on your way to minimal pump noise espresso shot pulling!!
All the best........Arch in Virginia Beach
Posted on Apr 13, 2008
SOURCE: Krups model 865 Coffe and Expresso maker manual
http://www.smallappliance.com/images/SmallAppliance/English/products/standard/865.pdf
Posted on Jul 19, 2008
  • 10865 Answers
SOURCE: I have misplaced my Manual for the Rancilio Miss
http://www.1st-line.com/machines/home_mod/rancilio/silvia.htm
go to this link and you will have more info than u can imagine. good luck earl.
Posted on Mar 20, 2009
EsWorld
  • 1618 Answers
SOURCE: I have a Rancilio Techna DE two head expresso
Easiest way is to remove the screw and screen, then using an Awl or ice pick, at a 45° angle, force it into the gasket and lift, leverage will do the rest, and it will most likely come out in chunks. After it is removed clean area to make sure there is no small pieces then insert new gasket.
Posted on Jul 10, 2009
EsWorld
  • 1618 Answers
SOURCE: I have a 14 month old Sirena expresso machine. It
Check the thermostat or element on the top of the machine.
Posted on Mar 16, 2010
Why won't my portafilter stay engaged once the water starts dripping? It flies off and sprays coffee grounds, and this started last week. Stays in place only if I wrestle with the filter handle.
It is possible that the grind you are using is too fine and causing so much back pressure that the portafilter is moving, also possible that the group gasket installed need to be replaced, I have also seen this happen with damaged screens.
Jul 27, 2015 | Rancilio SILVIA EXPRESSO MACHINE Silvia...
Pump won't turn off on my Rancilio Silvia. I left machine on for about 1 1/2 hours, then brewed the expresso and when I tried to turn off the pump switch, it didn't go off. Now every time I turn on the...
The pump switch is either burned out, shorted out, or there is a CPU problem. You will need somebody local to do basic electrical troubleshooting on this machine.
Jan 23, 2011 | Rancilio Silvia Espresso Machine
Why has my rancilio silvia v3 steamer stopped
Remove the top panel and check the 3 thermostats there, one of them tripped.
Jul 16, 2010 | Rancilio Silvia Espresso Machine
Rancillio Expresso Machine won't pump water through. Makes lound noise.
Hi There are a couple of things. 1. Your pump is not primed. Open the steam knob and push the middle switch. 2. Your intake hose is pinched or not connected to the pump, or your intake hose is not in the water tank.
Feb 21, 2010 | Rancilio Silvia Espresso Machine
I have a Rancilio Techna DE two head expresso machine. I need to change the gasket for the head. Water is leaking around the head. How do I change the gasket?
Jul 08, 2009 | Rancilio Silvia Espresso Machine
Is Rancilio Silvia best for $400?
yes, you can get better quality from Rancilio silvia, if you try to get the maximum from it. i believe that in short tame you will be able to do it.
in the video she uses the machine but im not content about one detail, i give solution there.
video :
http://www.fixya.com/support/t422860-making_cappuccino_rancilio_silvia
May 26, 2008 | Briel ED271AP 10-Cup Multi-Pro Espresso /...
I NEED A MANUAL FOR A 865 KRUPS COFFEE AND EXPRESSO MACHINE, I DID NOT GET ONE
Jan 27, 2008 | Krups Coffee Makers & Espresso Machines
Rancilio Silvia Espresso Machine Logo
100 people viewed this question
Top Rancilio Coffee Makers & Espresso Machines Experts
vilhj
Level 1 Expert
Are you a Rancilio Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
