Question about Whirlpool 5' Jacuzzi Tub Bathtub Cetra 532 H525-969
Pump will not turn off. Have removed tub face. The air tube is connected. I did test the tube and there is no leak. The pressure switch at the tub surface is working. What next?
  • Whirlpool Master
  • 12,061 Answers
If the Pump will NOT turn OFF, then the switch, must have failed, in the ON position, I suspect you will need to replace it.
Posted on Apr 28, 2010
My washing machine does not take water in, I fixed a broken wire and I changed the water inlet pump it's still not working, the motor jumps twice and stop.
check ur water pressure switch and ur water inlet valve always test it before buying new water pump?
The water pressure level switch is a pressure activated switch that is used to determine the correct water level in the tub. This part is normally located behind the control panel and will have a hose or air dome tube that connects it to the tub. On washers that use an electronic control, this switch may be located at the sump area below the tub. As the water fills in the tub it will compress the air in the tube and push against a diaphragm inside the switch. The switch will control the water inlet valve and turn the valve off at the correct water level. If the tube has a leak, not enough pressure may be created to activate the switch and the washer may overfill. If the switch is defective it may also cause the machine to overfill. To determine if the switch is bad, you should first eliminate the air dome hose as a problem. Look for signs of cracks or worn areas on the hose. Remove the hose and submerge in water. Seal one end and blow air into the other end and look for bubbles. Check for an obstruction in the hose as well. If the air dome hose appears to be ok, then the water level switch may be defective.
You can test it with a meter and with a manual test? ( first locate it in the panel, it has a plastic clear tube hose going into it, remove that tube from its connection, now put another small tube or hose into the slot where it was and have the machine set to wash cycle with water in it. Blow into the other end of the tube.
If the machine starts to wash. the pressure switch is more than likely good
( No wash- then THE DIAPHRAGM IS BAD AND SWITCH HAS TO BE REPLACED).
The other item to check would be your water inlet valve. Check it for continuity with a multi meter it should show Ohms or a closed circuit. To test it when water is overflowing unplug the unit and see if it still overflows or continues to fill. If it stops when unplugged. Then it is not a water inlet problem but an electrical signal problem going to ur water inlet valve. Possibly from the panel or board.
By the way my advice is free cuz God is good!
May 15, 2015 | Washing Machines
Machine filled with water then stopped working
Apr 07, 2015 | Washing Machines
Low water level on wash cycle just in to bottom of drum this cannot be right
Mar 28, 2015 | Washing Machines
Will not fill with water on wash cycle but if i put i on rinse and spin cycle it works like it should
Mar 26, 2015 | Washing Machines
The pump running all the time, water come out every where
Washer fills with water and overflows:
Washer will not drain:
Thedrain water pumpis the main part in your washing machine that pumps out the water. If this is defective or has failed in any way, this will be the reason why your washer will not drain the water. Before you order a new drain pump, make sure tocheck the pump to be sure a small object like clothing or similar has not lodged itself insideof it causing the NO DRAIN issue. If the drain pump is not clogged, you can test it with a multimeter and remove and replace if needed. Go to Google or YouTube and search for "Replace Washing Machine Drain Pump" then type your brand and model number of washer to show you details on replacement.
Mar 20, 2015 | Washing Machines
My machine 4E doesn't want wash and doesn't fill water
Feb 24, 2015 | Kenmore Samsung Washer Code 4E Water Pump...
My executive washing machine does start after filling with ater
Oct 13, 2014 | Whirlpool Washing Machines
Wash blinks H F
FH_ This will occur when No water is detected entering the machine or The pressure switch trip not detected.
If after 30 seconds the control does not detect water entering machine, the valves will be turned off and the error code will be displayed.
OR
If the control has turned the water valves on, and after 8 minutes, the flow sensor has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off, and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
Possible Causes / Procedure
• If there is no water in the unit:
- Make sure that both valves at the water source(s) are turned on all the way.
- Check for plugged or kinked inlet hoses or plugged screens in the inlet valves.
- Verify inlet valve operation.
• If there is water in the unit:
- Verify drain pump operation.
- Verify that the pressure switch hose is in good condition and properly connected to tub
and pressure switch.
1. Verify there is not a siphon problem.
2. Unplug washer or disconnect power.
3. Verify wire harness connections to inlet valves, pressure switch, drain pump, flow meter,
and Central Control Unit (CCU).
4. Check all hoses for possible leaks.
5. Plug in washer or reconnect power.
6. Verify pressure switch operation.
7. Verify flow meter operation by blowing air through the part and measuring the resistance.
8. Verify CCU operation by running a Diagnostic test or any cycle.
Replace failed component.(Which will be the CCU, if the pressure switch and hose are operational. Follow the procedure below to confirm optimal pressure switch function)
HI, the water level switch(aka pressure switch), is responsible for regulating the water fill level in this situation. It does this through a plastic tube which runs from the switch in the control console down to the side of the outer tub, near the bottom . The tube is filled with air. As water enters the tub it also enters the tube. As water climbs inside the tube, it pushes on the air trapped inside and increases the air pressure. When the air pressure reaches a certain level, it triggers the switch.
I would advise to Inspect the air tube for kinks, breaks or damage. The tube should also be free of water. The tubing should be securely connected to the bottom of the outer tub and to the bottom of the water level switch. If there is water present, the switch must be replaced.
The water level switch has three connectors. Label and disconnect the wires from the switch. Test the switch for continuity using a multimeter. Set the multimeter to the ohms setting X1. It will be necessary to test each of the three possible pairs. replace the switch if it fails the continuity test.
Dec 09, 2009 | Whirlpool Washing Machines
Get an fh error after the washing cycle but once paused and restr. cycle it completes teh cycle what could be the cause
OR
Replace failed component.(Which will be the CCU, if the pressure switch and hose are operational. Follow the procedure below to confirm optimal pressure switch functions)
The water level switch(aka pressure switch), is responsible for regulating the water fill level in this situation. It does this through a plastic tube which runs from the switch in the control console down to the side of the outer tub, near the bottom . The tube is filled with air. As water enters the tub it also enters the tube. As water climbs inside the tube, it pushes on the air trapped inside and increases the air pressure. When the air pressure reaches a certain level, it triggers the switch.
Nov 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
What does it mean when it flashes FH on my washer
OR
Nov 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool 5' Jacuzzi  Tub Bathtub Cetra 532 H525-969 Logo
244 people viewed this question
Top Whirlpool Home Experts
Craig Butler
Craig Butler
john h
Mike
Are you a Whirlpool Home Expert? Answer questions, earn points and help others
