Question about Philips HDD082 MP3 Player
Mp3 philips hdd082/17 not charging and not connected when connected to usb
I try to recover my philips mp3 but since i try every thing my main problem i cannot connected to pc ..i try for first time it show philips screen only ..i alreday done the reset but still the same....after itry to hold the vol button the pm3 screen show socket and plug only the batteries not charging
  • 8,596 Answers
WARNING: this process will erase all songs off the GoGear.
Disconnect the GoGear from computer.
Turn the GoGear off.
Hold in the volume + button.
Reconnect the GoGear while holding in the volume + button.
Continue holding the volume + button.
After 5-50 seconds, Windows will pop-up a "Found New Hardware Wizard." - complete the wizard (BTW, you can take your hand ff the volume + button now).
Good To Go (Gear)!
-Tha Mp3 Doctor
Posted on Apr 08, 2008
HOW IS THE BATTERY CHARGED
MP3 players are usually charged by the supplied USB cable when it is connected to a computer's USB port.
You can purchase an USB mains adapter and you can then connect the MP3 player with the USB cable into this USB mains adapter.
May 20, 2011 | Philips GOGEAR SA6045 MP3 Player
I was charging my media player and now it is stuck in charge mode?
Hi,Reset your GoGear with something sharp like the tip of a pen or the end of a paper clip, if you're device isn't working properly or there's a frozen display. Insert the sharp object into the "Reset" hole (located at the bottom of the player), and hold it there until the device turns off. If resetting the device does nothing to restore the display, access the "Philips Device Manager" through your computer to recover the GoGear.
Click "Start" on your computer, then "Programs," "Philips Digital Audio Player," "Aria Device Manager," and then "Philips Device Manager." This will launch the "Philips Device Manager." Make sure the GoGear is turned off completely. Connect your GoGear to your computer while holding down the "Volume Up" button. Continue to hold the "Volume Up" button on your GoGear, until the "Philips Device Manager" recognizes the device and enters recovery mode. Click the "Repair" button when it appears on your computer, then follow the steps to fully recover the GoGear. Properly disconnect your GoGear from your computer and restart the device.
Recharge your device if your GoGear dies suddenly while playing. Connect the GoGear to your computer via the supplied USB cord. Plug one end of the USB cord into a functional, open USB port on your computer. Plug the free, smaller end of the USB cord firmly into the small USB jack on your GoGear and turn your computer on. This will begin the charging process of your GoGear. If recharging doesn't work, the battery may need to be replaced. Check that your GoGear isn't in standby mode. Hold the "Power" button for two seconds to turn it back on.
Good luck.
Mar 11, 2011 | Philips GoGear ViBE Digital Media Player
How do i charge it
Refer to page 12 of your User Manual.
http://download.p4c.philips.com/files/s/sa3346_37/sa3346_37_dfu_aen.pdf
Connect to your PC with the supplied USB cable and it will charge via the PC USB port.
Dec 29, 2010 | Philips GoGear Flash MP3 Player
Can i charge my mp3 player philips gogear with a wall charger
You can charge your player with a 5 volt USB mains charger or use a powered USB hub.
Dec 29, 2010 | Philips GoGear Ariaz MP3 Player
How dont know how to charge my mp3 player
Some things to check for when your player does not act like its taking a charge. USB Cable Make sure that the USB cable is properly plugged in and use the original cable that came with your player. Computer in Hibernation mode Make sure the computer isn't entering hibernation or sleep mode while the device is connected. The computer must be ON in order to charge your player. USB Port 2.0 Make sure the player is connected to a USB 2.0 port (1.1 occasionally causes charging problems). USB Port location Try plugging into different USB ports (i.e. USB port in the back of the computer); occasionally the front USB ports have limited power to charge up the device. Battery Make sure the battery is fully charged. It takes approximately 3 hours to fully charge the battery. Latest firmware Depending on what player you have, make sure it's up to date with the latest firmware. AC charger (optional) AC chargers (sold separately) have a 500-1000 milliamp max output, which provides much better charging ability than a USB port.
Dec 25, 2010 | Philips GoGear Flash MP3 Player
I have 2 philips gogear mp3 players do I need to have to different software(s) installed? it's not charging. it's the 2gb one.
if they are the same model you anly need to install the driver once for both ...and the charging problem might be from the usb slot and not from the mp3 player ...cause there is no way that both to have the same issue ..
so change the slot and try again ...pay attention if on connecting you do not need to confirm from the mp3 itself the tip of connectivity ...charging or ..pc communication ..
another thing that might be is that it is not charging when it is on storage connectivity ..and in this case click on the remove safe icon ...in the tray system (lower right on task bar ) ..and choose remove and select the device ..but leave it plugged..it will stop the memory communication and it is a chance that wills tart being in charging mode..But usually this kinda devices that charge via USB slot..start charging from the moment you connect them into a good slot ..no matter if the driver is present or not..
Aug 24, 2010 | Philips GoGear SA178 MP3 Player
I have the philips go gear hdd1830 and it wont turn on. I tried to connect it to my computer and it does not show that it is connected to the computer and no charge as well.
Hi it sounds like the onboard battery is flat, so will not swich on. You have also stated the player is not recognized by the PC and not charging.
Try another USB lead and also try another USB port, either of these could be at fault.
Apr 17, 2010 | Philips GoGear HDD1830 MP3 Player
Mp3 wont charge
There is a lock on the side - unlock it and try charging again.
Recovery Mode for Philips' GoGear
Open the Philips Device Manager (Start à All Programs à Philips Digital Audio Player à SAXXX à Philips Device Manager) and click on the “Repair” tab. Then click on the “Repair” button to start the repair process. Most of the time, when your player is in that state, the Device Manager will not recognize that your GoGear is plugged in. If this is the case: Disconnect the player from the PC, and make sure the mp3 player is turned off. Hold in the volume + button on the mp3 player, and reconnect the player to your pc while holding in the volume + button. Continue holding the volume + for 10-15 seconds until a "Found New Hardware Wizard" pops up. It should recover your device if there isn't anything internally wrong with the player. Warning: this procedure will result in your songs being erased off the player, so they will have to be reloaded.
-Tha Mp3 Doctor
Philips GoGear Firmware Upgrade
You need to get the latest firmware upgrade from the Philips website:
1. Go to www.philips.com/support
2. Enter your country/language
3. Enter your model # SA6045 or whatever
4. Click on the link for your exact model # (the one w/o the "B" in it)
5. Click on "Software & Drivers"
6. Download the updated "Device/Firmware Manager"
7. Once installed, open the Philips Device Manager
8. Click on the "Update" tab, then the "Update" button (with your mp3 player connected to the computer, of course)
9. Your Mp3 players firmware will update automatically
If you do not have the latest version of the Philips Device Manager installed (the latest is the version from the Philips website), then clicking the "Update" button will give you a false positive saying "The firmware on your device is already up to date."
-Tha Mp3 Doctor
Sep 27, 2008 | Philips SA5145 MP3 Player
Player cannot get connected to computer-Philips GoGear SA3115
Install and run the Philips Device Manager software from the product CD.
Select the Repair / Restore option and follow the on-screen prompts.
This will format the player and repair the firmware.
Mar 24, 2008 | Philips SA3125\02 MP3 Player
My philips mp3 help
same thing happened to me and i charged and it said to connect it to ur computer and it might work
Jul 09, 2007 | Philips HDD1630 MP3 Player
Philips HDD082 MP3 Player Logo
82 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
