Question about Briggs & Stratton Lawn-Boy Insight Series 21-Inch 190cc 650 Series Gas Powered Engine Variable Speed Self-Propelled Lawn Mower
Tool for oil change/plug
Do I need a special tool for the drain plug. It seems square shape
  • 61 Answers
no special tool needed.Just use a 3/8 ratchet extension. Fits perfect
Posted on Apr 29, 2010
Is there a special drain plug wrench for removing the oil drain plug
if it has a normal nut shape then use an extended socket
If it has a hex then use a allen key
Apr 15, 2015 | 2000 Honda VT 1100 C2 Shadow Sabre
Oil drain plug on astra wagon 2005 ah
if it is a square hole .no you dont use a socket wrench to brake it free . remember righty tighty lefty loosy...
Aug 12, 2012 | Holden Astra Cars & Trucks
How do you drain the oil and gas out of this mower mtd 22' 4hp and how do you change the spark plug? do you need any special tools/thank you soooo much natalie
Drain plug for the oil should be under the deck next to the blade shaft. Usually a plug with a square head on the bottom of the motor. Loosen the fill plug and then remove the drain plug. Any time you go under there make sure you disconnect the spark plug wire so no spark can jump.
Gas is another thing. No fuel line as carb is part of the tank, so only way to empty is to .....
1) tilt the mower over and pour out the gas. Good time to change the oil and do it before you add the new oil.
2) unbolt the tank from the motor and remove tank carb and all a single unit. Then turn it over and dump the fuel. there are only 2 bolts holding it on so after you remover the air filter you can see them easily. Just remember how the throttle linkage hooks on.
May 21, 2010 | Mtd 22" Yard Machine Push Mower
I need to change the oil
no special tools needed, remove lower plastic ,undo drain plug ( probably 14mm wrench),drain oil into a non food container, undo filter with a filter wrench or by hand, refit new filter, refit drain plug, add 10w40 oil of your choice ( not car oil !!) probably approx 4 ltrs , check level is halfway on site glass on crankcase.if all is tight start bike check for leaks refit plastic.. brake fluid is probably DOT 4,
Oct 10, 2009 | 2004 kawasaki ZX-6RR
Location of oil filter on 2007 toyota avalon
the 2007 avalon has a cannister oil filter loof under the passenger front of the car youl see the oil pan and drain plug its just in front of the oil pan towards the front of the car its metal casing with a small square in the center thats where youl need a 3/8 exstension and ratchet to loosin the cap to change the gasket for the cap when you get your oil filter it comes with a small plastic piece so you can drain the oil out of the oil filter case, to change the oil filter itself you need a toyota specific oil filter tool to loosin(can get at any toyota dealer run about 20 bucks) take the filter out change the gasket around the case and thats it hope this helps
May 03, 2009 | 2007 Toyota Avalon
NEWBIE: How difficult is it to change the oil and oil filter?
ok, this should be pretty basic but if you have any doubts buy a repair manual for your car from auto zone or checker or wherever you shop.
first off buy the new filter and the oil, that filter should look very similar to the one that is on your car, although keep in mind that the color and sometimes even shape can be a little different, but you have a basic idea of what to look for.
the oil filter will be on the motor itself, as well as the drain plug, usually both are easier to access from underneath the car.  remove the oil filter counter-clockwise, some oil will leak out at this point and may be hot, so be careful, this may require a tool depending on how tight it is, the tool is usually relatively cheap.  NEVER use an oil filter tool to tighten your filter, it is only for removal and may damage the filter adapter, when you put the new filter on tighten it as much as you can with just your hands, this should be plenty tight. you will also need a drain pan, preferrably sealable so you can take it with you when it is full to be dumped (usually checker/auto zone will have an oil dump).
next loosen and take out the drain plug, this will be on the bottom of the oil pan, which is the bottom part of the motor itself.  when the oil stops (or reduces to a very fine flow being almost all gone), put the drain plug back in and tighten it down.  add 3 or 4  quarts of oil, start the car and let it run for 15 to 20 seconds, this will fill up the oil filter, then check the oil and add as needed.
hope this helps.
Apr 24, 2009 | 2003 Volvo S40
Need specific location of oil drain plug to change oil
I have owned a 1999 intrepid for 9 years. And have changed the oil many times in the 170,000 miles I've owned it. This car comes mostly with a 2.7 liter motor. It does some times have a 3.5 liter. As you open the hood,there is a sticker that tells you what motor it has. If you have the 2.7, between the two front wheels you have a cast aluminum oil "pan" You will see a oil filter sitting vertical, towards the passenger side.The bottom of the filter is almost flush with the bottom of the oil pan. Just to the side of the filter,towards the driver side, is a hex head oil plug. It will take a 11/16" wrench to remove it.Hope this helps lbreen
Apr 22, 2009 | 1999 Dodge Intrepid
08 toyota sienna van and oil filter change
a local auto parts store will have every thing you need including manuals
Dec 30, 2008 | 2008 Toyota Sienna
Jaguar xjr 2004
the motor is "sealed" by the factory... you need a special tool.... it does beg the question. it sounds like you are trying to remove the whole oil pan. why ??
There should be a drain plug that you can unscrew to change the oil.
Robert
Sep 02, 2008 | 2004 Jaguar XJR-Series
Briggs & Stratton Lawn-Boy Insight Series 21-Inch 190cc  650 Series Gas Powered Engine Variable Speed Self-Propelled Lawn Mower Logo
183 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
