Question about Frigidaire Affinity ATF7000E Front Load Washer
Error 68 what this means
  • 1,998 Answers
Card would not eject properly
error 68 mean the card is jam in the print station or in the flipper area.
you either clean the card part and flipper very well.or you may need to change it.
thanks
Mar 14, 2014 | Fargo HDP5000 Thermal Printer
Job Error Code:68 (VinPower DIgital Unit)
Error Code 68
System error code 68 means "The name limit for the local computer network adapter card was exceeded." This error code may also display as "ERROR_TOO_MANY_NAMES" or as the value 0x44.
I don't know what this has to do with using lightscribe and burning the CD's but perhaps your running this over a network?
Good information here and his solution near the end of the article:
Fix Windows error The name limit for the local computer network adapter...
Hope this helps good luck!
Mar 11, 2014 | Vinpower Digital SharkCopier 1 to 12...
I put the face back on my radio this morning,it displayed hp error 68 disconect
Error 68 means it is trying to connect to a bluetooth enabled cell phone. You should turn off the blue tooth pairing options under the radio options. Go through the menu and you should find it.
I hope this helps
Mar 21, 2011 | Kenwood KDC-MP228 CD Player
We have an error 68
Error 68 usually means that there is a hard drive failure.
  1. Try taking off the hard drive and starting the xbox.
  2. If the gray screen still comes up then it's a hardware failure in the xbox.
  3. You have 2 options, send it into microsoft or buy a new hard drive.
Feb 19, 2011 | Microsoft Xbox 360 Console
When i turn on the kenwood radiocar, hf error 68 appears. What does it mean? What should i do?
Error 68 means it is trying to connect to a bluetooth enabled cell phone. You Need to turn off the blue tooth pairing options in your radio options. Just go through the menu and you will find it.
Sep 21, 2010 | Car Audio & Video
What does status code-68-cood36be mean . i have downloaded a video from my computer straight to my xbox but wont play because it said it unsupported please advise
This means that the file format you are trying to play is not supported or cannot be played by your console due to format restrictions. It means that the video has an invalid format not recognized by the console that is why it is not playing thus showing this error code.
May 10, 2010 | Microsoft Xbox Console
It reads error when i put my hard drive in
I'm guessing that the error your getting is E 68. E 68 means that there is a hardware malfunction somewhere inside the xbox 360 and if you only get this error while the hard drive is in then that means your hard drive is busted... Sorry but your going to have to buy a new hard drive or see if you can get it fixed. (But I highly doubt you can at a reasonable price.)
Jan 27, 2010 | Microsoft Xbox 360 Console
Error e 68 pops up and dryer turns off. Doe sthis
Hi
Thanks for using FixYa. E 68 error means that there is a leakage of current to the ground on heater or fuse opened. Also check the resistance of the NTC which should be around 50K ohms. If not then you need to replace the water inlet valve assembly.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jul 30, 2009 | Frigidaire Dryers
System error 1 light code E 68
error 68 means that the xbox has insufficient power to operate. make sure it is directly plugged into the wall. try removing accessories on your xbox like intercoolers and USB devices.
Aug 24, 2008 | Microsoft Xbox 360 Console
ERROR CODE 68 ON AFFINITY ATF7000EE
check tech sheet located inside washer cabinet at bottom. remove lower kick panel to access.
May 04, 2008 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire Affinity ATF7000E Front Load Washer Logo
247 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
