Question about Sony SDM-HS73 17" Flat Panel LCD Monitor
My monitor screen is a bright green color
My computer was fine one day and the next as soon as I power it on turned green. I tested the monitor with the "built in testing function" and it tested that its working properly but yet the screen is still a bright green color. Please help I have tried going on the control panel and changing some settings but nothing is helping.
  • 11,361 Answers
Please check all the pins at both end of the VGA cable, also try it on another PC also since the problem can be in the video card. We need to narrow dow the problem first.
http://s807.photobucket.com/home/budm/allalbums
Posted on Apr 29, 2010
Screen won't turn on
You can try to do the monitor self test.
Monitor Self Test:
1. Physically test the monitor autonomously from the computer.2. Switch both the monitor and the computer off, and then disconnect the VGA cable le from the computer.3. Turn the monitor on, pressing the power button for about three seconds. The self-test screen will come up .4. If the image is clear, bright, and shows red, green, and blue, the monitor is working properly. Video issues may be due to the video resolution in the computer, and not the monitor.5. If the image is not apparent and intense or the colors are not accurate, then the trouble is with the monitor or some of the (OSD) settings. In this case, test your particular monitor's information for OSD.
It is always important to check the color of your power light for so you can distinguish if the monitor is defective. Getting red lights on the the power panel states that the power section of the monitor is faulty.
Dec 03, 2011 | Emerson Televison & Video
Screen goes squiggly, then black. have been able
best thing to try is a external monitor if one is available - if not then run the test....turn system off..as soon as u power back on hold down the FUNCTION key..wait till u see the test running on the screen before u let go of function !!! it will only take a couple of min to know .....when u see this test run just wait until it asks u if u see color bars..whether u can or cannot does not matter..we want to press N for no on the kb....next u will get the color bars if u can see them the mb is fine and u need to replace the lcd..if no bars were seen then u replace the LCD
May 08, 2010 | Computers & Internet
Power on - blank (black) screen
Disconnect the monitor signal cable from PC and switch on your monitor. It should show some logo with Red, Green and Blue colors with a message similar to "No signal". If so, your monitor is working fine. Sometimes if the brightness and contrast is set to zero using controls present in the monitor, it will not show up anything. check wheather somebody set your monitor brightness and contrast to zero. If so incease them. As a last try connect to different PC and check before approaching a service center. I hope this will help you out. :)
Aug 21, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
CRT Monitor Displays only a thin bright horizontal line
Vertical IC loose connection. Best is to reflux it or resolder. It is in internal circuitry inside the monitor commonly an upside single line IC.
And its a minor repair only. But I recommend it to be serviced by a qualified technician. Inside it are plenty of nasty voltages. It might caught you.
Apr 10, 2009 | Computers & Internet
Screen is on, but does not appear to be on
The monitor was broken. I returned it to the vendor for replacement. Your tech did not seem to feel it was a monitor problem and only focused on the video card - although I asked him directly regarding his confidence of it being a videio card problem versus being a monitor problem.
I will not use your service again.
Mar 21, 2009 | LG 22" FLATRON LCD Monitor
Monitor displays slowly after the computer starts.
try to turn off you screen saver just turn off power monitor to see monitor easy wake up after long time.if ok means windows screen saver have problem if still same look like is you monitor something wrong need to check
Jan 03, 2009 | Dell Dimension 2400 PC Desktop
Reddish tint on the screen
LG 700e
power suply is dad
resistanc is black not show it ohom
plz help
Dec 21, 2008 | LG Studioworks 700S 17" CRT Monitor
My flatscreen monitor has went a bright green colour, you can still see a picture (part from everything is green) I have tryed puttin another monitor connected 2 the computer and it works fine, so i no its...
you should check your monitor display cable first and second may be back pcb socket and ic is loose so it leave color combination and your screen will be green.you should repaire your monitor very soon otherwise it will be more damage.
Dec 03, 2008 | Computers & Internet
Dell P1110
Hi, The part where you see some color bars and blinking green led is what we call MONITOR SELF TEST. A diagnostic pattern consisting of four colors (red, green, blue and white) appears, and the LED flashes slowly. this happens when signal cable from the monitor is disconnected from the tower and leaving the power chord for the monitor plugged in. If the monitor works properly on a different computer. then its a problem with the computer's video card sending out signal. im 85% sure that its a problem with your video card.
Oct 02, 2007 | Dell UltraScan P1110 21" CRT Monitor
Sony SDM-HS73 17" Flat Panel LCD Monitor Logo
179 people viewed this question
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
