Question about Kodak EasyShare V550 Digital Camera
Kodak v550 digital camera
Flashes blue lights for a couple seconds, then shuts down.  Lens stuck in the outward position. Does this sound like a battery problem? Al
  • 1 more comment
  • Anonymous Dec 03, 2008
    aassasasa sadwerfdfd fdtrtrt
  • gilbertosilv Dec 07, 2008
    Get error#B03 lens stuck in outward position
  • hardhatstudi Feb 26, 2009
    I have the exact same problem. Camera will not turn on. Blue lights flash. Lens stuck in outward position. Has anyone successfully fixed this?
THANKS!! I thought my camera was gone for! This worked for me!
Christie
Posted on Sep 01, 2008
Hey akpssttt, I had the same problem with my kodak and even though I was able to turn on the camera, the lens would not come back in. So after awhile I just gave up took it to the repair shop and they still weren't able to fix it. So I left the camera for about a year now, gathering dust, but recently I decided to give another shot, and amazingly when I plug the camera into the charger, the lens went back in! And now the camera works perfectly.
So I would suggest you leaving your camera out for awhile and do not charge it until the batteries is completely drained. And then plug it back into the charger.
Hope this help.
Posted on May 25, 2008
Lens error 113,0,0,0
try these:-
  • connect it to pc and on it
  • vaccum the barrel of lens
  • changing mem. card and batt. for 2min.
  • shake it.
  • on and off in different positions
  • hit the part near lens softly with palm (trust me this made mine work)
May 26, 2010 | Kodak Easyshare M753 Digital Camera
Lens stuck open
hey, I had the same problem when I accidentally droped my camera, some parts in the mechanism are probably broken or jammed.
Most likely repairs required.
Apr 13, 2008 | Samsung Digimax S600 Digital Camera
I press the on button, the lens doesnt extend and the power shuts off
are you using the recommneded battery fro your camera KODAK Li-Ion Digital Camera Battery KLIC 7001? If yes please charged the battery for 3hrs and try to turn on the camera., if encounter same problem it means the gear lens of your V550 is already defective and needs of repair please call precision and binocular repair at 1 800 665 6515.,
Oct 31, 2009 | Kodak EasyShare V550 Digital Camera
Kodak V1253 lense won't close
Use the vacuum cleaner to suckout the dust/sand particles stuck between the lens casing and the body.
Aug 11, 2009 | Kodak EasyShare Z1275 Digital Camera
Kodak Z612 won't turn on
while you turn try and turn it on slow twist and pull lens outwards(gently while power on /off) and it will retract back in and power on.Work perfectly after.
Enzomatrixx Da Gr8 One
Apr 23, 2009 | Kodak EasyShare Z612 Digital Camera
Won't turn on light flashes green then flashes red then nothing else
This usually means weak batteries, the other possibility is the lens mechanism is faulty or stuck. These cameras will shut down if the lens cannot extend or retract. Sometimes you can coax the lens out with a little help by pulling gently on the lens with your fingers if it starts to come out, don't force it. If you have dropped the camera with the lens out, this can damage the mechanism to either work intermittently or not at all.
Oct 12, 2008 | Kodak EasyShare C743 Digital Camera
Battery won't charge on Kodak Easyshare V550
I don't think its the battery. My just did this this week..If I slide the Favorites switch up (switch by hand strap mounting hole) I can view the pictures in it, but it won't use in photo mode, Lens won't extend, and it shuts off?
Jul 08, 2008 | Kodak EasyShare V550 Digital Camera
Kodak Easy Share V550
mine fell in water and now the lens retracted and won't shut and i have error #45lol
try charging your camera, if it hasn't been broken from the fall, hope it had a soft landing!
Feb 25, 2008 | Kodak EasyShare V550 Digital Camera
My EasyshareOne 6.1 mp won't turn on :(
Either gear box problem ( sand/ dirt )or lens is impacted. First problem not expensive to cure but the second requres lens unit to be replaced : probably uneconomical to repair; get a quote from camera repair outfit in your area.
Aug 28, 2007 | Kodak EasyShare One Digital Camera
Lens Problem
my camera is also doing this and i need help the lens comes out and straight back in also i lost my manual on kodak easyshare v550 amd cant get my camera to work at all i brought a new battery and it makes no difference please help.
Nov 06, 2006 | Kodak EasyShare V550 Digital Camera
Kodak EasyShare V550 Digital Camera Logo
325 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
