Question about Roper RAS8445KQ Top Load Washer
CAN'T SPIN OUT
Hello, my husband knocked the little switch off the underside of top which controlled the spin cycle, now what do i do
  • 1,998 Answers
Do you mean the little prong that sticks into the lid switch to make the lid switch funtion so that it can spin you need to order the piece that he broke off on the lid or If he is mechanically inclined have him open the top find the lid switch connection and use a jumper wire from positon 1 to positon 3 on the lid switch wire connection this makes the unit run normally whether or not the lid is open or closed if he is mechanically inclined two phillips scews in back of unit to open the head
Posted on Apr 28, 2010
Washer stops during normal wash cycle for a minute or more, and then continues. Would replacing the timer fix it?
If it actually goes on and finishes the cycle and that really bothers you replace it. If not leave it alone and allow a little more time to complete its cycle. The lid switch only keeps the spin cycle from going with the top open.
May 23, 2014 | Whirlpool Washing Machines
My Westinghouse lt908s washing machine has started bundling clothes up and knocking sides of machine. Even after opening lid and redistributing load evenly it keeps spinning then bundles up load and knocks...
May be a problem with agitator gear box,open on wash cycle and use screwdriver to by pass cut off switch by pushing screwdriver down on little switch that is located where tab on lid is.If agitator is traveling at too much of a rotation that may be cause,also agitator mat be lose if you can grab and move up and down.Then remove cap on top of agitator and tighten bolt,if lose if not agitator may need to be replaced!
Jun 12, 2011 | Westinghouse Washing Machines
Washer wont go into spin mode or discharge the water
Check the lid switch or lid striker that operates the switch. lift the top lid and insert a pen or similar into the hole on the right hand side to operate the switch when in spin mode.
If not try shorting the switch temporary, the top part of the washer needs to be hinged back to gain access, to do this insert a flat blade 4" from each side at the seam with the front panel to release the clips, lid will now hinge back to give access to the internals, Isolate the supply and locate the lid switch on the underside of the top panel and remove the 2 wires and short out/ link together. test the spin cycle now should now work and also drain the machine (Draining only works when washer is spinning) If all ok obtain and install a new switch do not leave the switch shorted.
Note this switch only affects the spin and draining parts of the cycle.
Good luck
Jan 02, 2010 | Admiral AW22 Top Load Washer
Washing machine will not spin
Could be the lid switch, to access the inside, insert a flat blade 4" from each side between the front panel and the lid to release the clips. The lid will now hinge backwards, the switch is on the underside of the lid, isolate the supply and short the switch , test the spin cycle, do not leave the switch shorted, if spin works replace the switch, if no spin could be motor or timer.
Nov 27, 2009 | Admiral AW22 Top Load Washer
Spins out of control during spin/rinse cycle?
If it has a loud grinding noise, the pump shim is slipping up. It looks like a piece of corrigated cardboard inside the pully in the center of the underside of the tub. Use a flat screwdriver to GENTLY push it back into the pully and order a new pump as this is a temporary fix. The Atlantis is known for this, and the lid switch also. Good luck.
PS Here in SW Florida I paid $50 for the pump FYI
May 08, 2009 | Maytag Atlantis MAV6000 Top Load Washer
GE Washer Knocking During Spin Cycle
remove the agitator and inspect the main shaft on the gear box.and check the belt underneath.if the shaft is bend you will need a new gearbox. hope this helps.
Feb 09, 2009 | GE Spacemaker Washer and Dryer Electric...
Will bot spin in any cycle
It's almost certainly the lid switch. When you close the lid do you hear a little click? It should be an easy fix. You could either get a new switch or just bypass it. To get to the switch and connector, you need to slide a putty knife between the top of the cabinet and the control panel to release 2 clips. The clips are about 1 inch from the left and right side of the control panel. there should be a connector under the panel with 3 pins in it. Short out the 2 that are not green and I'm sure it will spin right up. This is pretty common. Good luck
Jan 23, 2009 | Kenmore 24032\24036 Top Load Washer
Maytag top loader stopped during spin and now won't start.
ok check the lid switch,,did it knock it out of place,,unplug and take back off ,,,
Jan 05, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Washer will not spin
I'm having a little trouble understanding the question because of the spelling, but this sounds like a typical lid switch not making contact either by the depressor on the lit itself or the switch is broken. try depressing the switch with a screwdriver and see what happens. The lid switch will be in a little slot in the top inside where the lid closes.
Dec 17, 2007 | Washing Machines
Roper RAS8445KQ Top Load Washer Logo
35 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
