Question about Kenmore 774 sq. in. Cooking Area Gas Grill 15337
Just hooked up new propane tank and grill won't ignite either with starter or matches
  • Colleen May 12, 2013
    I hooked up a new propane tank to a new weber bbq and the bbq will only ignite on a very low flame. Please advise.
    Guru:
  • 1,051 Answers
Turn gas tank off and disconnect from grill. Check burners to ensure there is no blockage and reconnect tank.Open gas tank slowly, some grills have a sensor to detect leaks and automatically shut off gas. Opening the tank fast can cause this safty device to falsely read the sudden gas flow as a leak. If you still can't light the grill check all fittings for a leak using soapy water.
Posted on Apr 29, 2010
Cannot get and flame.see spark from starter new tank
Turn off propane. Disconnect propane tank from barbecue. Open burner valves for about 20 seconds. Close valves. Reattach propane tank. Slowly open propane tank valve. Turn on burner and ignite
Jul 27, 2014 | Char-Broil CharBroil 4638310 Grill
Why won't my Weber grill ignite after installing a
Disclaimer- be careful when working with gas. Starters in gas grills are just about novelty anymore. Often, they only light 1/3rd or 1/4th of the burners and they usually stop working within one grilling season. I recommend using a wand lighter. Try to light just one burner but if doesn't light in 5 to 7 seconds, turn the gas off and wait to try again. Incidentally, you are turning the gas on at the tank, right? You should hear it when you turn the burner on.
Apr 24, 2012 | Grilling
Grill isn't flowing propane when tank is on. No smell of propane and starter is clicking. Tested 3 tanks on grill and no luck. Tested same tanks on another grill and they work fine so it's the
it could be the reg or a blockage in the line or open the taps on the grill then close them reconnect gas tank open slowly then tis if there is gas to grill
Mar 16, 2012 | Barbeques Galore Turbo STS 3-Burner...
How do I get my grill going?
Hook up the propane tank and open the valve. Then turn whichever valve is the starter to start/high. Hit the igniter and it should start.
Aug 25, 2011 | Thermos Grill2Go Gas Grill 4656110
Brinkman gas grill won't start. Don't hear clicking sound. Hooked up new gas tank, but no success
Victor, are you sure you're getting gas to the burners after installing the new tank? You can try match lighting them to make sure. But, I suspect, that it's the installation of the new tank, that's causing the problem.
To test my theory, tune the tank valve OFF and disconnect the hose from the tank. Wait 5 minutes and reconnect the hose to the tank. Ope the tank valve VERY, VERY SLOWLY (Slow motion, slow). Once the valve is fully open, try lighting the burner that's farthest from the tank first and turn it to high. Did the burner light and does the flame height look correct? If so, light the remaining 3 main burners the same way. Did those burners light and the flame heights looks correct? If, so you solved the problem. Remember to always turn the tank valve ON VERY, VERY SLOWLY.
Hope this helped you solve the problem. Happy Grilling.
Jun 01, 2011 | Brinkmann 810-8410-S Stainless Steel...
My 2 year old weber E-210 gas grill does light. I replaced the igniter, but I do not hear any propane gas being sent to the .I have also tried to manullay light it with a match, and nothing. HELP!
If you have recently bought a new propane tank you may have gotten a bad one. Try taking it back to the store and asking for an exchange. The valves go bad inside the tanks sometimes.
May 29, 2011 | Weber SPIRIT E-210 (NG)
The starter button does not seem to be igniting the propane
Its not, and this is common after about a handful of uses. The igniter is covered with sooot or grease or broken. They sell universal igniters at Sears for like 3 or 4 dollars. Your only other option is to strike long length matches and use those to light it. Be careful , always stand back when lighting grills or any kind off fire. hope this helps.
Jul 20, 2010 | Weber Genesis Silver B Grill
Burners ignite, but temp of grill struggles to reach 400 degrees with valves fully open
First disconnect tank. Hook back up and open very slowly. These new valves on tanks have a shut down if you open valve to fast, causing tank valve to think it is leaking, it slows down flow of propane. Always open tank valve slow when turning on grill. If this does not solve problem then regulator is going bad and need to be replaced.
Feb 06, 2010 | Weber Summit Silver B Grill
Last summer closed up grill had no problems..today not working
unhook the tank and hook it up again being sure that the regulator is right side u p.
these new grills have a safety valve that often partially closes and causes problems.
Apr 27, 2009 | Brinkmann Charmglow 810-7400-S Propane...
Kenmore 774 sq. in. Cooking Area Gas Grill 15337 Logo
639 people viewed this question
Top Kenmore Grilling Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kenmore Grilling Expert? Answer questions, earn points and help others
