Question about HP Photosmart 3310 Printer
What could be cause of carriagae jam in all in one
  • 4,041 Answers
Hello there Try this.
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Apr 29, 2010
What causes the error code J?
The error code J in Fujitsu fi-6140 scanner is associated with Document jam or feeding related issues. J-0 error is paper jam error caused by paper protection sensor malfunction, J-1 is also paper jam caused by US sensor malfunction and J-2 multifeed error caused by poor performance or malfunction of US sensor error.
Regards,
ScanCare
Aug 13, 2014 | Fujitsu Fi-6140 High Performance Color...
CAUSE OF JUMP PAPER
It can be various reasons like
Wrong Paper Type
Labels are a common cause of printer jams.
Torn paper from passed paper jams may also cause future jams.
Cracked or Dirty Rollers
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Feb 26, 2013 | Toshiba Office Equipment & Supplies
Having message jam inside rear door and can not find any paper jam
Not all of the paper jam was actually cause by paper. There are also instances that the media is the one that is jammed, causing to display a "paper jam" message.
If you can't find any jammed paper from the unit, you can try inspect the following cause..
1. Trays are loaded improperly or overfilled.
2. Tray 2 or tray 3 is removed during print job.
3. The top cover is opened during print job.
4. The media that is being used does not meet HP specifications.
5. The media that is being used is outside of the supported size range.
Also, try to tun HP toolbox.. on the Paper Jam options, click the Typical Jam Locations... to see the internal paper path and potential jammed locations.
I hope this solve your problem...thanks..
May 28, 2010 | HP LaserJet 2420 Printer
Paper Jam light is on and there's no jam anywhere. What do you do?
A paper jam notification can be caused by two things. One a hard jam, paper stuck.
Two, If the paper does not reach a flag or sensor on time, the printer knows that a jam has occurred.
Most likely, you had a paper pick problem caused by dirty rollers or maybe the paper is held to tightly by the paper tray. Also a static charge on the paper can sometimes cause sheets of paper to stick together.
Don
Dec 09, 2009 | Dell 1720dn Laser Printer
Xerox 5334 says it has a paper jam but i don't see one
A paper jam on this machine can be several things. Not seeing the machine, it can be in the fuser area, There is one switch there that can cause a jam. if there is a acornidan jam there the paper has to be removed.
The machine can have a bad cartrige, the pr belt maybe be a cause of the jam espeically if there is a U-7 code. (A false jam) The pr belt timing hole cannot be read by the timing hole sensor. If this is the cause, a broken mount on the copy cartridge unit can cause this problem. The cartridge reciever unit needs to be replaced.
In the registration area there is a jam sensor that can cause this type of jam. If it fell out of place, or the magnet on the back of the acutuator arm has developer beads, can cause the machine to get a jam signal.
Oct 12, 2009 | Xerox Office Equipment & Supplies
PRINTER DID NOT TAKING PAPER AFTER PRINT OPTION AND PRINTER STOPS AFTER 2INCHES PAPER
hi
I guess its a coz of paper jam in your printer.
Heavy cardstock and certain types of slick or coated paper can cause frequent paper jams. To better isolate the cause of your problem (machine or paper), try a new **** of regular 20 lb copy or laser paper.
  • Don't Overload
    Overloading your paper tray can cause paper jams. Your manual may say that your input tray can hold 250 sheets -- but if you keep getting jams, try loading 225 sheets instead.
  • Check the Paper
    Check the minimum/maximum paper weights that your printer can handle. Paper that is too thick, or too thin, can cause jams.
  • If you still get paper jams after this may be its time to clear the internal of the machine..You might want to have a look at the following link..
  • http://lasertoners.blogspot.com/2005/10/laser-printer-jam-fix.html
hope u will b helpffull
thankyou.
May 08, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Code 200 Paper Jam Error
Hi Mike,
This error can be caused by many reasons, some of them are:
Caused by Paper Stuck Under the Second Transfer Roll
Sporadic or Intermittent 200 Paper Jams
"200 Paper Jam" Resulting from a Possibly Damaged Tray
"200 paper jam" When Attempting to Print from Tray 2
To troubleshoot this problem, please click the links with their respective causes.
Please rate it fixya if it was helpful.
Thank you
Dec 19, 2008 | Lexmark C750 Laser Printer
Paper jamed
Sounds like the fuser is causing the jam. Anything from a dislocated pic finger to other paper debry can be causing these types of jams.
If you open the back door, will the page exit the printer fine of does it still jam?
If it still jams the fuser is definatly the problem. If it dosen't, then it might be the delivery assembly causing the jam.
You might be able to see where the jam is happening if you print something and watch it though the back to see where the paper catches and jams.
Nov 19, 2008 | Brother HL-2040 Laser Printer
False paper jam message
PRINTER TRY TO PICKUP THE PAPER,BUT PRINTER CAN'T.THE CAUSE OF THIS ERROOR IS FAULTY PICKUP ROLLER & SEPRETION PAD.SOME TIMES PAPER TRAY CAN NOT BE OPEN WHEN WE PUSH IN,IN THIS CASE PRINTER SHOWS PAPER JAM
VIJAY THAKUR
Jul 01, 2008 | HP LaserJet 2430dtn Printer
Frequent paper jams.
Heavy cardstock and certain types of slick or coated paper can cause frequent paper jams. To better isolate the cause of your problem (machine or paper), try a new ream of regular 20 lb copy or laser paper.
  • Don't Overload
  • Check the Paper
Nov 04, 2007 | Samsung ML 1710 Laser Printer
HP Photosmart 3310 Printer Logo
180 people viewed this question
Seeker5211
Seeker5211
