Question about Dell 1815dn All-In-One Laser Printer
Our printer is making a really loud, sort of grinding noise and then it jams. why is it doing this? When we start to use the printer in the morning it also makes the grinding noise when it's warming up.
  • Juanita Vega
    Juanita Vega May 11, 2010
    have you checked to see if you have anything jammed in it?
    Scholar:
  • 67 Answers
You need to check a number of areas, but first try to determine where the noise is coming from...
1) First, where is it jamming...If under the cartridge, the cartridge drum may be too tight. If you have another or an old one (even if empty) try switching it out.
2) If the sound is coming from the front, your manual feed rollers (front) or main paper tray pickup rollers or gears (below) may be slipping.
3) If the sound is coming from the rear, check the fuser gears. It will have a main, big gear that meshes with the big drive gear (swing gear) inside the printer. The fuser is the accessed by removing the rear cover. The fuser can be very hot, as its job is to fuse the toner to the paper just before it exits into the bin. Let it cool off, then remove, inspect the gears for wear, re-seat it and test print--listening again to see if the sound is still there or gone.
4) If the sound is coming from the top rollers where the paper exits, check the gears that drive these rollers for wear and/or skipping teeth.
One of these will be the culprit. The hardest part is isolating the source of the sound.
Posted on Apr 29, 2010
    Director Badge:
    Uploaded 100 video answers.
  • 160 Answers
After following MacD7's advice, if you suspect it is coming from the back of the machine it most likely is the fuser drive gear (part# - D1815-W3) www.Iteminc.com has this part in stock and can ship same day before 7pm est. It is not uncommon for these to go bad. Here is a video I made that shows you how to replace this part.
Posted on Jul 01, 2011
Hp 1018 printer making really load grinding noise and not printing
ok first try restarting your printer, then try uninstalling the driver for your printer off your computer, restart your computer and printer and then reinstall your drive for the printer, see if you get a replacement for your printer or a refund
Dec 01, 2014 | HP LaserJet 1018 Printer
HP Color Laserjet 8550 - Loud grinding noise near fuser
Hi Harden,
Thats an issue with the fuser assembly,try to check the teflon condition/ teeth gear might have worn out.
Jan 30, 2014 | HP Color LaserJet 8550dn Printer
My Dell 2135cn printer all the sudden started making crazy loud grinding noises. Then I got a paper jam. I fixed the paper jam and tried to print again, but got the loud grinding noises and paper jam...
Refer to the service manual in disassembling the device.. Clean it thoroughly then try it again.. If, you have no experience in doing so, hire a qualified tech to do so.
Jun 17, 2011 | Dell 2135cn All-In-One Laser Printer
Whenever I go to print something, my printer makes a really loud grinding noise and occasionally jams paper. What could it be?
It can be that the paper drawing mechanism of the roller and the geared drive has an issue, possible that the motor has a play with the roller out of alignment , producing a difference of gap in the roller settings. If so the paper will be drawn into in different lengths so as to jam with the uneven pulling.
Sep 28, 2010 | Dell 1720dn Laser Printer
Loud grinding noise when the shredder is on.
Your gears may be stripped - mine were. Time to get a new shredder
Jul 09, 2008 | Tech Solution TS-8000 Cross-Cut Shredder
Printer makes a loud clicking noise
Same problem after a paper trapped. I don´t know if the paper trap was because something broke, but after I took the paper the noise started. Please someone give us a solution.
Apr 13, 2008 | Samsung ML 2010 Laser Printer
Dell 942 carrier jam
This morning I replaced the cartridges in the Dell 942 printer, they jammed to the left which made a loud grinding noise and the cartridge jam error came on.
I solved the problem by turning the printer on with the top up which moved the cartridges to the right a little so I could reach back, push one down a little manually which freed them to move over to the middle.
Feb 28, 2008 | Dell 942 All-In-One InkJet Printer
Loud grinding noice before starting to print
Mine makes a grinding noise when scanning or making copies. As long as everything is working, I just tolerate the noise in which the rest of the staff find amusing at first and then ignore it as I do.
Jan 25, 2008 | HP PSC 1210 All-In-One InkJet Printer
Paper transport does not work; terrible grinding noise
I took mine apart from the back and put it back together and it worked. It is probably due to moving it and the bottom paper tray alignment gets out of whack. I inspected all of the gear train and didn't find any worn or missing teeth. I suspect a paper jam started it and the user turned the printer around to open the back door. Since the handles are on the printer the tray doesn't move with it which allows it to separate and possibly jam a pickup drive gear.
Nov 08, 2007 | Dell 3000cn Color Laser Printer
Dell 1815dn All-In-One Laser Printer Logo
609 people viewed this question
Top Dell Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
