Question about Kenmore Elite 45986 Front Load Washer
Access to the door relay of Kenmore Elite?
What is the best way to access the door relay of a front load Kenmore Elite washing machine?
  • 5,911 Answers
If you are attempting to replace or troubleshoot the door latch mechanism, the following link explains how to access and/or replace:
http://www.fixya.com/support/r3575840-replacing_a_door_latch
The easiest method is to go through the door bellow. You can attempt to reach the latch by removing the top panel of the washer and working from the top, but it can be difficult to reach for some people. If you have quesitons, please post back and let me know. I hope this helps you.
Posted on Apr 28, 2010
Testimonial: "I was afraid you were going to say that; I've changed the bellow before, and was happy to have been done with the job (ha-ha). Thanks very much. "
  • Jeff Rockwell
    Jeff Rockwell Apr 29, 2010
    If you follow the steps I provided, you don't have to remove the entire bellow. You just remove the outer bellow clamp (wire hoop) and push the bellow inside, so you can access the door latch through the door opening. The repair is much easier than you think.
The machine is locked and can't open with clothes washed inside,. Add garment light is on and the time is flashing'
Whirlpool-made Front Loading such as the Kenmore Elite washing machines use a door lock and switch assembly having a tab that can be pulled manually for emergency opening of the door. This tab can be accessed with the removal of the lower front access panel. Disconnect power to the washer and drain the water from the tub before accessing it. The link below contains the detailed instructions on manual unlocking of the door.
Manual Unlocking of Whirlpool Duet and Kenmore Elite Front Load Washing Machines
Aug 26, 2011 | Kenmore HE2 Plus Front Load Washer
The door remains locked
Remove the three screws attaching the lower front access panel to the cabinet then pull the panel down and off the cabinet. You can prop up the bottom front edge of the washer or cushion and lean it against the wall to access and remove the screws more easily.
Once the panel is off, reach up along the inside of the front panel and locate the bottom of the door lock and switch assembly on the right side. Locate the tear-drop shaped tab then gently pull it down until a click is heard, and then open the door.
The door lock and switch assembly may need to be replaced if the problem persists. The replacement procedure is here.
Some
Whirlpool-made Front Loading such as the Kenmore Elite use another type of door lock and switch assembly but still with the release tab and can be accessed through the washer top. Remove the screws attaching the top panel to the rear of the machine then pull the panel rearward and off the cabinet. Pull the release tab until a click is heard then open the door.
Dec 24, 2010 | Kenmore HE2 Plus Front Load Washer
Need access kenmore elite washer door latch wiring any ideas
remove the front retainer to boot and pull back on sw side / do not remove complety and you should be able to remove sw and get to wires . not a tuff job . mm
Dec 06, 2009 | Kenmore Elite 45986 Front Load Washer
Removing front panel from kenmore elite HE-3 front load washer?
If you've removed the screws and the panel sticks, tapping on each side will knock it loose. The panel should drop down, then off. You can also try propping the two front feet of the washer up slightly for better access. A 2x4 works real well. This will allow more room for the panel to drop and gives better access to the screws. The washer is very heavy, so you may need some assistance to lift the front. Either lift from the bottom, or place your hands on the front facing of the cabinet to push the washer back. DO NOT push on the door or control panel.
If you still need assistance, please let me know. I hope this helps you.
Jul 05, 2009 | Kenmore Elite 45986 Front Load Washer
Door relay
Onboard the ECU and not seperately serviceable,
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 12, 2009 | Kenmore Elite 45986 Front Load Washer
Door popped open during the wash cycle and now will not close
This advice is for Kenmore Elite and Whirlpool Duet model front loading washers. If you experience a problem where the door becomes jammed and will not unlock or open, here's an easy way to gain access inside your washer WITHOUT calling the repairman.
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" "DLE" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
Mar 08, 2009 | Kenmore Washing Machines
Kenmore Elite Smartwash Quietpak4 won't turn back on
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
Jan 11, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite door latch
Here ya go. Try this link:
http://www.fixya.com/support/r587965-door_latch_replacement_fdl_error
If you're still having problems, please let me know. I hope this helps you.
Aug 05, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite front loading washing machine
My machine just died. No codes, no nothing. I thought it had blew a fuse. But the outlet is fine. There is no power to the unit. There is a load in the machine and I can't get it out. Help
Jan 07, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore elite he3 - door lock
If sound like a lid switch issue. Open the top of the washer to get an access to the lid switch(located near the doorframe). Look for a loose wire or a broken switch. In case there is no loose wire or broken switch, you should replace the switch. Good luck!
Sep 05, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
415 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
