Question about Craftsman Garden
Gas powered trimmer runs then stalls - carb? - Craftsman Garden
5 Suggested Answers
SOURCE: Ryobi gas string trimmer won't run
I obviously posted this under the wrong category. I would post it properly, but I can't get back to where I was (or should be)
Posted on Sep 08, 2008
  • 10865 Answers
SOURCE: Troy Bilt Trimmer 75SS stalls at full throttle. new gas
Hello. Let me assist you. Since your trimmer runs but stalls at ful throttle it is telling you that there is a fuel problem. Not enough gas is getting through the carbeurator to satisfy the engines needs on full throttle. Most likely the carbeurator is gummed up. A common problem. Let's see if we can un gum it by getting a can or carbeurtor cleaner. Go to any auto parts store and talk to the clerk about your need.
Posted on May 20, 2009
  • 115 Answers
SOURCE: Ryobi 720r trimmer starts ok but stalls when the
The carburator needs to be adjusted a little, thin our your mixture screw when the trimmer is warmed up and idling. Well how do you get it to idle? I usually have to play with the choke lever with the throttle wide open going from choke to partial choke as needed to keep it running. Adjusting can be tricky, you need a small screwdriver. Screw all the way in then back out 3 to 3.5 turns. this should get you close. Adjust idle as needed.
Posted on Jul 06, 2009
SOURCE: Polan P1500 trimmer ideles great until i press throttle and stall
Yep...I too just bought the p1500 from Amazon (got a full refund and was told to dispose of trimmer) and have the exact same problem, it starts, I even let it warm up for a while, then press the throttle lever and it bogs and wants to die. Well we know that is why it was so cheap. I liked it because it was small and ligh weight. I was told to take it to the nearest dealer (with receipt) to have it fixed for free...but the dealer laughed and asked, who said that they would do it free! So Now I will screw with it and see what I can do. If I get it working properly, I will let you know what I did....If you don't hear from me again, that means I tossed it in the garbage and bought a real one.
Posted on May 27, 2011
I can not keep my weedeater running?
Mark, Ensure plug is good, remove,inspect replace in tn tank fuel filter if clogged, remove muffler and clean screen in side, carb., carb. could be dirty or out of adjustment or diaphragms worn out and needs rebuilding. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
String Trimmer Starts Then Stalls
http://support.mtdproducts.com/app/answers/detail/a_id/10666/~/basic-troubleshooting---handheld-string-trimmers-(gasoline-powered)
Toro String Trimmer Starts Then Stalls
My String Trimmer Starts But Won Stay Running
Jun 11, 2016 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Why does my craftsman 2-cycle model 316.791860. Gas trimmer die?
Those little carbs clog very easily and what you experience is a common symptom. Go to any bog box home store and in the mower area pick up a can of small engine carb cleaner.
Remove the carb, take it apart as far as you comfortably can and soak all pieces in a can/jar of CLEAN gasoline for 10 -15 mins. Agitate to get the gas moving.
Remove the carb, and drip clean then use the carb cleaner to blow out every port you can see. reassemble and install the carb, it should work fine.
Before storing for the winter drain all gas from the tank and start it allowing the machine to run till it stalls out due to no gas. You should be fine for next season that way.
Apr 27, 2014 | Craftsman Convertible 25cc. Gas Line...
What and if there is an adjustment for the reed assembly
remove the muffler and try it if it runs at high speed open the muffler and clean the screen off
Aug 08, 2012 | Troy Bilt Tb70ss Gas Trimmer
Craftsman line trimmer difficult to start but when I get it going it stalls after a minute or so. Sometimes before it stalls, it revs up other times it just slowly loses power and stalls. Can anyone...
I'm not sure the make of your carburetor, but it probably just needs a slight adjustment of the L (Low) and H (High) mixture needles.All diaghragm carbs are about the same. If you can access them, try removing them and spraying the circuits with carb cleaner and replace them at about 1 1/2 turns open from a lightly seated position. Don't mix them up. Here is the final adjustment.
http://www.zamacarb.com/tipspage.html
Oct 20, 2010 | Craftsman 25cc Gas Line Trimmer
Fuel lines!
Sounds like you need to adjust the carb. Remove the caps from the carb. Turn both screws clockwise until all the way seated. Start the trimmer and while running begin to back out the screws slowly until the trimmer is running strong but is smooth. Once you have the carb adjusted you can put the caps back on or you can discard.
Oct 02, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi lawn trimmer keeps stalling out. I have
If it is a relatively new unit it should have the carburetor adjusted after the first few hours of use. If it stalls upon accelleration the low speed adjustment on the carb needs to be opened a little bit. If it runs a few minutes and then stalls it could be the high speed jet needs to be opened or the fuel filter is clogged.
Sep 16, 2009 | Ryobi Garden
Stihl FS85 Stalls when warm and gas is given will still idle
Make sure the carb settings are correct. Screw both tuning screws all the way in and then turn ot anticlockwise the following settings H 3/4 of a turn, L 1 full turn. (this is set to the standard setting)
Jul 10, 2009 | Homelite Mighty Lite Lawn Trimmer
Weedwacker stalls when accelerating
Check the fuel lines for cracks/breaks. If they are o.k., then:
You willneed to disassemble the carburetor and spray with carb.cleaner. Makesure the small screen is free of debris.(Should be able to see daylightthrough it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance, just let me know.
Jim
Jun 21, 2009 | Craftsman 25cc Gas Line Trimmer
Ryobi 790r trimmer has low power and stalls
Maybe a quick fix and maybe not
check your muffler the factory puts a spark arrestor screen that tends to plug after awhile
there is a little plate on the side muffler that needs to be removed to access the screen you may need a torx bit or allen wrench to remove
you may have to remove the back half of the plastic cover to access the screws
remove screen and clean with carb. cleaner or equivalent make sure you can see through it and reverse the procedure to put it back
Jun 07, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Craftsman grass trimmer stalls when warm
The carburetor needs cleaned. Disassemble the carb. and spray with carb. cleaner. Use a Den Tek brush, (used for cleaning between teeth), to clean the small portals. This works great for this job. Make sure the small screen in carb. is free of debris. Reassemble carb. and try starting.If this still doesn't solve your problem, you will need to buy a carb. kit and replace the appropriate parts.
Jim
Jun 01, 2009 | Craftsman 25cc Gas Line Trimmer
Garden Logo
162 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
