Question about Peg Perego John Deere Gator HPX Ride on Toy
Only goes forward, even when you hold it in reverse ??????
    Genius:
  • Peg Perego Master
  • 1,508 Answers
Probably a bad/disconnected shifter switch first of all check to make sure that the shifter switch is connected underneath you can order a new one here www.powerwheelsoutlet.com
Posted on Jun 14, 2012
Vs auto have forward gears even in reverse any ideas please
A4LD stuck in forward, even while in neutral and reverse. - Ford ...
https://www.explorerforum.com/forums/showthread.php?t=216567
May 27, 2008 - 19 posts - ‎5 authors
I did find a thread that referred to an "always in a forward gear" A4LD problem, ... Eventhough band adjustment should not have anything to do with the .... in the transmission and then it auto shifts through the gears normally.
700r4 forward in all gears, even neutral, no reverse - Third ...
www.thirdgen.org/forums/.../631383-700r4-forward-all-gears.html
Oct 21, 2011 - 700r4 forward in all gears, even neutral, no reverse ... It has no reversebut when I put it in reverse it tries to pull the motor down like the rearend ...
my car is not moving forward or backwards even with gea
Dec 27, 2015 | Cars & Trucks
Is there no reverse, goes forward but won't go in reverse
Outboard won't go into reverse ?? - General Discussion Forum ' In ...
www.in-depthoutdoors.com > ... > General Discussion Forum
Aug 9, 2006 - 8 posts - ‎7 authors
There's 2 cables that go into my outboard. ... It would have forward just fine but it would not shift into reverse. Assuming it's a wheel boat does the throttle handle go intoreverse but reverse doesnt work or does it not even ... Here are instructions to recover your old idofishing.com or idohunting.com account:.
Boat won't go in reverse - Lake-Link.com
www.lake-link.com/forums/boats-motors/.../Boat-wont-go-in-reverse
Sep 23, 2013 - 4 posts - ‎3 authors
Fishing Boards - Boats & Motors: Boat won't go in reverse. ... Forward seems to be working OK, but reverse just won't engage. ... I'm not sure if this is something at the throttle control end or something wrong at the motor. Any thoughts ... Looks like there'sa piece missing that's supposed to hold that in place.
Help! Will go in Reverse but not Forward gear! - The Hull Truth ...
www.thehulltruth.com/boating.../526873-help-will-go-reverse-but-not-f...
Jul 30, 2013 - 8 posts - ‎5 authors
Whether you're researching a new boat, or are a seasoned Captain, ... and it was notengaging fully into forward gear, but into reverse just fine. ... I'm a little dumbfounded as to why it will lock the prop when it's not running, but won't go into forward gear when it is ... While your there, change out the bellows. Mercury 125 won't go into reverse - The Hull Truth ...
Mar 17, 2014
Mercury 25 Horse Won't Shift into Reverse
Apr 5, 2009
90hp Yamha won't go in reverse & more - The Hull ...
Oct 4, 2007
Boat wont go forward or reverse - The Hull Truth ...
Jun 6, 2006
More results from www.thehulltruth.com
Dec 16, 2015 | Boating
My car goes into reverse but won't go forward. What's the problem?
10 Most Common Transmission Problems
www.transmissionrepaircostguide.com/10-common-transmission-proble...
A similar type of thinking goes into diagnosing car trouble. ... response issue, but after shifting into gear the engine's RPMs will surge, but the car won't move ..... Can anyone please explain why my car cant go in reverse but can drive forward
My car will not go in reverse but will drive forward. What could ...
https://answers.yahoo.com/question/index?qid...
Dec 26, 2007 - My car will not go in reverse but will drive forward. ... I tried putting it in neutral and pushing it backwards, but something catches and it won't budge. ... Either way, it's likely that the transaxle is going to require removal and ... the hood and movethe linkage by hand, then it would shift into gear ok for awhile. Why won't my truck go forward, it only goes in reverse? ' Yahoo ...
Feb 23, 2014
My car won't go into reverse, still okay to drive a 2 hour drive ...
Jan 12, 2011
My car won't go in reverse but it will go forward with no problem ...
Feb 6, 2010
My car will drive forward, but not in reverse... Could this be a ...
Sep 11, 2007
More results from answers.yahoo.com
Dec 16, 2015 | Cars & Trucks
My golden companion 2 Gc 321 goes forward when i push reverse and goes reverse when i push forward
Sounds like the motor cables are in reverse at the controller. Check that the red is in the positive and the black wire is in the negative on the controller.
Aug 12, 2014 | Golden Technologies Golden Companion 2 -...
1986 chevy truck with a brand new trans will go into al forward gears but will not reverse?
this is a mechanical linkage system so if it goes in all forward gears has park and neutral but no reverse and the fluid level is full then you have a bad transmission even though its new it does happen.you will have to get another new trans to replace it.
Mar 02, 2012 | 1986 Chevrolet Chevy
It wont go in reverse it only goes forward, the steering works fine
Hi
The ESC on this truck comes with a reverse lock out. The reason is that when you're racing, race requirements are that no reverse can be used. Now you may have accidently turned this on. Go to the Traxxas web site and download the ESC manual and follow the instructions for reverse lock out.
May 13, 2010 | Traxxas Stampede Monster Truck Rtrw/Xl 5
How to wire a forward and reverse switch
I would normally expect this to be a wsitch with three terminals on the back. Power goes into the center. Forward goes to one outside terminal and reverse goes to the other outside terminal
(A) (c) (B)
Where A is forward, B is reverse and c is the power in.
Feb 13, 2010 | NRS Salzer Position Switch S225-61049-01
Janome machine going backwards instead of forwards. Goes forward if I hold the reverse button down.
sounds like a screw may have become missing to keep the reverse knob in its proper position so it is backwards inside the machine
Dec 13, 2009 | New Home MX-3123 Computerized Sewing...
Peg Perego John Deere Gator HPX Ride on Toy Logo
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Lawrence Oravetz
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
