Question about Sony KP-57HW40 57" Rear Projection Television
KP-57HW40 w/5 red Blinks
Received TV for free but would like to get it fixed. Does anyone know what the problem could be with 5 blinks.
It will turn on sometimes a couple of lines or turned purple once, but it will automatically shut off.
Any Suggestions out there?
  • DFlorez71 Mar 25, 2008
    Thank you for your help. I can use the link to purchase the manual if you can please share?
  • Sony Master
  • 8,617 Answers
That is basically an easy repair its on of the video uotputs on the green, red, or blue crt circuits thats bad or IC309 on the A board. I would recomend getting the service manual for your set to be able to pinpoint which Ic is actually at fault. I can post a link where you can get the manual and they will provide free step by step support to help you diagnose the problem and help locating replacement parts. Thats a free service they provide when you purchase the manual that they will email to you. If you want the manual let me know.
Posted on Mar 24, 2008
I have a sony KP-65WS500 Ztv turns on but screen is blue with lines. I can hear sound but cant get tv on.the red light blinks five times.. Does anyone know what is the problem?
Can you confirm the actual model number of this set? Some had issues with the picture tubes being bad but depending on model number there may be a fairly easy way to adjust around this to correct the issue.
Apr 27, 2012 | Sony KP-65WS500 65" Rear Projection...
Kp-fx532m91 green blinking and followed by red blinks
10 blinks is a high voltage protection. This is why it has a retrace lines on the picture. It can't be fixed by reset or unplugging the set from the outlet because there's a faulty parts inside. It needs to troubleshoot the deflection circuitry to determine which part(s) gone bad. You need to ask for an assistance of a qualified TV Technician because this kind of symptoms is not DIY unless you have an experienced in electronics.
Also, check if you're unit is under warranty period/extended warranty, avail it because the manufacturer will fix it for free. Opening the rear cover will void the warranty.
Nov 12, 2011 | Sony KP-FX532M91 TV
Sony KP-46WT520 Standby Blinks 10 Times
High voltage in TV got problem and thats why TV gives 10 time blink error code.
Qualified TV tech will fix it as its bit complicated fix.
Apr 15, 2009 | Sony KP-46WT520 46" Rear Projection...
Sony wega and i get 4 blinking red lights
4 blinks code shows problem in Vertical Deflection section of TV. Of course it worth to be repaired. If you are not familiar with TV repair then call TV tech to fix it. And if you are tech person, let me know to help you out with tech info.
Jan 09, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
I have a sony KP-57WV600 Big Screen Rear projection television. The problem is this: When I first turn the tv on the picture is fine, than after it warms up- the screen turns red. What would the problem...
Let me know when TV warms up does it go to standby?
If yes, standby light would be blinking, let me know how many times it blinks?
And if TV does not go to standby mode, does picture remain with red tone?
Dec 06, 2008 | Sony KP-57WV600 57" Rear Projection...
Sony dp-51ws510 made 11-03
If your tv is Sony KP-51WS510, then it has problem in convergence ICs or Board and needs to be replaced.
Best Buy has no idea about Bulb, this TV is 3 CRTs rear projection system and has no Bulb or Lamp inside.
Need further help, let me know.
Oct 03, 2008 | Sony KP-51WS510 51" Rear Projection...
Sony projecting tv kp-57wv700
Based on service manual info, it cant blinks 7 times as per symptoms, please count again blinks. It can be 5 times.
If its 7 times blink, Horizontal Deflection stopped in this case. If you want to repair it at your own, please let me know to guide you further but it is necessary you should have knowledge of electronics.
Aug 18, 2008 | Sony KP-57WV600 57" Rear Projection...
I have the same problem as faye95. My Kp-53HS30 tv clicks on and then turns back off and red light blinks on and off. Can anyone tell me what the problem is and where can I get a free service manual o
Free service manuals are hard to find and often they are complete. You can get the sony factory service manul at the following link for 15.99 and they will give free unlimited online tech support when you get the manual. They email the manual and info on getting the support instantly after purchase. heres a link if you would like.
http://servicemanuals.vstore.ca/
Apr 12, 2008 | Sony KP-53HS30 53" Rear Projection...
Sony KP-FX432M91 TV 10 blinks
my sony kp-fx432m91 has a 10 blinks problem. it has no pictures but has sound that goes off after 5 seconds please advice on what to do.
my email address is drbonnyb@yahoo.com
Oct 31, 2007 | Sony KP-FX532M91 TV
Cant fix my sony KP-53S65
If the TV will not turn on and the red light blinks on the front of the set, it means that the microprocessor has detected a problem in the set and shut the set down. It then blinks the red light a certain number of times, and the number of blinks is the code for why the set has shut off. How many times does the red light blink before repeating?
Aug 07, 2007 | Sony KP-53S65 53" Rear Projection...
Sony KP-57HW40 57" Rear Projection Television Logo
55 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
