Question about Vizio VU37L 37 in. LCD TV
Using a Vizio VU37L and I can't seem to get my sound working from the computer to my tv. I'm using a 3.5mm to red/white RCA audio cable and I get no sound.
  • 120 Answers
Hello, try to use the 3.5 mm directly to the TV, the reason this might not work is because you are trying to use two different inputs at the same time.
Posted on Apr 28, 2010
Vizio M550SV no sound. Is there an audio card or does the main board have to be replaced?
See page 8 here:
http://cdn.vizio.com/documents/downloads/hdtv/M550SV/991UG_M420-470-550SV.pdf
From the top
- HDMI - both Audio and Video come from device via one cable.
- RF Coaxial (aka CATV) - both Audio and Video come from device via one cable.
- 15 Pin Dsub (they are calling it RGB), Video comes from this cable and Audio is from a dual 1/4" plug (looks like a headphone wire at both ends).
- Component (this is true RGB) uses RCA type cables - two sets of cables, cable one has 3 RCA at each end and they are color coded, as follows Red/Green/Blue, cable two has two RCA color coded as follows White/Red. Cable one is Video, and cable two is audio, total of 5 connections at source and 5 connections at tv.
- Composite AV - one cable set, coded as follows - Red/White/Yellow, Red/White are audio and Yellow is video.
Hope this helps.
Nov 25, 2014 | Vizio Televison & Video
Want to connect pc speakers and subwoofer to lg37lc55 tv unfortunaly it doesnt have an earphone 3.5 connection point. My other smaller tv does, the speakers and subwoofer consist of a white and red audio...
Your TV should have an AUDIO OUTPUT other than optic..at least " Headphones" output..
You can connect TV audio output with a RCA cable.
white and red audio jack....
since SUB has both RCA and "3,5mm Headphone female Jack"..here are the options;
** you need to buy a cable one end 3,5mm MALE headphone jack and the other end 2xRCA stereo (or 1x RCA for mono or you may need "Y cable " ) to be connected to your TV...
** or 2x RCA
white and red audio jack and connect from your TV..
**" "Headphones" output to SUB with 3,5 male-to-male cable ( the least recommended)
And you need to connect front,centre and rear speakers to your SUB as well...
Take care and if it succeeds please Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
May 19, 2011 | LG 42LH40 LCD TV
No tv sound. Dvd works alright. Have hdmi cable from theater sys. to tv. Cannot figure out how connect red,white or yellow cables.
By Visio "55 I'm presuming you mean the Vizio VF550XVT.
First you need an Audio Cable (Red/White RCA Connectors) and with everything turned off connect it to your TV where shown below.
The other end of the cable will then connect to the Aux In 2 of your Samsung HT-Z320 as shown below.
Once connected you can turn your Vizio & Samsung back on.
You then need to use the AUX button on your Samsung Remote Control to Select Aux 2.
And on your Vizio Remote Control follow the Instructions below.
Please leave feedback
Cheers
Andy
May 14, 2011 | Audio Players & Recorders
Sound does not work for tv shows. It has no sound issues with xbox or playing dvds. I've changed about every setting I can think of.
what are your inputs for the tv? is it from a cable box and connects with a coax cable. ? if you are using hdmi make sure you select auto out as digital from cable box and input from the tv as that audio in the mnu settings also. if you are using old school rca jacks (red yellow white make sure there in tight. if you are using component red blue green then you still need an audio either optical or the rca red and yellow from whatever your connecting to your tv. let me know if this solves your problem
Mar 17, 2011 | Vizio L32 32 in. LCD HDTV
47" vizio has sound no
Have you selected the proper input for how you have it configured? If using an HD connection, select the HDMI 1 input. If you are using the coaxial cable connection, then select TV input. If you are using the three RCA inputs (yellow, red, white) then select AV input.
Mar 01, 2011 | Vizio VO47L 47 in. LCD TV
I have a vizio HDMI DTV telvision, and a sony surround sound system, I am trying to hook my wii to this to watch movies, the problem is I have hooked the yellow cable from the wii to the surround sound, I...
If you're using the HDMI cable with 5 wires, the red, blue and green wires are for video and the red and white wires are for audio. If your TV has a component IN RCA jacks, they connect there. If you're using the 3 wire cable, yellow is for video, and the red and white is for audio. You will NOT get HDMI pictures with this setup so you will have to go into the input selections and choose composite video input on the TV menu. Get a connection diagram from Visio's website or look in your owners manual if you have one.
.Connect them to the corresponding inputs
Jul 28, 2017 | Philips HTS-3565 Theater System
I have an rt2870 and am just wondering where i connect the yellow subwoofer cord to the TV at, and i set my tv setting for the surround sound
You shouldn't connect the subwoofer to the TV. Just connect the Right and Left audio cables (red and white RCA plugs) to the TV audio out and then the other side goes receiver's audio in. If you are using the subwoofer that came with the unit, connect it to the sub port (purple and grey or black striped). The red and black striped cable goes to the subwoofer control.
If you are using another active subwoofer, connect it to the RCA jack labeled Subwoofer Audio OUT.
If you have a 3-plug RCA cable that is a composite video cable. The yellow plug carries the video, the red and white carry the audio signal. This cable is most often used for connecting older VCRs and game systems to a TV (or newer devices to an older TV). Thus leave the yellow jack dangling if using it for an audio cable.
Set your TV to use the external audio speakers and the receiver will take care of the signal to the subwoofer. (You only would connect the speakers individually for a computer sound system.)
I hope this helps.
Sep 19, 2010 | RCA RT2870 Theater System
Not get sound out of tv
You have to select how the audio being sent, you can select the sound to be sent through the HDMI cable or through the analog AUDIO out RCA (Red and White) jacks. Please see the on screen audio setup.
http://s807.photobucket.com/albums/yy352/budm/VIZIO%20L32HDTV10A/
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Jun 28, 2010 | Vizio L32 32 in. LCD HDTV
How do i hook up a nintendo to my tv which cords go where and can someone walk me through it
Round peg into the round hole. Red peg on the red slot. etc. If the wire from the nintendo doesn't fit the slot on the tv then you're in the wrong slot. if the wire from the nintendo fits the slot on the tv (and is the same color if you are using red/white/yellow rca cables) then you're good. here's a hint on connection types (you will not mix): 1. RCA (red/white/yellow round connectors) Red=right audio sound White=left audio sound Yellow=video connect to the slots that look like they want some. 2. Coaxial (stiff cable with a pinner poking out of the end -- same cable that connects you to cable tv) just hook it up by itself; it carries audio and video. 3. Component (red/green/blue)(red/white) two 'bundles' red=red component of video green=green component of video blue=blue component of video red=right audio white=left audio 4. VGA + (red/white) VGA=video (computer monitor cable) red=right audio white=left audio 5. HDMI (flat hdmi cable. you spent $30 on this 3 foot ****) HDMI=audio and video 6. hugs and kisses hugs=video kisses=audio (both sides)
Jul 15, 2009 | Video Game Consoles & Games
Connection to a portable tv
The RCA set on a tv [Red /White /Yellow] are INPUT[ VCR/DVD player] not out put. Hook the speakers up the the 3,5mm earphone jack though you will need a conveerter plug like this
Jun 30, 2007 | JBL CREATURE II Computer Speakers
Vizio VU37L 37 in. LCD TV Logo
59 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
