Question about JVC AV-48WP30 48" Rear Projection Television
I believe i am having a convergence problem. the top half of my screen has double vision and slight discoloration however the bottom half is just fine. how do i fix this myself?
  • JVC Master
  • 8,617 Answers
There is a repair kit called the AV48wp 30 convergence repair kit from www.tvrepairworld.com which has step by step instructions that should solve that issue.
Posted on Apr 30, 2010
I own a Panasonic HDTV projection monitor PT-47WX42C I am having convergence/warping issues; There is a large green/red curve in the bottom rear of screen about 4 inches tall, and stretching over more...
Replace the convergence ICs they will be big black ICs and will have Part number on them example STK392-110
Mats Electronics has them for 9.95 each you will need 2 .
1-800-628-1118
Sep 10, 2010 | Panasonic PT-47WX42 47" Rear Projection...
I have Hitachi 50GX30B tv suddenly started to give green-red double vision with arcs On top and bottom of screen What is the solution?
The tv have a problems"Known as a Convergence problems"it,dead.The tv convergence board reqiure changing 2 STK convergence ICS and some or all it resistors to solved the convergence problems.The shop will cost u $300-350 for parts and labors.
Jul 19, 2010 | Televison & Video
Top half of screen is double vision and green and purpule.
Ur tv have convergence problems,it dead.U must know how to solders?U must replaced 2 STK convergence ICS and some or all it resistors.Tries websites like Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.
Apr 27, 2010 | Hitachi 53FDX01B 53" Rear Projection...
Convergance problem on lower half of screen.smeared red and orange double vision,but only on bottom ofscreen.top appears out of focus,but not double visioned.
Howdy,
The TV has a convergence problem; the IC’s for that circuit will need to be replaced. The part(below) Number is from Toshiba, they provide good advice on replacement parts. Make sure what type of IC's your TV uses first. The cost for this repair runs around $450.00 or more.
Replace the defective Convergence Output IC Part Number
23905094 (STK392-110) using the revised “T” version IC Part Number
23135090 (STK392-110T). When Convergence Output failure is
detected, it’s recommended that both IC’s be changed to the “T” type IC
version. Inspect the Convergence Output IC’s for the “T” type version as
shown in Figure 2. Replace the Convergence Output IC’s using the “T”
type version Part Number 23135090 (STK392-110T).
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up)
Please Note: If you can not rate this post with the highest rating, then please do not leave any rating. I am doing this for free and I do not think that any rating other that the best is needed.
If you need further assistance please comment to this post and I will try to help you further.
Thanks for choosing FixYA, Big Irish.
Nov 23, 2009 | Televison & Video
Double- Vision
More than likely your akai has defective stk392-040 Convergence chips . it also may have open resistors generally 3.9 ohm flame proff. this board is attached to the top left looking from the back of the set it is screwed on by 1 screw black in the center . after installation this will probably half to be converged dinamically. which means you will half to get to the grid this is done by using the remote press mute 183 quicly to enter numbers on thew remote 2 to adjust red 4 to adjust blue horizonta 6 to adjustred vertical and 8 to adjust red vertical using center button to go up and down
Feb 20, 2008 | Akai PT4298HD Rear Projection Television
Double vision pretty much
This problem from what you are describing is a convergence issue the customer menu has a option that might help set convergence. if that doesent work a technician may have be called to adjust convergence or see what part has failed in the convergence cuicit
Feb 18, 2008 | RCA R52WM24 52" HDTV Projection Television
Blurred/double vision Samsung HDTV 1080i projection
Your convergence ICs are bad and maybe the two resistors right next to them. This is an easy and inexpensive repair if you can solder. A repair shop will run about 400.00 The parts are readily available for about 10.00 each you will need two ICs STKXXX-XXX
Look inside your set for a large aluminum heat sink that's where hey are located they will have an STK number like above stamped on them. Those are the part numbers. Let me know what type of TV and model number you have and I can help you locate the proper parts.
Jan 24, 2008 | Televison & Video
Yellow at the top, double vision, blurr
Good Day, turott1;
You need repair in the convergence circuit, purchase KIT 10. You can buy this at B&D ENTERPRISES, at 1-800-458-6053.
Good Luck, big IRISH.
Dec 30, 2007 | Hitachi 50UX26B/27K 50" Rear Projection...
53UDX10B 53 in. Rear Projection "3D vision"
the convergence IC`s and associated resistors have to be replaced, do not repeatedly push magic focus or the alignment after the parts change out will take longer which of course means higher repair bill, good luck
Nov 10, 2007 | Hitachi 53SDX01B 53" Rear Projection...
Auto Convergence not working
I'm assuming you were having picture quality problems prior to pressing the auto convergence button. If not then there could be a problem in that circuit. More likely I believe is a problem on the convergence board assembly or in the pincushion circuits. Also, check your owners manual to see if there is a manual convergence adjustment you can do.
Jan 27, 2007 | Zenith R49W36 49" Rear Projection HDTV
JVC AV-48WP30 48" Rear Projection Television Logo
151 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
