Question about John Deere Gilmour Traveling Sprinkler - 4010j
Back wheels don't turn - John Deere Gilmour Traveling Sprinkler - 4010j
  • 718 Answers
The gearing in the rear wheels is gummed up, if you can get in to axle assembly take it apart and clean it up, hard water and dirt attribute themselves to your problem. If you want an easy way out of this problem, just buy a new one and put the old one back in the box and just return it. I DO NOT in anyway condone these actions but if your not handy or just want to get er done, WELL whats the harm it's a stupid over priced water sprinkler anyway. Good Luck PAL
Posted on Apr 29, 2010
  • Butch Millen Jul 03, 2011
    You don't say how to get the assembly out.
85 honda sabre 1100 on stand in 5 gear and back wheel don't move is it frozen up ?
Is the engine Running? If the engine isn't running then it isn't a problem as you are trying to turn the engine over with the rear wheel, and you would need he Worlds Strongest Man to turn that over on his own. If the engine is running then you have a big problem and need to get it to a mechanics before riding it.
Apr 06, 2013 | Honda Motorcycles
Creaking and grinding noise when turning steering wheel
Were the top strut bearings changed?
You don't turn the steering wheel, unless
your have the vehicle moving or off the ground
Do you flush the power steering fluid every 3 years,
when you do the trans fluid every 3 years?
Aug 28, 2012 | 2000 Lexus Gs 300
Signal lights don't cancel
there is a cancel spring in the steering wheel that when the wheel comes back it pushes the signal switch to the off position.when these get worn/broken they stop turning off the signals.the only way to fix this is to pull the steering wheel off to gain access to the switch to either fix or replace the switch.
Nov 08, 2011 | 2002 Chevrolet Malibu
What is the foot pounds for the front wheel bearings on a 1995 chrysler cirrus
Hello, If you Chrysler has replaceable wheel bearings and seal. This is the way it goes---pack the wheel bearing with new grease-install the bearing in the wheel nub--install new back wheel seal--coat the axle shaft with grease lightly, thing coat-----install wheel hub on to axle shaft...be careful here don't damage the rear hub seal------------insert front race washer---install axle shaft nut--tighten nut down wheel nut until it is firm with water pump pliers----spin the hub/with tire mounted.
(the wheel and hub will turn but not freely)----take the pliers and back off the axle nut 1/4 turn----now spin the wheel and axle hub, it should spin freely---now if doesn't spin freely---back off the axle nut about 1/16 or 1/32 (or just a little bit)-----now, spin the wheel and hub and if turn freely------------Now grab the top of the wheel/tire and move it back and forth.-----if there is some movement ---try tighten the axle nut just a little little bit, unit the one can barely feel some little movement in the wheel/tire and hub.-----------Now, spin the wheel/tire and hub and it should also turn freely.
If it does----install new and correct size of cotter pin and bent the ends around the axle nut.----
coat the inside of the hub cup with grease. Now, use an rubber or plastic hammer to install the cup on the wheel/tire hub. You are finished with one wheel bearing maintenance. Now do the other side.
I really don't know if you Chrysler Cirrus has replaceable wheel bearing. All the auto/trucks have replaceable hubs, that means that the replacement is total hub with axle shaft, sealed bearings, and seals. This is bolt to each wheel steering hub. This work to remove these one unit hubs.
Four bolts hold the axle hub to the steering hub. Hear is the problem!! it has rusted to the steering hub. Also, these hubs cost more than replacing bearings, races, seals to cool turn of $180 to $250+ I wish you luck in your replacement of wheel bearing on your Chrysler. GB..stewbison
Sep 24, 2011 | Chrysler Cirrus Cars & Trucks
How do i bleed power steering pump ?
You don't, just fill it and let it idle for ten minutes. Some people will suggest turning the wheel back and forth but this tends to aerate the fluid and make the pump noisy for awhile. If you can get the front wheels off the ground, turning the wheel without the load may help but it just takes a little time to get rid of the air / noise.
Jul 20, 2011 | GMC Safari Cars & Trucks
After a few minutes of being on my Samsung HLN507w dlp tv the picture will freeze and turn black and white, but the sound still works, I have to unplug the tv to reset it then it will work again for a...
This tv have a colors wheel design in it.The tv make loud grinding motor noises or pictures flashes or freeze and pictures turn in black&white with sound.The tv colors wheel it is dying or worn out already.Don't tries to change the tv colors wheel ur self.If u don't any mechanical skills,because the colors wheel it sit way back of the tv,must take out many mechanical parts before even can come to the tv colors wheel itself to replace it.Best to hire a tv tech. to change the colors wheel,so no problems for tv funstions for later or damages more parts on the tv set,if u install the new colors wheel in the tv wrong way.
May 12, 2011 | Samsung HLN507 50" Rear Projection...
Our stroller shakes when pushing forward (very badly - would shake the baby out of the stroller if we had her in it), but if you pull the stroller back it appears to cease shaking. Is there something...
You don't mention what make / model you have. Try turning stroller upside down ( without baby in it *-) ) and spin each wheel to see if it runs freely. Try to rock the wheels from side to side to see if there is any play in the axel. On a flat smooth surface do all wheels touch the ground? If the front wheels swivel do they rotate freely without any side to side play? Some strollers have nuts you can adjust others just have Silver domes. Try tightening nuts till wheels get tight then back off just enough so they spin freely try taping domes on tighter using a large socket from a socket set and a hammer so the pressure is around the edge of the dome and not in the centre where it would dent. Silicon spray is the best lubricant for strollers.
May 09, 2011 | Bertini Baby Gear
When I turn on my Samsung 46" DLP, I get this whining noise that sounds like a soft siren winding up. It cycles on and off with no picture, and then shuts itself off after a few cycles. Sound only.
The tv have a colors wheel is design in it.The whinning noises is it the causes by a dying colors wheel it is spinning off of it motor axis.The colors wheel is dead,require replacing.The colors wheel sit way back of the tv.Have to take out many mechanical parts out before can even come to the colors wheel itself to replace it.If u have no mechanical skills don't tries to replaced the colors wheel by ur self.Hire a tv Tech to do the job,if u don't u do a wrong installation of the new colors wheel in ur tv u will regret it,because the colors wheel functions,link to the tv Light Engine Block itself most exspensive part of the tv beside the CRT-tv tube.
Apr 20, 2011 | Samsung HLP4663W 46" Rear Projection HDTV
I can't start my honda accord. the steering wheel is locked
Gently rock the steering wheel back and forth against each place it stops while trying to turn the key. DON"T use any force here! You may consider shooting a spray lube into the key slot also.
Mar 29, 2009 | 1991 Honda Accord
John Deere Gilmour  Traveling Sprinkler - 4010j Logo
353 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
