Question about Kenmore Elite 45986 Front Load Washer
How to put the top lid back on a front loading washer model #41743142300
  • 1,998 Answers
If you look around the back side of the washer youll see 2-3 screw holes align the holes on the frame with the holes on the cover slide the cover to the front of the machine and insert and tighten the screws
Posted on Apr 28, 2010
How to put top back on miele w1926
1 Remove stacking kit from top of unit.
2 Reatach the two plastic clips to the back of washer.
3 engage the two slots on the washer top into the clips , pull forward drop lid down on top of washer then secure with two screws on either side of lid.
Dec 29, 2013 | Miele W1926A Front Load Washer
How to remove back of washer
Hello, Thank You for using FixYa. I will be helping you today.If its a front loader just remove all the 1/4 inch screws from the back cover. If its a top load remove the control panel back corner screws flip up control remove two clips unplug lid switch and remove the whole cabinet.The back does not come off the top load whirlpool.
Thank You and please rate my answer if it was helpful..
Jun 11, 2011 | Whirlpool Washing Machines
How to bypass a lid switch on 26002010
You first un plug machine. Front panel has screws in the four corners. Trace lid switch to the back of panel. Cut the two wires and strip wire and put together , use **** connectors and put all back together. As you now, when washer is on high spin, make sure no kids open lids, as you just bypassed safety feature.
Jun 06, 2011 | Kenmore 20172 Top Load Washer
I have been given a Whirlpool AWM 312 by friends moving overseas and don't know how to operate it and would like to get a manual. My main problem is what drawer (front the left facing the machine) do I...
The manuals for most Whirlpool appliances are available here: http://www.whirlpool.com/custserv/index.jsp . Look for the full model number under the lid on the rim of the washer. AWM 312 is not a complete model number. Next is the washer a top loading or front loading machine? This is actually indicated in the model number - most Whirlpool models start WFW (front-load) or WTW (top-load). The exception is the compact washers (LCE4332PQ is the current model).
For the front-loading washers, the detergent goes into the largest compartment (usually the left-most part of the drawer). Top-loading washers that have a detergent compartment usually have it positioned at the top center back of the tub. Use HE detergent for high efficiency washers and do not use more detergent than recommended (using less is okay).
I hope this helps.
Mar 03, 2011 | Washing Machines
Have a Hotpoint 6 cycle HD washer. I need to open the top in order to clean.
Most front load washers have 3 screws on the top, back edge of the lid. Remove these 3 screws, slide the top back about 1 inch, and lift the top off. If you could post the model number off of the machine, I will be able to help you further.
Regards, Rick
Jan 07, 2011 | Hotpoint WMA64 Front Load Washer
Washer top has raised up in middle. how do i put the top back in place.
Not sure of your description......If its front load it has case lid do you mean that lid is raised/ distorted ?......
Dec 31, 2010 | Bosch WFMC 3200 Front Load Washer
Find serial and model number
Normally on top load machines open the lid and look toward the back hinge area inside the lid. It is usually on the back there. It may also be posted on a white sticker on the back of the machine.
Apr 30, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Unstacking the dryer
it just slide on and off and is help by two screws on the back of the lid
Apr 10, 2010 | Frigidaire GLTF2940ES Front Load Washer
Can't get top off kenmore washer model # 110 22852 100
No problem. What you want to do is this, remove the screws from the back panel first to remove that metal plate protecting the wires. Once off you need to take off the two covers on the sides of the control panel. There is one on each side, just pop them off. Once off you will see there is a screw under there holding the control panel in place. Remove the screws and that will lean back. Next take a flat head screw driver and put it under the lip of the lid on the front of the washer. I mean the lip that is about an inch down from the top on the front. Pry up and the whole lid will pop up. You will see the lid switch there held in by a screw, follow the wire to where it plugs in and unplug it and replace with the new one. Let me know if you have any other questions and if this was helpful to you. Always happy to help and good luck.
Jan 23, 2009 | Kenmore 24032\24036 Top Load Washer
How does the top come off ge washer model wjxr2080t6ww
Use a putty knife to push the spring clips in where the top of the front panel meets the washer top, about 2 or 3 inches in from each side. Front panel pulls forward and lifts off pegs, revealing two 1/4 inch drive hex screws holding top to side panels. If your washer has the lid switch near the front, push the tab on the back side toward the center of the switch and push switch up, then twist 90 degrees and pass switch back through the opening. Now lift washer top at the front side. Most washer tops will unhook from the back side now, but some need to be slid an inch to the side yet to remove once the top is lifted a few inches. If you model still has the lid switch near the back of the washer opening, lift the top at the front and unhook the back of the washer top, pull the top forward a few inches and unplug the lid switch disconnect block. (two wires)
Oct 12, 2008 | GE WVSR1060A Top Load Washer
Kenmore Elite 45986 Front Load Washer Logo
56 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
