Question about Jandy AquaLink RS2/6 All Button Dual Equipment -
I have an Aqualink RS6. light button pops GFCI
I have an Aqualink RS6. When the aux 2 (lights) button is pushed the GFCI pops. Happens if button is pushed in the house on the controller or at the power center. I have had the lights all replaced with results. Where is the problem most likely at?
  • James Young Apr 29, 2010
    I had the bulbs replaced! How do I check for a short?
  • 990 Answers
This is in your lights. Ether you have water in one of your lights or a short somewhere in the system. Were these new lights or just new bulbs?
Posted on Apr 28, 2010
  • Kieran Ruppert Apr 29, 2010
    If you just had bulbs replaced then you may have water in one of your fixtures. You will need to find the junction box for the lights. It's going to be a two x two x three inch box sitting on a condute a foot to eighteen inches from the ground, with four screws holding the top on. Their can be one or two of these depending how many lights you have. From each light you will have a black wire with three wires in it. you need to remove the wire nuts and undo these wires then try to turn the power on. If the GFI still kicks then you can look for shorts, but if not then you will need to hook each light up seperatly to see when the GFI kicks. This light will be the problem. Even a small amount of water will cause problems so you wont nessarly see the water. If this is a small pool light you will probally need to replace the light fixture. Most of these are quartz lights and can be replaced with incandesent. These will last much better. If it is a large light you can probally open the light on the deck and turn for a half hour or so to dry it out and be sure to use a new gasket when you put it back together as it may seem tight when you put it back together but expansion and contraction when the light is on will cause leaks by it self. Let me know how you do.
Why is jandy rs6 solar always on
assign the solar in the setup to a aux power the lights from the aux that you assigned
Jun 22, 2014 | Jandy AquaLink RS OneTouch RS6 Pool or Spa...
What can I do to use a PCB#6474G to replace a broken PCB#8124A?
yes the G is just a newer board go to set up and reprogram all your auxs just re assign them
Jun 15, 2014 | Jandy Aqualink RS4 Pool/Spa Combo -...
I have Aqualink RS6. Screen is lit, but no display. Is they some thing I can check?
Check to see if all 4 wires are connected inside the controller (your inside wall unit) and also at the power center outside. After removing the cover outside you will see a red 4 terminal strip (4 wires) above the buttons. Above the buttons is low voltage, below the buttons where the relays are is high voltage, be careful.
Your inside controller (cover pops off from below) has the same red terminal strip that hold the other ends of those same wires. If you have a later model it may use a telephone type connection.
If it all looks good call a pool tech who should have a portable controller, he can plug in outside to see what happens. Good luck with it.
Jan 28, 2013 | Jandy AquaLink RS OneTouch RS6 Pool or Spa...
Aqualink RS6, 6700 rev c message
check to see if wires are cut or shorted if ok need new controller
Apr 30, 2012 | Jandy AquaLink RS OneTouch RS6 Pool or Spa...
I am replastering my spa and want to put a new LED light in. Can I control the different light functions with th Aqualink and the button on the spa deck?
I have a Aqualink RS one touch control system, model 8157 RS6 Combo. The backlight in the control panal is out, the panal works fine, but does not light up, so it is hard to read. How can I replace the light? Do I have to replace the whole panal unit? Is there a bulb to replace? thanks, David
Feb 23, 2011 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Aqualink RS6 all lights on control panel lit and won't work
I' m having the exact same problem, where the panel lights up and is non-responsive. Did you ever find a solution?
May 21, 2009 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Auto shut down function not working (Jandy Aqualink RS6)
Jandy relays are known to stick. You can diagnose this yourself with a screwdriver. Remove the four screws on the outside panel. You will see a series of black rectangular relays and a lot of wires. Typically the pump relay is the one in the upper right. It will certainly be the one plugged into the left hand socket at the bottom of the circuit board.
Be sure to do all of this simply be looking. You can move the twisted red/black wires a bit to determine which relay is plugged into the first socket. Try to notice on the bottom of the relay a small black tab that is sticking out. When out, the relay is on. If the pump is running, this tab is out. If you then put the controller into service mode and the lights go out without the tab popping back in, you have a bad relay. If turning the pump off does not put the pump light out, you have a bad board.
In most cases, the relay is bad and it is a simple fix.
Nov 24, 2008 | Jandy AQUALINK RS TELELINK KIT
Jandy AquaLink RS2/6 All Button Dual Equipment -  Logo
228 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
