Question about HP COLOR LASERJET CP 3505 N PRINTER
Paper is jammed in fuser. Actually it is contact paper jammed in the fuser. (Don't ask).:0) While it was not a smart move, I am unable to "unjam" it. Any suggestions?
    Scholar:
  • 67 Answers
You'll be extremely lucky if your fuser is not ruined. Nevertheless, first you have to remove the fuser.
1) Open the cartridge door and lower the secondary door as when you change the cartridges.
2) Raise the fuser cover that is just below the LCD screen on the front of the printer.
3) The fuser sits right on top. Loosen two blue plastic screw-locks--one on each end of the fuser. Then, lift it straight up and out of the printer (be sure it is cooled off!).
4) Inspect the fuser rollers indside the fuser housing.
More than likely, the rollers will have the contact paper wrapped all around and stuck to them, since the fuser generates heat like an iron. Rotate the fusers main big gear to try and get the paper out. In the likely event you cannot remove it (without damage to the rollers), you can try using 97% or higher isopropyl alcohol on a lint-free cloth if you cann even reach the affected areas to remove it.
If all else fails, go online and look for a rebuilt fuser...much cheaper than a new original. You have my sympthies, and GOOD LUCK.
Posted on Apr 29, 2010
Testimonial: "Somehow after it cooled, I was able to pull it out with pliers over the course of an hour. And my fuser is fine. Thank you for your help. "
Shredder jammed and will not back up - how do I unjam it?
Carlo, unplug shredder, patiently use pick, scissors etc to remove stuck paper. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Unjam Paper Shredder
How To Fix Paper Shredder Jam Video
How To Clear Jammed Paper Shredder ABC Office
Best Way to Clear Out Jammed Shredder Ask Ozone
Jun 30, 2016 | Shredder Office Equipment & Supplies
Misfeed detected. Remove paper indicated by 0
misfeed is different then a jam. jam is the paper hit something miss feed the paper rollers can not pick up the paper. clean the rollers or replace them and or there associated clutches
Feb 21, 2014 | Konica Minolta Bizhub C451...
Paper won't feed through to the printing area
If when you mash print and the paper doesn't move through to be printed on it may be because you don;t have the paper inserted properly or maybe someone jammed your printer and tried to unjam it the wrong way and didn't tell you....hope it helps
Nov 16, 2011 | Office Equipment & Supplies
I have paper jammed in Xerox 7700 rollers and cannot remove even though I release the green lever on right side. Do I need to release something else?
The green lever you are referring to are I'm assuming is on the fuser. If the paper is jammed in the fuser and you are unable to remove it try removing the fuser and trying to remove the paper again, there are two thumb screws that hold it in. Make sure the printer has been off for awhile because the fuser gets VERY hot. If paper is constantly jamming in the fuser or you are unable to remove the paper you should replace the fuser, part number 016-1887-00 iteminc.com offers them for $$235 new and $139 for a refurb. Hope this helps, good luck
May 16, 2011 | Xerox Phaser 7700DN Laser Printer
I have a Brother MFC-685CW printer. I have unjammed a paper successfully. Yet the Printer is still telling me there is a paper jammed. How can I delete this message?
Toner complaint may also cause paper jams. It can be solved only by replacing it. When you switch on the loop back plug in, two flash lights appear; then it indicates paper jam. The oil spillage in toner can cause this problem. If the toner cartridge is not functioning properly, the same problem would be the result. The diodes or transistors in the fuser unit of the Multi Function Printer may get damaged and this can lead to fuser complaints. To solve this problem, you should replace it.
May 24, 2010 | Brother Office Equipment & Supplies
Iron on paper jammed and cannot be reached to unjam and will not process thru on its on
You cannot run iron on paper through a copier. They will melt in the fuser, and then the fuser will have to be replaced. The fuser generally runs 160-190 degrees, generally about the heat of the iron.
Dec 25, 2009 | Canon imageRUNNER 2200
Paper got jammed in our HP L7780and after it was unjammed we now have grinding gears on start up and it still says we have jammed paper
The jam might still be inside but you need to be sure all papers are all cleard,ckeck tray 1,where it picks papers carefully,and check the fuser assembly to be sure it not broken and faulty.
Jul 12, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Paper Jam? Print quality
If the toner wipes off the printed pages, then the fuser is the problem....not hot enough or enough pressure to heat the toner to the paper. I would try to reseat the fuser...make sure it is making good electrical contact. I have also seen the paper actually wrap around the fuser roll, which would cause the same symptoms...be careful removing the paper if that has happened...the fuser roll can be easily damaged !
Jan 22, 2009 | HP LaserJet 2840 All-In-One Printer
Hp 4100 paper is jammed between rollers the back panel should come off? and then how do I get fuser out to unjam paper
Hi Jacque,
I gather the paper has got into the fuser and cannot get into the output bin. Few things...
1. Clean output rollers. Are rollers moving?
2. Check gears on the fuser unit. Any broken or worn gears?
3. Check default paper size setting in printer, paper size setting on tray, paper size setting in printer driver and document page.
4. Leave the back door open. Does the printer still jams? If it does, see it could be paper pick up problem. Use different trays or the manual feed. Also the fuser unit could be the problem.
5. All else fails, replace the output assembly.
Rgds
S88
Dec 18, 2008 | HP LaserJet 4100 Printer
My printer jams frequently
More info is needed where does it jam ie. going to print from paper tray or coming out of the fuser in back before it comes out on top?
Feb 26, 2008 | Lexmark E330 Laser Printer
HP COLOR LASERJET CP 3505 N PRINTER Logo
273 people viewed this question
Seeker5211
Seeker5211
