Question about Oreck XL Ultra Bagged Upright Vacuum
Eureka upright is smoking and blowing air rather than suction
When turned on the vacuum smokes and blows air. The roller in the head is turning and I have cleaned any strings, etc from that area. Checked for clogged wand and hose . Could this be caused by a loose belt?
  • Oreck Master
  • 43,501 Answers
Yes the first thing that I would do is to change the belt...run it for a few seconds and then check the belt... if it is hot then you have found your problem...if it is cool then you need to keep looking...
heatman101
Posted on Apr 30, 2010
Eureka vaccuum blowing out and not sucking in
Hi There,
I am going to assume you are talking about a Eureka upright vacuum.
The cause for this is generally either
A) Broken Belt - Which you can easily fix by changing belt
or
B) Blockage in the hose somewhere - Basically test the suction with the machine turned on with you attachment hose and see if you have suction. If you do check the belt and make sure you clear out any muck left around the roller.
If you need Eureka vacuum belts go to VacuumSpot.com.au
May 13, 2012 | Vacuums
I have a Eureka Contour model 2900 type A upright vacuum, the roller works fine nothing clogged, took it apart motor blade is free of debris, no suction from tube and blasts OUT air from the front HEPA...
Even with your explanation,it seems the hose is clogged.Try taking the hose off,then blow through it or pour water through it.If this doesn't do it,make sure the suction canals are going to the proper areas.
Apr 04, 2012 | Eureka 2900A / 2901A Contour Bagged...
How to fix a vacume that is smoking
any electrical unit that smokes,is ,not worth repairing
Jul 01, 2010 | Eureka 2961AVZ Bagless Upright Vacuum
My eureka vacuum won't suction and starts to smoke when I try to use it. It sounds like it is suctioning when I first turn it on, but after about 20 seconds it begins to smell like burning and does not...
The problem is that your belt is stretched and worn. This causes that burning smell and it also causes the vacuum to not pick up well. You need to replace the belt. Here is the belt you need and the manual with instructions:
Eureka Altima Belt and Manual
Jan 31, 2010 | Eureka Altima Upright Vacuum Model 2996AVS...
No Suction
is your brush roller turning? unplug the vacuum and see if you can turn the brushroller by hand.if it turns real freely the the belt is broke ,if its real hard to turn then something is caught up around the bearings on the ends of the roller.my suggestion is if your having that much trouble withit take it back and tell them you want a new one.if they want to keep your buisness they will give you a new one
Jan 02, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
No suction.
Mine is doing the same thing, the hose picks up things fine but the rollers turn and instead of picking up it is blowing air out????
Nov 29, 2008 | Eureka WhirlWind 4381 Upright Vacuum
Main vacuum suction won't turn off
try cleaning out hoses,if that dont work turn it on its side if the roller doesnt spin u need to change belt if it does take the bottom cover and try cleaning out the hole under roller
Nov 22, 2007 | Eureka Altima Upright Vacuum Model 2996AVS...
Oreck XL Ultra Bagged Upright Vacuum Logo
179 people viewed this question
Top Oreck Vacuums Experts
xalint1
xalint1
Kory Ronning
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
