Question about Maytag Performa PAV2200
I have a Maytag Performa Electric dryer which makes a rumbling noise every twenty or thirty seconds. It doesn't seem to be drying properly either. I checked the belt and it appears to be in good condition.
  • 1,998 Answers
That rubbing noise is coming from either the rollers which are onthe bottom of the tub or the tensioner pulley. if you repair try to buy dryer rebuild kit as a kit its alot cheaper difference of paying 20-29 for the kit and 40-50 for seperate parts
Posted on Apr 28, 2010
I have a stackable washer/dryer gas maytag. Purchased around 17 years ago. The dryer is not drying clothes. Gas is powered fine and it is heating up. The cycle seems shorter than normal
The problem with it not drying is most likely going to be a worn out blower wheel thats slipping and not moving the warm air through the clothes to dry them properly. Always a pretty good sign the blower is slipping is,if you hear a rumble noise from the dryer at start up and also that same rumbling noise when the power stops. So if you hear it at start up...wait 30 seconds and open the door and listen for the rumble noise as drum stops. also you can check where the vent exits the house and see if their is air flow when the dryer is running.
GENE
Aug 19, 2011 | Maytag LSE7806A Top Load Stacked...
Dryer initial had rumbling sound when started and then quieted down to normal. It now makes a rumbling sound through the complete dry time
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Aug 31, 2010 | Maytag MDE2600 Electric Dryer
My Maytag Performa dryer makes a loud scratchy noise while drying. What is the noise and how do I fix it?
My Maytag Performa gas clothes dryer makes a scratching noise for the first few minutes when turned on, then it goes away.
Jun 01, 2010 | Maytag Performa PAV2200
Makes a horrible noise. Seems to dry fine but before its done it sound like it going to explode.
The blower wheel may be stripped out or broken.
This will cause a loud rumble noise while operating.
Jan 16, 2010 | Maytag PYE2300AY Electric Dryer
Dryer makes rumbling noise intermittently
It sounds like a faulty roller under the drum. Need to pop the top of the dryer, then remove the front -- you'll probably easily spot the faulty part.
May 06, 2009 | Maytag Dryers
Dryer makes rumbling sound when starting
If you remove the front cover and access the blower fan and see if it is still tight on the shaft. if it isn't it makes a rumble sound when started due to vibrating and after a while it makes more noise as it goes. Now I removed the fan and placed a shim in the flat area and matched the flat area of the shaft and replace it back on the shaft and it should solve it.
Mar 21, 2009 | Maytag MDE2600 Electric Dryer
Electric dryer makes a rumbling when tumbler is turning.
Check the drum bearing, a load noise, and often spinning problems are symptoms of a bad drum bearing.The bearing is at the base of the drum and accessing it is not easy.
You can find diagrams and replacement parts entering model number here.
Jan 06, 2009 | Maytag PYE2300AY Electric Dryer
Dryer making horrible squeeling noise
this is normally a problem with rollers that have gotten dry bearings , take the drum out check the rollers if they turn hard or act sticky you may clean them up and and oil with turbine oil , do not use wd-40 or 3in 1 as these will dry the bearing, check the idler pulley while you have this apart also oiling it if need be
Dec 30, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Rumbling noise
Time to call GHOST BUSTERS!
Here is a good service!
A&E Factory Service is nation wide!
1800-905-9505
They are open 7 days 24 hours to make appointments
Neil
Aug 22, 2008 | Maytag Performa PAV2200
Washing Machines Logo
140 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
