Question about Moen ShowHouse by S542BN Exact Temp w/ Five Function Transfer Valve Vertica
My drain Baby was toyingaround and it came loose how do I fix it to make the drin go up and down again?
  • 349 Answers
For bath tub take screws loose to plate and remove lever assembly and you can adjust it up and down. it should have a threaded rod to adjust it so it will work.
move it a little and put it back in and see if lever will work .
Posted on May 03, 2010
Where is the colant drin plug on 2002 WG, i have removed lower cowl and left side cover, but cant locate it.
Most newer radiators no longer have a drain plug or valve. One must remove the lower hose to drain the cooling system.
Feb 05, 2017 | Cars & Trucks
Bosch wft 2830
Its hard to say what your problem is without more information.
If you had a lot of vibration and water from a broken hose, you may have shorted one of the sensing units or main board.
Try to clear the program by disconnecting power and holding down the start key for a few seconds. Similar to Clearing the CMOS on a desktop computer.
Hope this helps
Mar 22, 2014 | Washing Machines
I have a 6mth old Maytag Quiet Partner that will not drain. I took the hose off the drain pipe and hit the Cancel/Drain button and put the hose into a bucket-worked fine. I then re attached the hose to the...
Seeing where it will work when disconnected from drain, i would be looking at the house drain as the problema nd not the dishwasher. You can check these things.
1) a clogged pipe under sink that it connects to
2)do you hava airgap,its a piece that goes on the sink and hasa chrome cover about 2-3 inches tall,if ya have one of those(not all drains do) reomve cap by pulling off and depending on brand of air gap unscrew inner cap or push in the 2 tabs and pull out inner piece to check for a blockage
3)if you dont have airgap is the drin hose under the sink always slooping down? at on point the drain hose should be higher that the level of the peice on the drain it attaches too,with corrogated drain hose its easy to pull it up and attach it under sink so at one point the hose is higher that the drain(disposer) nozzle
Good luck, i hope this helps
Gene
Aug 04, 2011 | KitchenAid 24 in. KUDI02IRBS Stainless...
Need to drain transmission fluid in 98 ford exployer 4x4 is there a drin plug ?
most trans require the removal of the pad to drain, since the filter is in the trans you have to pull it anyhow
Aug 18, 2010 | 1998 Ford Explorer
Quinny Buzz seems to be locked up and will not fold. The screw on the long part of the chassis is loose
i have a similar problem i cant get it to shut back down extremely stiff does anyone know how to fix it ?
Jun 22, 2010 | Quinny Buzz Three Wheel Stroller
Refrigerator won't stay cold
where you found the block of ice there should have been a drain hole with a tube attached that runs to the evaporative pan at the bottom ... most likley is the pan at the bottom is dirty and the drin tube is plugged at this point the easy fix is to (1) clean the drain pan (2) remove the ice in the cold transfer shaft as you have done before (3) pour warm water into the drain hole as it is probally iced up and last take a can of air like you use for a computer key board with the straw attached place it in the drain hole and hold a wet rag around it and press the button once this is clear you should be home free hope this helps
Aug 22, 2009 | Frigidaire FRT17G4B Top Freezer...
Water in fridge
First, empty freezer and fridge. Unplug and leave door open for at least 3-4 hours. Blow out drain lines with compressed air. It is more likely that the drain line is clogged than frozen; but a clogged drain line will freeze-up quickly.
Aug 08, 2009 | Kenmore 21.7 cu. ft. Top Freezer...
My top loading washer does not spin out the water
check: 1-drin hose 2-drain filer 3- no spin mode maybe you selected
Jun 08, 2009 | Washing Machines
Dishwasher fills and drains at the same time
your water is syphoning out make sure your drin hose is up
Nov 14, 2006 | GE 25 in. Nautilus GSC3400J Free-standing...
Moen ShowHouse by  S542BN Exact Temp w/ Five Function Transfer Valve Vertica Logo
55 people viewed this question
Top Moen Plumbing Experts
john h
Donni Steen
Don Numinen
Don Numinen
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
