Question about Sharp AL 1631 Copier
Hello I need help with a Sharp AL-1631 copier
When I try to copy the wheel that moves the paper just spins and spins nothing comes out and it won't shut off. I don't know where or how to get it fixed the IT department has come to look at it but they say it's beyond their capacity to fix
    Problem Solver:
  • 9 Answers
Are you talking about the bypass paper source?...if yes then the clutch lever support on your bypass assembly is probably broken, try to feed using tray 1. if it is ok...
Posted on Apr 29, 2010
The scanner won't move. I tried the lock button and it is not locked. Light comes on and paper goes through but scanner doesn't move.
if the scanner is not locked, you can try pressing #*C* then enter 14 and press start, if it is not resolving your problem you need to replace the carriage motor mcu pwb and the power supply pwb respectively.
May 18, 2011 | Sharp AL 1631 Copier
On my AL-1631, it has stopped making copies. All other processes are normal, using either the paper feeder or from the screen, paper goes through system but fails to copy. Toner cartridge is fairly new...
Sounds to me like your lamp is stuck. There is a scan latch that can catch the lamp. it is on the under side of the scanner on the left side.
Or is your lamp not coming on at all.
If it prints , it eliminates the laser, drum and developer unit. Try making a page with the top up and see if the lamp is moving back and forth.
Apr 21, 2011 | Sharp AL 1631 Copier
SHARP AL-1631, SCANNER NOT MOVING WHEN MAKING
You try any zoom copy, I maen 80% small then move scanner.
Apr 21, 2010 | Sharp AL 1631 Copier
Sharp al-1631 error L1
Your copy lamp is faulty or scanner drive is not moving. Check the lamp and replace if not lighting.
If its the scanner, unlock the scanner lock above the paper exit tray.
Nov 25, 2009 | Sharp AL 1631 Copier
The "Paper Jam" light on my Sharp AL-1631 copier stays on
The paper detector on the fixing units have a history of going bad. The fixing unit is the hot roller above the drum inside the right door on the top. As the copy comes thru the rollers the paper hits a plastic lever that is spring loaded and located in the middle of the fixing unit. The sensor is all the way to the right side of the fixing assembly. If you move the lever in the middle you'll see a piece of plastic moving on the right, that piece comes out of the sensor and if can't reset the jam, that piece may not be resetting itself back inside the sensor. This is difficult to try to explain.
Good luck
Bob
Apr 23, 2009 | Sharp AL 1631 Copier
Scanner bar will not move to scan the paper to be copied.
a piece of plastic locks your scanner in place, it is under the scanner up above where the copies come out. It turns 90 degrees.
Maybe some one turned and locked it.
Good luck
Bob
Sharp Copier AL-1631. Copies with a black line (which moves positions on the page each time). Checked the manual and cleaned the part that it told me to. That did nothing to fix the problem.
If it only happens when using the document feeder (if fitted), then the small glass on the right hand side needs a clean ( normally tippex), if it occurs when copying from the glass and doc feed then your charge corna needs cleaning
Dec 01, 2008 | Sharp AL 1631 Copier
Could not pick up papers from paper tray.
1- either the tray is not lifting the paper to meet the rollers ( which may indicate a motor problem) or the rollers are not coming down to meet hte paper (clutch problem)
Aug 30, 2008 | Sharp AL 1631 Copier
Copier runs but copy is not made
please replace the toner cartridge.
sometimes it doesn't show that toner is empty
Apr 15, 2008 | Sharp AL 1631 Copier
Sharp AL-1631 - would not copy.
Your unit definetly needs a new drum. The usual yield for this consumable is upt ot 15,000 pages, so at the stated rate, the unit yielded more than average. AL-1000 series share the same toner and drum, so finding remanufactured (or recycled) drum units should be no problem. In Puerto Rico, they are sold for about $79.00.
Oct 05, 2007 | Sharp AL 1631 Copier
Sharp AL 1631 Copier Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
