Question about Kenmore Elite 45986 Front Load Washer
Diswasher doesn't clean
My dishwasher is only 5 years old but has been nothing but problem since day one. when the diswasher is done, it leaves a residue on everything and i have to rewash everything by hand. some items had to be thrown out because of how bad they got. i have used many different soaps and diswahser cleaners and nothing works. service men have been her to fix it but it never helps. why doesn't my diswahser work?
  • 1,554 Answers
Your water heater is set too low in temp.
you can turn up the heat or get an on demand heater under your sink for the dishwasher. you get a tax rebate too.
the heater in the new washers are too small to effectively heat the water to hot.
and always add a bit of bleach to your wash. the hot water will neutralize it.
or get an old dishwasher.
Posted on Mar 26, 2008
By wwcon on Aug 24, 2011 We have a builtin maytag dishwasher of the "Quiet Series 200 MAYTAG Legacy Series". If we push the start/cancel on the control panel it does noet start. If we push...
Hello & Welcome to FixYa
The problem is with the control board that is bad and yes these parts are covered less than 5 to 7 years of warranty, for this you have to contact manufacturer. Please get back to me if you have any other questions.
Sep 03, 2011 | Maytag Dishwasher
Bosch Diswasher
Remove the drain hose and check if you have any residual into it. After 11 years your appliance may need a thourought cleaning.
Check also if the pump has enough pressure.
Apr 22, 2008 | Dishwashers
I have a bosch diswasher which is quite a few years old no sgs3042gb/03. the water isn't getting hot and it doesn't dry?any help will be grateful
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Aug 13, 2011 | Bosch Dishwashers
I Have a candy dishwasher about 4 years old after washing it seems to leave a gritty chalky residue I have tried added salt, rinse aid and putting a diswasher cleaning solution through it nothing seems to...
The problem is most likely that there is still water residue at the bottom of your machine. If the machine is not fully drained it picks up some of the residue and sprays that onto the dishes during the final rinse, leaving an unhealthy and unsightly film on everything.
Remove the bottom strainers and make sure that there is nothing obstructing the outlet pipe and the pump. If possible back flush through the outlet pipe and try draining the machine again before using it again.
Feb 13, 2011 | Candy CD623X Free-standing Dishwasher
GE Nautilus built-in dishwasher suddenly won't spray
micro switch at the door lock has failed. it just happened to me.
I wired it direct and it worked. just dont open the door until you get a new switch. it wont shut off
Jul 11, 2010 | GE Nautilus 24" Built-in Dishwasher
Clean button will not go off
Alternate solution: Within 6 seconds, alternately press "heated dry" then "normal" buttons. Wait for all lights to come on and for the diswasher to finish washing the load.
Jun 19, 2010 | Whirlpool 24 in. DU1100XTP Built-in...
I have a neff dishwasher that is maybe 5 years old. im pretty sure there is nothing wrong with it as it was working perfectly fine before i had a plumbing problem a few days ago. after the plumbing problem...
Look for the connection from the valve to the inlet of diswasher. Check the hot water valve to be on. It is probably closed when anyone working on the plumping. Good luck.
Jul 05, 2009 | Neff 24 in. S5443X2 Built-in Dishwasher
Dishes still dirty after wash cycle
It would be real helpful to have you provide the manufacterer and model number to get more specific with solution.
-Have you changes dishwasher soap powder recently? Buy a box of Electrosol or Cascade and see what happens. The ultracheep versions actually have caused cleaning problems, especilly in water-conserving dishwashers.
-Under the lower rack is the sump area with a filter that can be removed, usaully by removing several screws. Pull that filter, rinse is as best you can. Inspect under where the filter was and remove all debris. Watch out for broken glass that is found in most well used diswashers, it is hard to see and sharp! Reasemble the filter.
-If problems continue and if this diswasher is several years old, plan on getting the wash pump motor replaced (or replace the diswasher with a name brand, Energy Star model.) Good Luck!
Please update me with what you found. OK?
Mar 30, 2009 | Dishwashers
Dishwasher is leaking
Gasket probably became dislodged, replace door gaskets, at 4 years old I would replace the gaskets, they are not expensive.
Feb 17, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Diswasher stopped working
there is a fuse in the washer that needs to be replaced reply to me and will walk you through it
Dec 31, 2007 | KitchenAid 24 in. KUDI01FLSS Stainless...
Kenmore Elite 45986 Front Load Washer Logo
88 people viewed this question
Sal De
 Brian Main
Brian Main
