Question about Sta Rite Max - E - Pro 1 1/2 Hp Dual Speed
Pump hums then breaker flips
My sta rite pump is not seized because when I unfasten the clamp that connects the wet and dry side and then turn on the pump power, the motor works fine. Then when I re-connect the clamp and fasten it down, the motor just hums and the breaker flips. Any thoughts on why this happens?
  • 990 Answers
Something is binding in the pump try the impeller to see if it runs true when you have it apart. It may be cross threaded on the shaft. This is a common problem if you have a air leak in your system.
Posted on Apr 28, 2010
What is a Sta-Rite Max-E-Pro Pool Pump impeller
take off silver band clamp that will separate the motor from the wet end remove the plastic piece on the side with the motor impeller is inside check to see if glogged use a stiff piece of wire to clean out
Aug 08, 2014 | Sta Rite Max - E - Pro 1 1/2 Hp Dual Speed
Have deep well vetical sta rite pump both pipes in ground staying full of water will not pump press does not looose prime but wont build press
shut off pump breaker at the lowest faucet drain completely. Turn it back on. If this doesn't work, you have to change out the pressure valve on the side of the tank. it's not hard.
Oct 08, 2012 | Sta Rite Ds3hf 1.50 Hp Self Priming...
When i turn the switch on the pump buzzes and wont start , then trips the breaker . Help .
Either the pump is seized or the motor start capacitor is open or blown. If you can spin the impeller with your finger it is most likely a start capacitor problem.
Aug 20, 2011 | Sta Rite 1 HP StaRite Pump 15" inout...
EARLEIR TODAY I REPLACED ALL MY FILTERS FILTERS AND TURNED MY STA RITE E GLASS II ON ....IT RAN FOR ABOUT TEN MIN......... SHUT OFF AND NOW IT WONT TURN BACK ON HAVE RESET ALL BREAKERS IS THERE A RESET...
First to be sure shut the breaker off then turn back on. Most breakers require that you do this for safty reasons. Check all your power from the breaker to the back of the motor with a meter. If you have power shut it off then open the pump by removing the steel clamp that goes around the pump. Pull the motor and back half of the pump away from the rest of the pump. Now remove the difusser, the white plate covering the impeller. Then try to spin the impeller. If it spins then try to start thr motor. If it goes then you have a problem with the impellor or the difusser. If it won't start at this point you probally have a bad motor and will need to replace it. I always recomend new but you can get a rebuildt. If it's the impeller that will usually be obvious. You can take it into your local store and have them match the parts and they will usually do the bench work for just the charge for parts.
I hope this helps, good luck.
Aug 31, 2010 | Sta Rite Sta - Rite 2hp Max - E Pro...
I have Sta Rite 1.5 HP Model: P2RA5F-182L for my in-ground pool. I just notice that when the pump turns on, immediate this trips the breaker, the pump never begins to operate. I isolated the problem to...
if the seal behind the impeller is leaking theres water in the motor. you could probably replace the seal and dry it out...maybe. if the pump does turn thats probably the issue
Apr 02, 2017 | Sta Rite STA-RITE 1 HP DURA-GLAS PUMP
To purplewg re my Sta-Rite pool pump: I haven't disassembled anything yet, because I'm trying to get an accurate dx before delving. If I take the thing apart, I'll have to replace the seal, and I'd rather...
SOUNDS LIKE BEARINGS .. SEARCH YOUR LOCAL AREA FOR POOL PUMP MOTOR REPAIR GUY, SEE IF THEY OFFER FREE TESTING REMEMBER TO VOTE FOR YOUR FAVORITE FIXIT GUY ! THANKS JAY
Jun 17, 2010 | Sta Rite Max - E - Pro 1 1/2 Hp Dual Speed
Spa Motor Hums
if it is a used pump, these have a tendency to have a little rust. just get some pump pliers and rock the shaft gently back and forth. then plug it back in.
David
May 17, 2009 | Sta Rite Sta - Rite Dyna - Glas Pool Pump...
Sta Rite Max - E - Pro 1 1/2 Hp Dual Speed Logo
426 people viewed this question
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
Oloyede Monsuru
john h
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
