Question about Garden
How do I change the tires on a front wheel self propedded lawn mowers?
  • 718 Answers
There is usually a plastic cap that covers a nut/screw, take that nut/screw off and change tire.
Posted on Apr 29, 2010
Remove front tire on lawn mower
Jill,
If the tire has a hole have you considered a Plug?
If thats not an option before you can pull the tire off, there should be a small snap ring holding it in place. please use blocks to block the tires and do the following.
  • Park the lawn mower on a level surface, then place the wheel chocks in front and behind the rear tires.
  • 2Place the jack under the frame at the front of the mower. Raise the mower up and place the jack stands under each side of the frame. Lower the jack until the mower frame sits firmly on the jack stands
  • 3Remove the plastic cap in the center of the wheel by hand; this should expose the snap ring holding the wheel to the axle.
  • 4Pry the snap ring off the axle with the flathead screwdriver. Slide off the washer, wheel and the shim washers from the axle.
    To replace tire follow steps 3 and 4 in reverse order. place shim washers back on and then wheel and then snap ring, etc...
    hope this helps
  • May 29, 2012 | John Deere Garden
    Front wheels do not move on self propelled lawn mower
    check the cable at the front gear box
    Mar 24, 2012 | Toro Garden
    How do you remove the gears on a front wheel self propelled troy bilt push mower?
    Take the front tires off, pull gears and take out pins, put tires back on and you have a "non-self propell" mower.
    Apr 13, 2010 | Troy Bilt 5.5hp Self Propelled Mower
    Self propelled mower no longer propells
    SOUND LIKE THE TRANS IS WORE OUT
    Oct 01, 2009 | Garden
    Craftsman lawn mower wheels won't turn
    take cover off the top off deck and see if your belt have came off next turn deck sideways but before you turn it sideways take air filter off cause oil can come through and ruin the filter noe look and make sure the belt is on the pully
    Sep 09, 2009 | Craftsman Garden
    Blade too close to ground
    move them foward to raise wheel height. you can confirm by moving to full foward posistion on front wheels then adjust down to get height you desire.and repeat with back wheels and set accordingly. hope this helps..chris
    May 12, 2009 | Mtd Yard - Man 160cc, 21" Self - Propelled...
    I would like to change the front tires lawn mower
    Remove the wheel from the mower.
    Let all the air out
    Lay the tire flat
    Push on the tire to release the grasp on the diameter of the rim (use a malet if ou need to)
    Apply soapy water to the tire and rim
    Insert a standard screwdriver between the tire and rim and pry the tire over the rim in one spot
    Then work the screwdriver around the rim, pulling the rest of the tire up and over as you
    go
    Repeat the last step for the other side of the tire, same side of the rim though!
    Viola, there you have it. Shade tree mechanic at it best. And NO labor cost$$$!!!!!
    Mar 22, 2009 | Swisher 52" 20 Hp Riding Lawnmower #Zt2052
    Front wheels of our riding lawn mower
    Most front ends for riding lawn mowers, need to be greased. In addition to this, most of the rims for the front tires, have a nipple for a grease gun, which also need to be lubricated.
    Sep 18, 2008 | Garden
    Garden Logo
    46 people viewed this question
    Top Garden Experts
    Dennis Key
    Dennis Key
    roeb
    john h
