I turn the TV on the sound starts but visuals come with what looks like Tartan screen (horizontal and vertical multicoloured strips- then after about 10 mins the picture come on - I have taken the back off to see if there is a problem with the 'famous' capasitors - the board look OK no burn outs -
  • gizmogeeks Apr 28, 2010
    not complete yet
  • 19,396 Answers
Hi.
On the 26 inches troubleshooting is the same as on the 40 inches. Apart size, the differences are pretty small.
I think to remember that the 26 inches does not have AV board, and inputs are on main controller.
Testing on this set must be done on PSU and main controller.
Parts for the LE26S86BDX are not available online, and must be ordered calling Samsung at the number listed on the owners manual.
Refer to my other post for info on how to test the TV, procedure is the same.
Regards.
Posted on Apr 28, 2010
My 42 in phillips LCD flat seen has a black horizontal line toward the bottom how can I fix this.
Samsung LN46B650 Thin Black Horizontal Lines - Forums - CNET
www.cnet.com > Forums > Samsung
CNETI'm experiencing thin black lines from the top of the screen to the bottom. ... by babes808gpa / January 15, 2010 1:42 AM PST ... lines are about 1/4 inch apart from top to bottom of screen. starts on the right and about a 1/3 of the way toward the ...have the exact same problem, my lcd tv has multiple lines are horizontal it ...
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the ...
? 3:05
https://www.youtube.com/watch?v=KiqJuMiEiak
Jun 8, 2013 - Uploaded by Sameh Moustafa
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the picture SOLVED .... I just have one black line ...
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Dec 20, 2015 | Televison & Video
I have a Philips TV model: 27pt9015d. at the top of the screen several horizontal lines have appeared. it looks like the top inch is being cut off and then flipped back. that is - when credits are...
sounds like the vertical adjustment has spanned beyond the screen, causing it to jump up and then upside down. after the cover is removed look for vertical adjustment and with a non-conductive screwdriver, adjust it a little bit either way to see if it fixes it, if it doesn't fix it, then look again for the right one.
Jun 18, 2008 | Philips Televison & Video
Can I see the difference
Visually, there is very little difference to the eye of the average consumer between 720p and 1080. However, 720p can deliver a slightly smoother-looking image, due to the fact that lines and pixels are displayed in a consecutive pattern, rather than in an alternate pattern.your tv is display format is 720p and blu ray is 1080p. what happen is it will be scaled into 720p. old tv set format is 480p 720p represents 1,280 pixels displayed across the screen horizontally and 720 pixels down the screen vertically. This arrangement yields 720 horizontal lines on the screen, which are, in turn, displayed progressively, or each line displayed following another. 1080p, on the other hand, represents 1,080 horizontal lines displayed sequentially. This means all lines are displayed during the same pass. 1080p is the highest quality HD display format. 480p represents 720 pixels displayed across the screen horizontally and 480 pixels down the screen vertically. This arrangement yields 480 horizontal lines on the screen, which are, in turn, displayed progressively, or each line displayed following another.
Apr 05, 2009 | Samsung Televison & Video
TV turns on with sound but blank black screen
This solution from troylove solved my problem. troylove11
Rank:wizard_s.gif Wiz
Rating: 85%, 1164 votes
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source.
Jan 07, 2009 | Mitsubishi VS-50607 50" Rear Projection...
Jvc av-32wf36--have sound no picture
A bright Horizontal Line indicates failure of teh Vertical deflection Circuits.
Get a competent Technician to have a look.
Nov 30, 2008 | JVC AV-27230 27" TV
I have a Sanyo tv with sound an a horizontal white line on the screen. Where should I start looking for the problem?
A horizontal white line on the screen means that you have problem on vertical section. It might be the vertical IC or other components near that IC.
Jul 13, 2008 | Televison & Video
Lines on tv
Set starts, horizontal and vertical deflection work, HT ok, crt heaters ok, but no sound or picture
I turned the G2 voltage up and noticed a white screen with flyback lines, frame ok. I detected two badly soldered double diode rectifiers in the secondary part of the power supply ! I checked all other joints, and everything was ok !! success
White horizontal line (no vertical deflection)
Check / replace R548, R549
Sound but no picture except for a couple of horizontal colour lines
Replaced the frame chip TDA8356, set now ok
Nov 23, 2007 | Mitsubishi WS-65511 65" Rear Projection...
RCA F36674ET - Only beeps when turned on
Clearly shows problem in deflection area both horizontal and vertical section. Horizontal lines is due to vertical section problem and making bbzzzz is due to horizontal output transistor short and sometimes LOT SHORT.
Aug 23, 2007 | RCA F36668 36" TV
Hitachi 32CX39B
The xbox is just a coincidence,the good thing is your friend tap on the set and it reacted going back to normal maybe for only a second but is good,you have a loose conection is the vertical IC,this the circuit in charge of pushing the picture up and down.The vetical IC is normally mounted in a small heatsink and is flat,it should have 10 pins soldered to the board.The board need the be flip over and the pins resoldered. If you are familiar with tv service you have a place to start but if you are not too familiar be safe and call for assistance from a servicer.Let Us know how it goes and if you need more information.
Oct 13, 2006 | Hitachi 32CX39B 32" TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
