Question about Olympus Camedia C-750 Ultra Zoom Digital Camera
Custom settings disappear
This is my second attempt for help with my camera problem. Up until recently my Olympus c-750 camera (4ish years old) retained all my custom settings as I changed batteries. Now, as soon as I remove the batteries all camera settings revert back to the factory settings. I put in newly charged batteries and than heve to reset everything to my liking. It happens at every battery change. Is there an internal battery that is supposed to provide power to retain custom settings? Perhaps a capacitor to provide power?? If so, are they replaceable??. Any help is welcomed. If you replyed in the past, I must have missed that response. Perhaps sending me an email would be better. Thanks
Fred Nowak fritzak@chartermi.net
  • Anonymous Apr 10, 2008
    I also have this camera which has just started exhibiting the same problem. I believe there is an untra capacitor soldered on a circuit board within the camera that holds the settings during battery changes. Much like computer motherboards. When this fails, the main batteries are quickly drained as they continue to try charging this capacitor. Apparently a replacement capacitor has been sourced by people overseas, but here in Australia I have yet to find a replacement supplier. It would be a shame to throw out an otherwise good camera for the sake of a $3.00 part. Does anyone know where this part can be sourced in Aus. It's a 0.2F 3.3 volt cap from Panasonic ECG. part number EEC-EN0F204RL.
  • Anonymous Apr 16, 2008
    i have the same problem with my Digicam olympus c 750.
    Where can help??
This was already answered! See prior questions... indicates to go here for how to
http://www.pbase.com/ociepka/750
Posted on Jul 13, 2008
Mju 400 slow down with 2GB xD-PicCard?!?!
It's possible that your camera, being 7 years old, was never designed for a 2gb card. You can find cards of all sizes at amazon.com
Jun 15, 2010 | Olympus MJU 400 Digital Camera
I have an Olympus FE-230 and it suddenly starts taking black and white pictures. I don't know what I did, but how can I get color back?
I have had my Olympus FE-210 for about 2 1/2 years just recently it started to display an all black screen after I took pictures and like many of you I would turn it off and back on just to get 1 picture out. After testing it over and again I may have solved the problem: First: remove all of the pictures and memory card from the camera Second: go into the menu and find the reset button it will then display that the camera will return to default(factory setting) after I did this I was able to take over 35 continuous pictures using every setting and scene setting the camera has If this doesn't work I would suggest buying a new camera Hopes this helps!!
Jun 11, 2009 | Olympus FE-210 Digital Camera
How do I set the time on an Olympus c-725 Camera?
Set the mode dial to AUTO, then press
the POWER switch to turn on the
camera.
● Be sure to take off the lens cap before
you turn the camera on (P. 27).
2 Press OK button.
● The top menu is displayed.
3 Press the up arrow button to select the clock.
4 Press
to select the date format.
● Select any one of the following formats:
D-M-Y (Day/Month/Year)
M-D-Y (Month/Day/Year)
Y-M-D (Year/Month/Day)
● This step and the following steps show the
procedure used when the date and time
settings are set to Y-M-D.
Press right arrow button move to the year (Y) setting.
6 Press
up or down arrow to set the year. When the year is set, press right arrow to move to the month (M) setting.
● Repeat this procedure until the date and time are completely set.
● To move back to the previous setting, press left arrow.
7 PressOk .
● For a more accurate setting, don't press until the clock hits 00 seconds. The
clock starts when you press the button.
8 To turn the camera off, press the POWER switch.
● The lens retracts.
Jan 06, 2009 | Olympus Camedia C-725 Digital Camera
Not able to Custom Reset the camera
Hi, in order to access CUSTOM RESET, mode dial must be selected to SCENE MODE or any mode other than AUTO.
Nov 23, 2008 | Olympus E-420 Digital Camera with 14-42mm...
I need to reset my olympus e-520 to its default settings and i don't know how.
dear airwin433,
to reset your caamera to default setting follows the steps.
1. press menubutton(which is the second button from down in left side of your camera )
2. screenpops up in view fiender.
3. select the custom reset option.
4. there select th reset option ond press ok button.
and now your camera is resetted to default settings.
Sep 22, 2008 | Olympus Cameras
Olympus E-500 flash smelling like burnt plastic
You should contact Olympus about this.
Olympus have had a recall on some older 35mm film cameras for problems with the flash circuit.
Please see -
Olympus Recall
http://www.olympusamerica.com/cpg_section/cpg_recall.asp
Hope this helps,
Vincent
Jul 08, 2008 | Olympus EVOLT E-500 Digital Camera
OLYMPUS U770 SW TOUGH CAMERA / Olympus U770 SW -Camera 2007
You should be able to order what you want from most any photo products supply store. You can also get in contact with Olympus directly, and enquire for a local dealer for what you need. '
Jerry G.
Jul 01, 2008 | Olympus Stylus 710 Digital Camera
Olympus FE 190 pictures are blurry
Check any adjustments that have to with resolution. Do they look more pixellated when you look at them on the computer. Or do the pictures look out of focus?
You should check under the Shooting guide #3 (blurring background) to see if this helps you.
If none of the settings (ISO settings, resolution, lighting, image stabilization mode) help you, contact HP next.
This camera, if I recall correctly, is a fairly basic camera. I would contact HP and see what they can do for you. Since the camera is close to the warranty period of one year, they should cover it under warranty.
Mike
Nov 12, 2007 | Olympus FE-170 Digital Camera
Stuck in manual mode
Check that the wide angle pull out filter is pushed in proberly until it clicks in place also in custom menu check that M ZOOM is set to OFF. (hold zoom and - buttons together for a couple of seconds to enter and exit custom menu)
Oct 06, 2007 | Nikon Speedlight SB-600 TTL Flash
“Custom Button”
The custom button can be used to assign specific camera functions set by the user. This function allows the user to quickly select assigned camera functions by pressing the custom button and selecting settings using the control dial.
Sep 04, 2005 | Olympus Camedia C-8080 Wide Zoom Digital...
Olympus Camedia C-750 Ultra Zoom Digital Camera Logo
193 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
