Question about Maytag Neptune MAH5500B Front Load Washer
The wash started as usual. The door won't open when finished. It says "DO" I can't see anything in the manual about "DO" Do you know what this means?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. It seems the error is "od" not "do" which means that the door has not opened after two complete wash cycles and the door switch did not open since the last two final spins. To resolve this issue leave the washer unplugged for 10-15 minutes. After doing this if still the error appears then its means that you have a stuck or bad door latch. You can also try to clean the door locks, may be you can use screw drivers for this. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Apr 28, 2010
Red light will not go out so I cannot open the door
Generally machine take time approx 5 minit to open automatically open the door if not open please check door switch or pcb
Aug 07, 2016 | Washing Machines
HNL 6146 door won't open
Has it emptied all water out ??
Jun 18, 2013 | Hoover Washing Machines
The door on my Hotpoint Washing Machine WT741 won't open even though the programme has ended. We've tried running the programme again and pumping out but still the door won't open.
The door latch may have broken. You can sometimes open the door from the inside. You will know the door latch is broken if the door handle is floppy. If the door handle is not floppy - then the issue is probably with the door interlock. This is the electronic part that prevents the door from being opened during and after the wash has finished.
Either way - you'll need to get the door open.
To do this, unplug the washing machine from the mains and then move it out from where it is. Tip the washing machine to a 45 degree angle. Don't tip it over 45 degrees as you may break internal parts.
You need two people to do this - one person hold the machine at 45 degrees angle, whilst the other person puts their hand up into the machine - you should be able to feel the door catch mechanism and depending on the model, open the door that way. Sometimes the manufacturer has helpfully put a manual release inside - and sometimes they don't.
If you aren't able to open the door using that method. Get a length of strong string and poke the middle section of the string into the gap between the washer door and the machine body - to the right of the door handle. Use a flat headed screw drive to push the string into the gap, all the way around the door, so that you end up with the two ends of the string on the left hand side of the door. Now have someone put the ends of the string whilst the other person pulls the door handle. If the string is pushed in far enough it will release the door latch and the door will open. It takes a bit of persistence to get it right.
Once you have the door opened you can usually replace either the interlock mechanism or the door latch itself. Parts are easily available online from sites like espares and yourspares.
Mar 29, 2013 | Washing Machines
It keeps starting at the beginning of a cycle, won't finish, and can't open the door
1) YOU MUST test the TIMER for defective, test the contacts dirty, or oxide.Loose wire, or open or break.
see the diagram
2)see if the screen is clogged+ test the defective water inlet valve see how to test.
Jun 28, 2012 | Whirlpool Duet GHW9150P Front Load Washer
My mother accidentally pulled the door open on the washing machine when it was still locked. Now it won't do anything. It would not even finish the cycle. We were able to get the clothes out and...
Due pulling of the door forcibly the door interlock switch has damaged. So the door cannot lock properly &r the door lock switch is not functioning. Replace the door interlock switch.
Aug 07, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Hi I have a Bosch Logixx 8 washing machine that
go to the manufactures website and download the user manual giving the model nr eric
Jan 19, 2018 | Bosch Logixx WAS2446 Front Load Washer
Door light turns on when you start the machine but turns off a couple of seconds after that and the washer won't do anything. It's a frigidaire aft7000eg0. Any ideas.
check the door interlock sensor. Somewhere there is a tab or button that lets the washer know when the door is closed. If this switch isn't being triggered it could be that the machine thinks the door is open and won't function.
Jun 01, 2011 | Washing Machines
When washer starts it usually makes a clicking noise know it is humming and nothing happens the door is locked and wont open
your main belt is broken or loose i would suspect the latter,the reason the door will not open is the machine has started a wash cycle and because the belt is not able to finish the cycle the door wont open so the progam is not finished,switch the machine of at the mains and the door will open after 10 mins.But the problem remains the belt.please rate this answer thanks.adrian,,,,,,,,,
Aug 23, 2010 | General Electric WCVH6800J Front Load...
Washer stops w/ 19 min. left to finish and door pops open.
the same thing happened to our washer and a friend told us to take off panel below door and there's a opening that's covered with a circular plastic cover, open manually and remove all the junk that's accumulated from all washes, careful it may leak a great deal of water! Try that if anything else, unless you've already had it serviced!
I'm looking to try and solve yet another issue with the same washer...
Mar 31, 2009 | GE Energy Star WCVH6260F Front Load Washer
A problem with my Bosch washing machine
It usually takes 2 minutes after the wash to open the door; do not force the door. Doesn't matter if the active light is on. Just try.
Oct 05, 2007 | Washing Machines
Maytag Neptune MAH5500B Front Load Washer Logo
21 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
