Question about E-Machines eMachines T3830 PC Desktop
Machine will not power up
Used the machine this AM. Moved the equipment to a new location. After re-connecting eery thing, the machine will not power up. Checked inside the box and everything seems connected.
Any suggestions
Chris
  • ceeandbee Mar 28, 2008
    The second opinion I was looking for came in as the same as the one discovered by the geeks at Best Buy. There is an apparent problem with the MB. The quickest way to get the machine back into production was, in my opinion, to just replace the board, which I am having done.
    Thanks for all your suggestions and hope my experience with this emachine helps someone else.
    Chris, Benicia, california
  • 93 Answers
Power out let ok ?
fuse on the power cord ok ?
if all ok then it could be the internal fuse in the power supply unit
dont try and replace it you need a new 1
Posted on Mar 24, 2008
  • Brian Connelly
    Brian Connelly Mar 29, 2008
    yeah thax for the rate realy happy for u
    enjoy the un needed cost u have just waisted
Two of the electrical outlets in our kitchen have no power. I checked to make sure the connections were tight and they were, still no power. Then I replaced both of them with new receptacles (ones that...
Each outlet receives power from previous outlet box or switch box in a long chain of parallel wiring back to ceiling box, or junction box, and then back to circuit breaker.
Use process-of-elimination to find problem.
Locate all boxes on same circuit breaker. Locate box before the two dead boxes... it can be in ceiling light, or switch box, or outlet box. Then test those wires. Look for loose quick connect where wires are pushed into hole on back of device, or loose white wires twisted together and shoved to back of box.
http://waterheatertimer.org/See-inside-main-breaker-box.html
http://waterheatertimer.org/How-to-wire-switches.html
Gene
Aug 03, 2013 | Leviton 10 Brown Switch Outlet...
A friend used my Bissell Proheat Clearview shampooer, and didn't wash out the shamppoo bottle nor turn the dial to water only after using. The flow assembly on the bottle was destroyed. I bought a new...
A similar concern has been addressed on this site. With your indulgence, pls click here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 12, 2008 | Bissell Vacuums
My fisher & paykel model ad39 dryer has stopped working
Always unplug the appliance before working on it.
I would suggest checking the circuit breaker in the breaker box for your apartment, to see if it has tripped. You have probably already done this, but try to reset (open all the way and then close) the circuit breaker. Plug the power cord in again and try to operate the dryer.
If it trips the circuit breaker again, there is a short circuit or a ground, and you should unplug the machine and diagnose the problem. 240 volts AC, when shorted or grounded can start fires or kill people.
Many Dryers are equipped with a "non-resettable thermal fuse". When the air being blown through the dryer gets too hot, this thing melts and opens up the entire power circuit.The dyer doesn't do anything, as if it had no power.
This non-resettable thermal fuse can usually be purchased from the manufacturer or a good appliance supply store, and comes in a kit which also includes a new thermostat, to replace the one that probably failed and overheated the machine to start with.
Get a friend who is an Electrician to help you if you are at all unsure of replacing parts in your power circuit. Be sure to unplug the machine / use a VOM to check it dead before you touch anything electrical. BE SAFE. 240 Volts AC is not just playing around.
Oct 06, 2012 | Dryers
We just hooked up our Ford 1996 econoline van to a trailer. The trailer brakes are not working. We checked all the fuses - all seem to be fine. The fuse diagram on the fuse box panel does not tell you...
First thing is your van equipped with a trailer brake controller and is it working. This is usually a small box that is installed inside the vehicle and is needed to operate the brakes. Next what type of plug do you have on the vehicle to plug the trailer into some plugs do not support wiring for trailer brakes. If you have a aftermarket trailer brake controller it will not be fused in the fuse panel so you will to locate a inline fuse used to power up the controller. Hope this helps.
Mar 04, 2011 | 1996 Ford Econoline
Power problem
The best places to look are:
1. Remote wire running from fuse box or back of head unit.
2. Ground wire, make sure it is connected good the the body of your vehicle. (I almost threw away and $700 amp because the ground wasn't secure enough).
3. If equipped, inline fuses on power wire or connections on battery.
If all these check out, then its probably a short inside the amp. You can have them fixed, but sometimes it cost just as much for a new one! Hope this helps and good luck!
Jul 11, 2010 | Fusion ENAM60040 Car Amp
New home 8000 memory craft embroidery machine
Locate a Janome dealer and have him order them for you. The power cord can be purchased from Radio Shack if the dealer doesn't have one.
sewman7
Jul 19, 2008 | Janome Memory Craft 9000 Computerized...
Moved Washer and Now no Electrical
Suggestion: You dont need any special outlet. With a tester (you can get this in any electric shop) see if there is power in the outlet. You said it was hot?? It is not supposed to be hot. Try another outlet; & you could unscrew your machine plug to see if all the three wires are okay, ie. well connected, screwed in.
Sep 21, 2007 | Kenmore Elite 45986 Front Load Washer
Sgs43a Dishwasher
Most of the time with dead bosch dishwashers, i find that the wire nut has melted where the service cord is connected to the appliance. This connection is on the lower right side of the dishwasher. you get to it by removing the two screws from the toe kick, then removing the screw holding the cover on the metal junction box, if it has one. Make sure power is off, then check the two connections inside that box. Usually the black wire is melted and needs to be repaired and re-connected with a new wire nut. Good luck!
Jun 10, 2007 | Bosch 24 in. SGS43C12 Classixx...
E-Machines eMachines T3830 PC Desktop Logo
76 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
