Question about NetGear RangeMax NEXT WNR834B Wireless Router
Internet light vanished on Wireless N and won't come back
I unpluged one of the wires in the back to hard wire a laptop and the light went off and i can't get it to come back.
    President:
  • 1,768 Answers
1. log into the router and check the status page of the router.
2. check with the ISP to see if the connection to your premise is good.
3. logging into the router is: a.bring up browser page and type in 192.168.0.1 or the ,manufacturers ip for the router.
type this into the URL.
Posted on Apr 29, 2010
I have wireless Internet! I have a laptop, I tried to connect to it~ It will connect to the router, but won't connect to the Internet! Help!
How many wired and wireless computers do you have ion the network.
Do you have any wired computer ?
Connect your laptop to the router with the Ethernet cable and try to access Internet. See if the wired connection is working or not.
If the wired connection is working then I think you will need to check the wireless settings of the router and the laptop.
Try following websites
Router setup
How to connect to the wireless network
May 15, 2012 | Computers & Internet
Was working ok then internet down and red light on router constant - have done the turn off turn on routine and reset router to no avail. have also plugged indirectly to computer - green light then comes...
Try rebooting both the modem and the router. It could be that the modem didn't pick up it's ip number when the internet went down. Then try pluggint you computer directly into the modem first to make sure it is setup and working properly. Then plug in the router (to the modem) and the PC plugged in directly to the router and check.
Once you have it connecting at that point then check the wireless settings on both the router and the pc. Then enable the wireless on the pc, unplug the LAN and switch to wireless network on the pc and see if it won't work.
If it works plugged in on the LAN but then not on the wireless then either your configuration isn't correct (ie wrong gateway ip number...gateway should be the same ip number as the router...ie 192.168.***.***) or perhaps the wireless part of the router died. It is possible for the wireless to die and the LAN (hard wired connection) to still work.
Aug 08, 2011 | Belkin N Wireless Router wireless router
Cant get internet connestion
Are you hard wiring it? if so you may need to reboot your modem then start the ps3 back up. Don't unplug from the computer and connect it directly to your PS3 because the modem still has the computer's ip address and it won't recognize the PS3 until you reboot it. If it's a wireless connection, check to see that when you scan for wireless connection that the green wireless LED is blinking, meaning it's searching for a signal. If it's blinking, then try resetting the modem and the wireless router as well and give it another try. If the green light does not blink, then there might be a harware issue with your PS3. Good luck
Jun 04, 2011 | Sony Playstation 3 (PS3) Console
My granddaughter dropped my laptop, now when I turn it on iy says no operating System.
If no physical damages occured to any components, a display of missing operating systems is indication of unpluged cables to the storage drive containg the entire saved prorgrams. Simply said, the internet circuits wouild have gotton unpluged. A computer technician may need to open to physcally observe the mothe board for broken components or unpluged wires to reestablish the damages.
Jan 29, 2011 | Sony VAIO (PCWA-A200)
WHEN I PLUG IN MY ROUTER IT DISABLES MY INTERNET
try unplugging all the wires from your router including power then after 5mins plug internet cable in to the router then plug the power cable into the router then leave it for a few mins untill the router has conected to the internet (usualy indicated by 2 lights changing from flashic which is connecting to solid which is connected then plug the rest of the wires in with the router still on and try it then
Sep 25, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Acer Aspire On Netbook - lost wireless connectivity completely
Relax.. check all your drivers in device manager:
Vista- type device manager at startup
XP- right-click my computer -> hardware -> device manager
Make sure all the drivers is ok with no question marks or errors, if it does, reinstall your drivers from your driver CD.
Apr 03, 2009 | Acer Aspire 1414 Notebook
Netgear MR814 won;t connect
wireless problem is there re-configure the wireless router go to the wireless option then cilk right information then you get it
Mar 04, 2009 | NetGear MR814 Wireless Router
I installed the wireless internet.
guidrylillia, as per your description there is a possiblity that the router is showing signs that it is going out on you, there are ways you can avoid this from completely going defective, please check on the following:
Hard reset:
this is pressing the reset button on the router for 25 seconds, unplug and replug the power cord while reset is still pushed, then let go of the reset button once the power is plugged back in.
Firmware upgrade:
Click here to get the steps needed to be done.
once you have this going you may reconfigure the router for internet and it will be operational.
if none of the steps wokred, please contact linksys tech support at 1-800-326-7114 for further troubleshooting or replacement depending on the warranty status of the device..
Aug 19, 2008 | Linksys Computers & Internet
Can not get on internet
Which are you using, wireless internet or wired?
If your using wireless then:
Goto Control Panels via start menu
Double Click on network Connections
Right Click the LAN and choose Properties
On the bottom you see the "Show icon notification ..." make sure that is unchecked.
Close out and your good. no more notification.
Nov 12, 2007 | Acer Aspire 5100 Notebook
NetGear RangeMax  NEXT WNR834B Wireless Router Logo
54 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
