Question about Garmin nuvi 200W GPS Receiver
Takes forever to locate satellite - Garmin nuvi 200W GPS Receiver
  • yadayada
    yadayada May 11, 2010
    this is a built in fault with the 200 and 205
  • yadayada
    do u have the Garmin "Hotfix" installed?
  • 3,866 Answers
I have a garmin NUVI i wish i can email you a picture but i cannot. This proves nothing tho but to tell you i had the same issue and the issue was the software got corupt on the device due to a bad battery, Not this is not always the case so i do welcome you to investigate but at least give me some face time with my arguement here. these unit are battery powered and there little small pocket pc so to speak there software is stored into Flash memeor inside witch can become corupt and take forever to load the gps mosule you are having issues with.
things to give a shot here.
1. corupted software try a complete reload.
2. how long you had that battery? Couple years? well betterys have a certain life cycle recharges.
3. if after a reload and battery the unit still does not work you can entertain repair.
thanks for asking your FREE questions please keep in mind that it was free at no charge to you. all we ask before you leave is to rate and leave feedback to keep these free answer alive. without your feedback experts tend not to answer freebies anymore and go for the paid questions. thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Apr 28, 2010
My route 66 champion 6000 satnav has no signal, just says no GPS
When a GPS device is switch on on a different place it was switched off, I could take some minutes before it finds enough satellites And when you are in a building, or close to high buildings it could take forever, because the receiver only can receive the very weak satellite signals, if it is outside and has a clear "view" of the satellites.
Jul 05, 2014 | GPS
Takes forever to fill water bearly comes out
The water line valves will need to be replaced. The are electrically operated valves so remove all power before replacing them. They are located under the hood, top rear of the machine.
Sep 23, 2010 | Maytag Atlantis MAV6000 Top Load Washer
My Meridian Gold GPSr won't find our location. The
You might try leaving the batteries out of the GPS for a few days and then put them back in and set back up GPS. I know Garmin has a download for the loss of satellites on some of their GPS's but not sure if Magellan does or not. I have set up several of the Meridian Golds and have never had any issues with them.
Dec 03, 2009 | Magellan Meridian Gold GPS Receiver
296 takes forever to acquire satalites.
If you don't use it very often it can take time to find its location. Have you tried using the 'set initial location' option? Once it knows roughly where it is and what time it is it can then work out which satellites it should be looking for instead of searching for any/all of them. The manual does say that it will take time if it has no initial clue as to where on the planet it is, and if you're on the move while it's trying to work that out then it may take even longer. Obviously, if it has a poor view of the sky, or if most of the satellites are behind you and you have a tin roofed aircraft then that will probably not help either.
Sep 24, 2009 | Garmin GPSMAP 295 GPS Receiver
Trouble acquiring satellites
try the reset
Note: A master reset will erase all waypoints or favorites and will restore your unit to the default factory settings.
with the unit off, try pressing and holding your finger on the low right corner of the screen and slide the power switch to the on position until you see the message "confirm if you really want to delete all user data?" hit yes and let it restart. then it will set up the nuvi again, so follow the prompts.
if that fails, hook up the nuvi to the web updater and get the latest update
(actually i would do this either way)
bill
Sep 07, 2009 | Garmin nuvi 200W GPS Receiver
Satelite search takes forever
Hello bertvanjbert,
In order for your GPS to calculate its own location, it needs to receive data reports from four or more GPS satellites. This process is normally pretty fast. However, this assumes that the GPS has a clear view of the sky.
Obstructions such as tall buildings, trees and local terrain such as mountains and hills can affect your receiver's ability to "see" the sky. This is also true of GPS units used indoors or inside of a vehicle.
A GPS receiver without a clear view of the sky can take a long time to get a fix on its own location. The process can also take additional time if the GPS has been powered off for an extended period of time or if you have travelled a long distance (greater then 500 miles) since it was last turned on.
Hope this helps!
Ken
"Go Ahead. Use Us."
Jun 26, 2008 | Garmin nuvi 250 GPS Receiver
Takes forever for garmin 260w to locate satellite signal
it takes forever to get a gps signal on my garmin 260w , can you help please . thank you .
May 25, 2008 | GPS
Garmin Nuvi 350 GPS, not working
Hello, Here was my problem. I was traveling at 60mph yesterday and my Nuvi 360 dislodged and fell down with a huge impact inside my car. I came home and tried to look for any damage. Unfortunately Nuvi had stopped to continue beyond loading maps screen. I tried rebooting , but the problem persisted. It would take me to reboot screen, but after screen calibration, when it came to loading map screen, again went blank. I tried this and just simple starting by pushing power button several times but to no avail. I called technical support, eho advised me to to just simply connect it to my labtop and leave it that way for 3 to4 hours. Bingo!, in the next 30 mins, I accidentally switched my laptop top off, but Nuvi had started to work all fine.
Aug 30, 2007 | Garmin Nuvi 660 GPS Receiver
Garmin nuvi 200W GPS Receiver Logo
143 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
