Starter is slow then it surge and start the engine....often times its slow and wont start....my battery and the connections are good....I just recently put a remanufactured starter.....what could be wrong?
    Sniper:
  • 57 Answers
I would be checking on the starter solenoid. It sounds like that is where your problem is coming from. I know you said you checked your battery but it would be helpful to make sure you're getting the proper voltage... I use a voltmeter. Make sure you're actually getting 12 volts (13-14 if it's running). you can usually get a new solenoid fairly cheap from your nearest auto parts store. Hope this helps!
Posted on May 02, 2010
Slow to crank up and start but no check engine light on
Make sure battery has a full charge and battery connections all good. Make sure starter motor circuits have good voltage and ground. At the moment I can't rule out starter motor. Any testing at the starter motor, make sure tranny is in park or neutral and functional parking brake is set.
How long since a tune-up?
Mar 17, 2016 | Hyundai Cars & Trucks
My 1992 honda accord wont turn over like the battery connects and everything turns on but it wont start
This procedure usually works:
  • Check the battery cable connections:
Make sure the positive cable, makes a good connection at the battery and at the starter. Make sure the negative cable makes a good ground connection at the battery and (preferably) at the engine.
  • Check the battery the simple way, like this:
Turn on the headlights, then try to start the car.If the headlights do not dim or go out, then the battery is likely ok.
  • Check the starter and solenoid:
If the wiring looks ok, then look at the starter solenoid for a good connection, and proper voltage at the starter(10 volts minimum while cranking).
If the starter spins and no crank, the problem is most likely the Solenoid's bendix gear is stuck.
Have someone hit (not too hard) the starter while you try to start the car. This usually works by dislodging a stuck bendix gear.
  • Make a simple test of the alternator:
If you can, somehow get the engine running, measure the voltage at the battery. It should be at least 13.6 volts to properly charge the battery.
Sep 01, 2014 | 1992 Honda Accord
WHY DOES MY 04 DODGE RAM 1500 TURNS OVER SLOW AND WONT START?
Read your owners manual or use the internet,
to find out what the dash symbol is
Any dash light that is on, you should have checked for codes
The alternator has nothing to do with starting the motor
Turns over slow-- is telling you something
Bad Battery
Bad Cables--voltage drop
Bad Starter
Motor Problem-mechanical
You didn't say how any of the testing was done, or the results
What about spark,injector pulse & fuel pressure
Jul 27, 2014 | 2004 Dodge Ram 1500
2001 honda civic wont turn over, battery-starter-good, timing belt good, engine will turn by hand but when attempting to start it just clicks. Im leaning towards the ckp sensor
The crank sensor only comes into play while the engine is cranking or running to tell the computer where TDC is.
A no crank issue would be only the starting or security system.
Do you have battery power at the starter when the key is in the start position ? Are the battery cables clean and tight on both ends ?
Feb 04, 2014 | 2001 Honda Civic
My Ford Explorer wont start
need good 12 volts 11 volts starter turn engine over slow then starter solenoid start clicking.the pull in and hold in windings in solenoid wont have enough power to hold in engage starter drive pinion.have battery charged and load tested.make alternator keeping battery charged.if battery over 5 years old time to replace.
Jan 14, 2013 | 1996 Ford Explorer
1999 chevy silverado 2500.6.0 l.if truck sits all week sometimes it rolls over slow and wont start.sometimes it will start.new battery starter and alternator is good.if truck does roll slow then starts...
2 things come to mind, first check and clean all battery and starter connections. second, maybe you have something draining the battery. next time it rolls slow, put on a battery charger and see what happens. also, even though it is a new battery, it still could have a weak cell.
Oct 30, 2010 | 1999 Chevrolet Silverado 2500
I replaced the starter on voyager it has 3.3 the battery has been tested and good, however after I installed the starter it has a slow role like the battery is dead, and it wont start. the connections...
If the connections from the battery to the starter solenoid is good, the ground of the battery is good and the ground of the engine is good then the starter must crank well.
If there is slow cranking it is due to a faulty flywheel connection to the starter pinion, a tight engine/ faulty timing setting..... assuming that the battery and starter motor is double checked.
Oct 28, 2010 | 1999 Plymouth Voyager
Slow starting, almost acts like it has a dead battery at times but it does not, keeps trying to start and then finally starts
run a avr test on the battery.then check the wiring to the starter,the starter itself.alot of times people sya the battery is good because the headlights are bright,but 10 amps to run lights is not 300 amps to start a v8 engine.
Jul 11, 2009 | 2001 Dodge Ram 2500 Truck
Wont start
Is starter engaging but is turning the engine slowly then not turning engine? (that's what I'm reading) If so, check both connections at the block and starter. If reading proper voltage 12v or better, check voltage across battery when in "start" if it drops below 9.5v the starter has failed. (you can turn the engine by hand...correct?)
Apr 25, 2009 | Jeep Grand Cherokee Cars & Trucks
Computers & Internet Logo
David Payne
David Payne
