Question about RCA R52WM24 52" HDTV Projection Television
Color doesnt line up
The picture is in a 3d look meaning the reds and blues and greens dont line up
    President:
  • 1,619 Answers
Need to use convergance, if you cant do it from your remote go to menu and align.
Posted on Apr 28, 2010
If looking directly into screen you see all three lights Red Green Blue next to each other illuminating parts of the screen that color.
U mean on tv screen colors lines R,G,B colors are all mixed up and mis alignments all those R,G,B colors lines on the tv screen?Yes,u have colors shadow picture or 3D picture look alike?Yes,ur tv have a problems known as a convergence problems,it is dead.This tv convergence board it is dead must require replacing 2 STK of convergence ICS and some or all of it resistors too.To fixed the tv convergence board to fixed the tv picture convergence problems.The shop will cost u like $300-350 for parts and labors.
Jun 22, 2011 | Panasonic PT-52DL52 52" Rear Projection...
I have red and green shadows. I tried using the Converge Red/Blue and Multipoint Red/Blue functions as described in the manual but neither worked
The tv 100% have convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv have a dead convergence board,the 2 STK convergence ICS and some or all of it resistors are dead too.These parts on the tv convergence board,must be change to fix the tv convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Dec 10, 2010 | Philips Televison & Video
My philips 46pp9302 picture looks green ive lined up the blue and red colors but dont know whats wrong.....help
The tv have a problems known as a convergence problems,it dead.The tv color lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board have dead parts.The 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost like $300-350 for parts and labors.
Oct 27, 2010 | Philips 46PP9302 46" Rear Projection...
Red, yellow and blue bars going through the screen, what does this mean and how do I correct it?
U mean ur tv have colors shadows?Colors lines Red,Green,Blue misaligns don't line up to produced a solid picture?U have a 3D pic?All these are cause by a problems known as CONVERGENCE PROBLEMS.Ur tv the convergence board the 2 convergence ICS and some or all it resistors are dead.All these parts on the convergencce board,must be replaced to solved convergence problems.The shop will cost u $300-350 for parts and labors.
Jun 15, 2010 | Toshiba TP50H50 50" Rear Projection...
The picture looks 3D
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 03, 2009 | RCA HD52W56 52" Rear Projection HDTV
Letters and numbers are 3d and curved picture
Hello
red, green, and blue lines curve across the top of tv is cause by defective convergence STK IC or you have open resistor at convergence section. if you have defective RGB Color vertical ramp probably you have defective STK IC..
Angel
Thanks...
Aug 02, 2009 | RCA D52W23 52" HDTV CRT TV
Color is splitting, and almost looks 3D.
the ITC222A convergence option missing repair kit at the following link should repair that issue. The kit contains the parts and the instructions on CD
http://www.tvrepairworld.com/
Jul 19, 2009 | RCA R52WM24 52" HDTV Projection Television
The colors are distorted and it seems like the only colors that really show are blue, green, and red. When you turn the TV on you can see blue, green, and red lines across the screen. The picture also...
Hi there, this is what we call in the industry convergence board failure. this board regulate the rgb and keeps everything in order so the picture looks nice and clean. when this board starts to malfunction, what you are witnessing is usually the result. I suggest repairing this convergence board. this will fix the 3-d effect.
Mar 08, 2009 | RCA HDLP50W151 50" Rear Projection HDTV
Picture calibration settings for 42lg70
Picture Menu
Picture Mode: Expert1
*Backlight: 16
*Contrast: 83
*Brightness: 53
Sharpness: 50
*Color: 55
*Tint: 0
Expert Control
  • Fresh Contrast: Off
  • Noise Reduction: Medium
  • Gamma: Medium
  • Black Level: Low
  • Real Cinema: On
  • TruMotion: Low
  • Color Standard: HD (N/A w/HDMI)
  • White Balance: Warm
  • **Method: 10-Point IRE
    • 10 IRE
      • **Red: 1
      • **Green: 2
      • **Blue: -16
    • 20 IRE
      • **Red: -6
      • **Green: 0
      • **Blue: -7
    • 30 IRE
      • **Red: -5
      • **Green: 0
      • **Blue: -4
    • 40 IRE
      • **Red: -8
      • **Green: 0
      • **Blue: -4
    • 50 IRE
      • **Red: -4
      • **Green: 4
      • **Blue: -4
    • 60 IRE
      • **Red: -6
      • **Green: 6
      • **Blue: -5
    • 70 IRE
      • **Red: -8
      • **Green: 3
      • **Blue: -10
    • 80 IRE
      • **Red: -8
      • **Green: 7
      • **Blue: -16
    • 90 IRE
      • **Red: -9
      • **Green: 5
      • **Blue: -18
    • 100 IRE
      • **Red: -10
      • **Green: 4
      • **Blue: -9
Color Management System
  • Red Color: 0
  • Red Tint: 0
  • Green Color: 0
  • Green Tint: -15
  • Blue Color: 0
  • Blue Tint: 11
  • Yellow Color: 15
  • Yellow Tint: 2
  • Cyan Color: -15
  • Cyan Tint: 0
  • Magenta Color: 0
  • Magenta Tint: -1
lg70 nice tv excellent processor just to bad there is no intensity control on color management oh well still better than what the three s are pushing block out the hype lg will be number 1 in a few years haters are starting to come around and well leds coming,
p.s. i dont work for lg just tired of losers bashing stuff because they dont own it.
im isf certified those settings are right on the money straighter than a ruler
Oct 05, 2008 | Televison & Video
Picture in 3d without the 3d glasses
Replace 2 convergence chips, will start with stk ###-###
Oct 02, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA R52WM24 52" HDTV Projection Television Logo
132 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
