Question about Whirlpool Duet GHW9150P Front Load Washer
Stains from washer
I have noticed that many of my whites come OUT of the washer with brown stains on them that look almost like burn stains.
I have used the cleaning tabs to make sure the washer was clean. What could be causing this problem.
Thank you
  • chazard Apr 28, 2010
    Yes, like that color. How do I fix it? Thank you.
  • Whirlpool Master
  • 8,220 Answers
Posted on Apr 28, 2010
What's your problemI have an inglis royal 100 model 1a 86600 The white clothes come out with brown stains on them. It is old but seems to work well. Could it be the front gasket around the drum? I
there either is a rust mark on the tub or under the agitator oil could be leaking out or metal is rotting where the tranny shaft comes up under the agitator but like you said it's old and parts are starting to rust out and decay
Oct 06, 2017 | Whirlpool Duet GHW9150P Front Load Washer
Brown stains on clothes
Sounds as tho there is an excess of fabric softener build up on the inside of the outter tub. Try Filling with Hot water and bleach and let set for an evening and then turn back on and e tcontinue washing thru cycle.
Jan 31, 2010 | GE WHRE5260E Top Load Washer
Brown stains on white clothes in front loading washer
The brown stains are likely coming from the felt drum seal. The OEM adhesive is tar based - and after time and use - breaks down.
You'll need a new felt seal - and the adhesive that is used should be silicone based... eliminating the brown streaks.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 12, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
My Kenmore heavy duty tumble washer is leaving a light brown stain on white or light clothes. It is likely staining dark clothes but of course they are too dark to see a light stain. It is definitely...
Jun 06, 2009 | Kenmore 44102 Front Load Washer
I have been getting brown stains in the shape of a line on items of clothing washed in my Whirlpool duet washer. I can not get these stains out with anything and they are ruining numerous items of...
I have been getting brown stains in the shape of a line on items of clothing washed in my Whirlpool duet washer. I can not get these stains out with anything and they are ruining numerous items of clothing. I have no idea what is causing them - I have manually cleaned the inside of the washer. same thing here. I have been having this problem for a few weeks, cant wash anything white without ruining it.
Apr 23, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Stains on clothes after washing
This sounds like the infamous "Frigidaire Flaw" (they make some of GE's washers). The likely culprit is that the bearings on the drum's spindle are leaking.
To diagnose, call a repair man, or pull it out and remove the back cover. If you see brown streaks from the center spindle - that's it.
Repair is cheap if you can do the work yourself (inner and outer bearings), but $300+ for a technician
Feb 09, 2009 | GE WPXH214A Front Load Washer
Iam getting brown spots on white shorts after washing with Kenmore front loading washing machine
If it's gunk or build up the marks should wash away. In this case run a long cycle using "affresh" or "washer fresh" with an empty load and use the hottest water available to help rinse the gunk out.
If the marks do not wash away, it could be grease due to a bearing failure. Listen for loud growling or grinding either by spinning the drum by hand or putting it into a spin cycle. If this is the case, the rear tub assembly (contains bearing) will need to be replaced. Not much can be done about the ruined clothes :(
Jan 18, 2009 | Kenmore 44102 Front Load Washer
Front loading washer leaves stains
This often is called "lint" but is really a "whiting" left by un-dissolved soap and can be seen at it's worst on dark colored clothes. This is made worse in a colder climate where the cold water entering the washer is much colder than normal. Things that can effect the quality of the finished washed products.
Too much soap: ( we have a test for this further down the page ) If you follow the manufactures instructions on the box, then chances are you ARE using too much soap. They like to sell you their product, I find cutting usage in 1/2 of what the box says will still wash good and also cut your chances of getting "whiting" on your clothes.
Nov 03, 2008 | Frigidaire GLTF2940ES Front Load Washer
GE Profile Model WMSR3110W2WW washer
Your bearings may be going.. does it make a racket as it spins too.. bearings come as sealed units, when they break down oil leaks, hence the stains.
It will only get worse so have it sorted to save your washing.
sue
Aug 18, 2008 | GE Profile WPSR3120WWW
Burn mark
Most likely the brown stain will NOT come off, if the stain comes off the paint will come with it. Replacing the control panel is the option for making it look good again. Sorry to bring bad news.
Mar 02, 2008 | Whirlpool RBS275PD Electric Single Oven
Whirlpool Duet GHW9150P Front Load Washer Logo
242 people viewed this question
Dan Webster
Dan Webster
Sal De
