Question about Kenmore 24032\24036 Top Load Washer
Agitator had stoped working
The washer still working but the agitator dosn't move forward or backward
  • oldguy5 May 11, 2010
    Can you provide the exact Make, Model and Kenmore model number? .......... Kenmore model numbers use the format ###.######## with the first three digits of 110 for Whirlpool manufactured machines......... The model number on top load washers is usually found by lifting the lid and looking above the tub. The Fixya numbers are Stock Numbers. Can you hear the motor???? Will it spin / drain????? Have you tried a different cycle???? If it's a two piece agitator, is it only the top section that doesn't move????
  • 5,911 Answers
If this is a Whirlpool manufactured TOP LOADER (such as your Kenmore), a no spin problem can have several causes. Most commonly, this is caused by either a lid switch malfunction or a broken motor coupling. The following link explains how you can diagnose the problem and repair:
http://www.fixya.com/support/r3965207-whirlpool_top_loader_no_spin_problem
Read through the link provided and let me know if you have any questions. I have included parts sources and instructions on how to replace each part as well.
If this just a simple matter of the agitator not working, but everything else does, you may just have a worn agitator cam assembly, worn agitator dogs, loose agitator bolt, or all of the above. The following link explains what agitator dogs are and how to access them:
http://www.fixya.com/support/r3608577-replacing_agitator_dogs
Whirlpool manufactured washers use a split agitator design. The top half is known as the "auger, while the lower half is the agitator. Between the two pieces is a cam assembly, with small teflon teeth known as "dogs". There's also an agitator bolt that holds the entire assembly to the center post.
If the auger (top half of the agitator) is slipping, I would suspect the dogs or cam assembly need to be replaced. The part number for the dogs is included in the link I provided. For a little more you can purchase the entire cam assembly which includes the dogs, the cam, the cam seal and thrust bearing.
If the entire agitator appears loose or slipping, check the agitator bolt to ensure it is tight. DO NOT overtighten as this can restrict movement of the agitator or damage it. Tighten until snug.
Replacement parts (if required) can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
All these sites are reputable and offer great service with competitive pricing, so shop and compare. The first three sites I listed also include helpful exploded view parts diagrams to assist you in locating and properly identifying the parts you need. If you do not wish to order parts on line, use the part numbers from the Sears website and go to your nearest appliance parts retailer. All these parts are commonly sold as part of their in-store inventory.
If you have any questions, please post back and let me know. I hope this is helpful to you.
Posted on Apr 28, 2010
My washer works fine just no agition goes though cylces just fine fills and drians fine but agitator does not move
80040 dog kit is all you need. The upper portion of the agitator has four dogs mounted inside. As the transmission moves the agitator back and forth these dogs catch the side of the upper agitator. This rotates the fins and makes the clothes tumble on top of each other forcing them into a downward motion. When the facing of the agitator dogs wear smooth the upper agitator will cease to function.
Video:
I have a service manual and more videos HERE
Feb 10, 2011 | Kenmore 24032\24036 Top Load Washer
Agitator not moving--seems loose
This washer has what we call a bionic agitator and this agitator has a 2 parts:
it has a base and a top section.
IF the BASE IS NOT WORKING AT ALL, please have the transimssion checked and also check the coupling.
IF the BASE is working and the top is NOT
THEN replace the 4 plastic AGITATOR DOGS that are in the agitator.
Remove the CAP from the agitator...remove any plastic cap.
Get a socket wrench and get the socket that removes the bolt.
remove bolt...
PULL the agitator from the base and separate the top from the bottom.
Take the top and turn it upside down to remove the platic interior part that holds these 4 dogs. REMOVE the old dos and replace with new and do a reverse engineeriong putting agitator back.
Nov 20, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
How can I remove the agitator on a premier 510 model
Before removing the agitator, unplug the washer to avoid an electrical shock hazard.
The agitator is fastened to the agitator shaft and its movement is driven either by splines or a simple clutch assembly. The splines are usually plastic or rubber nubs on a cylinder that fits over the agitator shaft. If the nubs wear down, the shaft will not turn properly or it will turn weakly. If the agitator is moving in only one direction, the likely cause is the clutch assembly. The clutch has dogs that depress and pop up with each turn. If those dogs are worn, they will not engage properly and the agitator will turn only in one direction.
Various makes and models differ in how the agitator is removed. In some newer models, the agitator just lifts straight up and out. However, in most models you will have to do some combination of the following steps. First remove the fabric softener dispenser, if any. It should either lift or screw off. Next remove the cap. It may lift off, screw off or failing that, it may need to be pried off.
Beneath the cap some agitators are secured in place by a bolt. Use a socket wrench with an extension to remove that bolt. Some washers may have a screw near to the bottom of the agitator post that must be removed. Now try to lift the agitator straight up, possibly with a little back and forth rocking motion. Use caution when pulling, the agitator may come loose suddenly and hit you in the face or send you flying backward.
If the agitator is particularly stubborn, you can loop some rope under one side of the agitator at the bottom and then up over a broom handle. Now loop it again under the other side of the agitator and back up to the broom. Brace one end of the broom handle against the top of the washer and lift up on the other end. Double check that you have removed anything that may be securing the agitator in place. Do not use too much force or you may damage the washer cabinet, agitator or injure yourself.
Thank you for contacting Fixya.com
Aug 05, 2009 | Hoover Nextra HNT 2135 Top Load Washer
Kenmore Series 80 Washer, Model 20852 - Agitator not turning well, making noise
Hi, If the washer spins properly but the agitator does not work, it could be the dog kit needs replaced. If the washer does not agitate or spin, it is probably the coupler.
Put the washer in wash cycle with no laundry in it and see if the lower prt of the agitator moves. If the agitator moves, try and hold the upper half of the agitator and see if it will only move one direction.The agitaor dog kit is designed to only let the top part of the agiator to grab one way. When they go bad, they can make some noise.
To replace the dog kit in the agitator, remove the top cap/rinse dispenser and the inner bolt cover. Remove the 7/16” bolt and lift the agitator out of the washer. Separate the 2 halfs of the agitator and replace the dog kit inside the upper part of the agitator.
Please let me know if this helps you or if I can assist you further.
Thanks
Vic
Jul 17, 2009 | Washing Machines
Agitator spins in one direction
The purpose of the upper portion of the agitator is to push the clothes in a downward motion. As the agitator moves the dogs grab and on the backward srtroke the top portion rotates a quarter turn. In the spin mose the agitator only goes in one direction or your clothes would be torn to shreads.As the washer rotates back and forth, the dogs grab the inner walls of the upper agitator and that forces the clothes into a downward movement to the bottom of the tub. These dogs will wear out. To test whether or not these are bad just grab the agitator while in wash mode. The dogs should advance the top portion easily. If not then they are worn out. To replace them you must remove the agitator and sit it on the floor. Hold the base down with your feet and yank the top upwards. After seperating the 2 pieces you simply install the new dogs and line up the bottom with the top being careful not to break the little tabs on the bottom agitator that hold the top in place.
Dec 22, 2008 | Kenmore 22422 Top Load Washer
Clothing stuck on agitator with top loading washing machine
Dear Whitworth,
please rate this solution if it meets ur needs, else choose fixya...
The agitator's movement back and forth is important for the cleaning of your laundry. If it doesn't function properly, your clothes won't be as clean as possible. If your agitator does not move, moves only in one direction or its movement is very weak, you will probably need to remove the agitator. Furthermore, in order to inspect the tub for leaks, the clutch assembly, the splines, or to remove the spin drum, you will have to remove the agitator.
Beneath the cap some agitators are secured in place by a bolt. Use a socket wrench with an extension to remove that bolt. Some Maytags may have a screw near to the bottom of the agitator post that must be removed. Now try to lift the agitator straight up, possibly with a little back and forth rocking motion. Use caution when pulling, the agitator may come loose suddenly and hit you in the face or send you flying backward.
Click here to order replacement parts.
please rate this solution if it meets ur needs, else choose fixya..Thank you.
Dec 17, 2008 | Kenmore 22422 Top Load Washer
GE washer not agitating
when you pulled up agitator was the splined shaft moving back and forth ? If so replace the insert in the agitator. If not the problem is in the transmission .
Dec 11, 2008 | Washing Machines
Washer won't spin
Could be a worn belt,
Empty the machine and tilt backwards, you may need some help to do this.
Remove the belt and check, some times these appear OK but may have stretched.
Chech the agitator pully, try to rotate, will only move in one direction, see agitator moving as you do, get the person helping you to see this.
Check the motor moves freely on the tensioner, motor will appear to move 2".
Fit a new belt and try.
Apr 16, 2008 | Maytag PAV2300 Top Load Washer
Agitator stops when sweeper is pulled backward
If you have made no changes to the vacuum's setup and are using it on same carpet you have previously used it on with no problem, then the most likely cause is the agitator/beater bar's drive belt is worn or on some models may have a tension adjustment which is set too loosely. This can also be caused by having the vacuums height adjustment set to low for the carpet or flooring you are using it on, causing to much drag when the vacuum is pulled backwards for the agitator to overcome.
The vast majority of agitators turn in a forward direction, as if it would pull the vacuum forward, when you pull the vacuum backwards the drag is increased.
So...First check height adjustment (a no cost fix), then check out the tension adjustment (if present on you model, some engage when top of vacuum is tilted back after stepping on the release pedal) Lastly, consider changing belt especially if you have had the vacuum awhile or if it gets a fair amount of use or it you seem to need to use it on a low height setting all the time to vacuum up debris.
Hope this helps!
Dec 19, 2007 | Kenmore 34923 / 34925 Progressive Bagged...
AGITATOR DOESN'T WORK WELL
sounds like the spline is stripped on the agitator take the bolt out of the center of the agitator remove the agitator and visually inspect the splines let me know if this works
Sep 12, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore 24032\24036 Top Load Washer Logo
55 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
