Question about Danby 5.5 cu. ft. / 156 liter Chest Freezer Millenium DCF550W
Power light not working. What type bulb needed for replacement?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 66 Answers
Model make of this unit is very helpful. let me know i got a parts book.
Posted on May 02, 2010
How do I replace the door light switch?
I appreciate your post, Deborah!
From what you have described you need to replace the door light switch on your Frigidaire freezer. In order to assist you further I would need your model number. You can locate your serial tag (which lists your model number) on the inside wall of your freezer. I look forward to assisting you. -Matt
Apr 27, 2015 | Frigidaire Freezers
How to change the bulb on my freezer?
led's become weak over time. it is only an indicator that the power is on. Leave well alone!
Oct 01, 2014 | Freezers
Light bulb is not working. how to change it and what kind of bulb is it model: FKFH21F7HW
Good Afternoon Rose, I am happy to assist you!
Before replacing the light bulb in your Frigidaire freezer please confirm that the temperature control is set in the OFF position and unplug your appliance to avoid electrical shock. Typically, you may remove the light bulb by turning it counter-clockwise. The old bulb can be replaced by an equivalent watt bulb (part number is 216988100) available either from part distributors or hardware stores. I hope this information helps to some degree!
Feb 25, 2014 | Frigidaire FKFH21F7HW Freezer
Skandiluxe freezer seals
Hi
Most freezer lights are screw on bulbs. Unscrew the bulb unticlockwise and replace with a new one.
Feb 15, 2014 | Freezers
My freezer is not working. The light on the front is not on. Does this mean that either the switch with light is not working or the power cord is not working?
check first the convenience outlet or the main breaker reset if trip off or replace together the cord test it the continuity using ohmmeter also check the over load protector of the compressor replace if busted. also check the bulb if busted replace it.
Feb 23, 2011 | GE 7 cu. ft. Chest Freezer FCM7DR
Hi, I have a Vulcan Deep Freeze 300L with no bulb in light fixture, Can you tell me what type of bulb and wattage should I buy. Not sure if these bulbs are a special type or not. I also need a cover for...
http://www.alliedappliance.net/_vulcan_part.html
aussie aussie aussie oy oy oy
hi from sonic boom electronics sydney above is a link to volcan parts australia they should be able to help with a cover as for the globe it is 240volt 20 watt pm5 connection
take care need more help feel free to call 0416380976
Sep 29, 2010 | Vulcan Freezer EXTWARRANTY-GCO2D Extended...
Light doesn't come on on front panel
It sounds as if the bulb has burned out and you need to replace it. It might also be that, if the indicator light is located at the bottom of the cabinet, that it might have become unplugged from the wiring and it simply needs to be reconnected. In any case, be sure to unplug the freezer before you go removing anything, such as the access panel or the bulb mount, etc.
It is a very easy repair in most cases and you will need to determine the brand and model number for your freezer, since you didn't provide it here. Once you have that information, you can go to www.searspartsdirect.com and enter that info into the site and locate the replacement bulb for your freezer.
You'l be able to see a line drawing and a parts listing for all the various pieces for your freezer and can order it online directly from them, too, if you wish. You can also use the part number to get on from a local service provider if you prefer.
Remember, with more information (brand and a complete model #) we could provide you with the precise part numbers and a direct link to the web pages that show your specific freezer.
Hope you find this Very Helpful and best regards!
Oct 23, 2009 | Freezers
Changing light bulb in a 25 year old freezer
Whatever you do, you MUST unplug the freezer before attempting any repairs... there will not be any release buttons, nor any special installations for water safety... also, take care to avoid cutting yourself on the broken glass..
1) did the whole light bulb glass And internals come out, or is the internal part of the bulb still present?
2) verify that the light bulb is really a screw-in appliance bulb -- look into the center of the broken bulb and see if the metal base has internal ridges -- or if the metal base is smooth on the inside...
3)  if a screw-in appliance bulb:  3a)  if the whole light bulb glass AND internals came out, you will have to probably look very close inside the socket to determine the wall of light bulb base... it should be very thin and flexible and very unlikely you can unscrew it directly -- I've had to take needle-nosed pliers and gently bend and twist until the bulb base came out...
3b)  if part of the glass remains as well as the internal stem, I have heard that one could cut a potato in half and then push the internal part of the potato onto the broken end of the bulb and gently unscrew the bulb by twisting the potato... never tried this so I don't know if it will work -- if the internal stem is still intact, I'd use my fingers and try to gently turn it to unscrew the bulb
4) if it has smooth inside wall -- this is probably a bulb with small exterior pins -- the base should be a little more thicker than the screw-in type, so you should be able to push the bulb base in -- a little give in the spring holding it in -- if you feel this give, then turn carefully counterclockwise and it should pop out...
Again, turn off all electrical power to the freezer, Pull the Plug before attempting any repairs... remove all glass and handle with care...
Jul 25, 2008 | Kenmore 14.1 cu. ft. / 399 liter Upright...
Danby 5.5 cu. ft. / 156 liter Chest Freezer Millenium DCF550W Logo
432 people viewed this question
Top Danby Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
charles
Are you a Danby Freezer Expert? Answer questions, earn points and help others
