Question about Carrier XHB123D X/Y Series Heat/Cool Air Conditioner
The thermostat on the wall is blinking Lb what does that mean? And how do we fix it?
  • 8,220 Answers
Low battery. Remove cover replace battery. Sample
Posted on Apr 28, 2010
Unimac front loader washer with the error code OF not sure what it means. This is a stackable unit.
[PDF]Operation/Maintenance for Drying Tumblers - Alliance ...
docs.alliancelaundry.com/tech_pdf/Production/70283501en.pdf
NFPA 54 "National Fuel Gas Code" and Standard ANSI/NFPA 70 "National Electric Code." In Canada ..... NOTE: If display shows an error code, refer to.
E fl error code on industrial uni Mac washer. What's it mean ...
www.fixya.com/support/t20744713-e_fl_error_code_industrial_uni_mac
Oct 15, 2013 - I've had this issue three times. On the first case, I found my external drain hose ( the hose from your washing machine to the drain in your wall) was ...
65 lb Capacity UWN065T4V - UniMac
unimac.com/products/unimac-washer.../high.../65-lb-capacity.aspx
A description for this result is not available because of this site's robots.txt - learn more.
e OP error - YouTube
Dec 15, 2015 | Washing Machines
1 lb 60z what is mean.pls answer me
What's the question?
Since one pound is sixteen ounces, 1 lb 60 oz is 4 lb 12 oz.
Aug 17, 2014 | Cars & Trucks
My Kidde Carbon monoxide beeps every 30 seconds and is showing L6 with a flash of 0? It is brand new. What does this mean?
L6 is actually "Lb", which is a low battery warning. If the 9V battery is missing, or if the battery's power is low, an "Lb" message will display, which blink's alternately with the current CO reading, while chirping. If this happens, you need to replace the battery.
Nov 10, 2012 | Kidde Nighthawk Combo Gas/co Detector
Flashing 4
Reprogram it and then hold down the button that says hold until it goes back to the screen that should fix it the blinking 4 is just saying you are in the 4th programming stage of the day. Mine was blinking on 3 yesterday and when I reprogrammed it it stopped blinking
Jul 03, 2012 | Hunter Fan Company 5/1/1 Programmable...
The clean light on kenmore dishwasher elite keeps blinking and will not stop
That blinking light is trying to tell you that there is something wrong with your dishwasher. Watch that blinking light.... Does it blink 7 times, pauses, and repeats? Or does it blink 3 times (or some other number). The most common problem is 7 blinks which means "water not heating error". This could be caused by a bad heating element, a bad thermal cutoff or thermostat, a bad controller, or a problem with the door latch and/or switches. Usually there is a tech-data sheet located on the other side of the toe-kick panel which will explain the meaning of the varius blink codes, but you might still need to call a technician to fix the problem. Don't forget to put that tech data sheet back so he can find it and use it to fix your dishwasher!
Dec 16, 2011 | Kenmore 24 in. 17482 / 17484 / 17489...
I have a craftsman garage door opener that wont work and the main opener in the garage keeps blinking how can i fix this?
If by "main opener" you mean the wall control is blinking, press and hold the lock button for 3 seconds.
Oct 18, 2010 | Sears Craftsman LiftMaster Chamberlain...
Thermostat is reading FR Return what does this mean? It is a honeywell CT 3200.
My new blanket works great. Then I changed my sheets and would get the F2 problem. Very consistent after 5 tries with F2 blinking by unplugging at wall outlet and comes on with F2 blinking. Let it rest a night and still the same.
Then I unplug it at the blanket. Hmm, notice a pin was lower than the others. PUSH BACK IN FIRM and tried again. Perfect.
Apr 03, 2010 | Honeywell CT3200 5-2 Day Electronic...
My totaline thermostat is blinking ''L6'' Furnace is operating ok, filter is clean. I can't figure out how to reset it and don't have a manuel.
Well..I just recently noticed this problem on mine and cant seem to find anyone to help me other than to call for furnace service..but the more i look into this ..the more i wonder if the code is L6 or Lb for low battery.
Jan 27, 2010 | Heating & Cooling
I have a direct vent wall heater that I switched from a larger lp tank to a double 100 lb cylander tank, now the pilot will light but when I turn the thermostat up the heater won't start.
If you can jump out the thermostat connections on the gas valve and the heater still does not turn on, check to make sure the thermopile is well into the pilot and getting hot. If it is, replace it. That is the safety for the main burner.It will have two wires wrapped with metal and note which terminals it is connected to on the gas valve.
Nov 18, 2009 | Empire Heating & Cooling
Blinking re co on thermostat
It means that you are going into from one program to another program.
Jul 15, 2009 | Hunter Fan Company 5/1/1 Programmable...
Carrier XHB123D X/Y Series Heat/Cool Air Conditioner Logo
735 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
