Question about HP Photosmart C4480 All-In-One InkJet Printer
Power button flashes and display says shutting down but it won't turn off and is unresponsive to pressing the power button. This happened after I tried to copy something but it froze halfway through the copying process.
    Scholar:
  • 118 Answers
turn on/off, unplug, plug in, should reset configs.
take all the paper out, put half as much back in.
check the rollers to make sure no paper or particles are stuck .
go to applications folder for your computer, dbl click printer icon for make of printer. check settings. print 'test document and clean cartridge heads', this should ensure proper printing formats.
lastly, go to web site of printer model and check site for trouble shooting if this does not work above. HP has an awesome website for trouble shooting problems
hope this helps and good luck
Posted on Apr 29, 2010
Why wont my computer turn on macbook air. what do you think?
could be a number of things including the power block faulty, a break in the power lead, the power regulator in the macbook or even it's just plain old dead. if the macbook lights come on when it's plugged in and nothing else happens when you press the power button, odds on it's just dead.
Jan 30, 2015 | Apple MacBook 13"White /2.0Ghz Intel Core2...
RC-3910 Toshiba television won't turn on, has flashing standby light?
Missing power supply rails from the main power regulator board to sub boards is the fault. Contact any experienced service technician to get this set repaired, since the work is skilled one.
Jul 11, 2012 | Toshiba Televison & Video
My phone won't start, when you press the power button it tries starting then when it gets to the windows phone screen it restarts. Please help.
PLease do a hard reset ... Here is how you do it .
1. Turn the phone off. If it's frozen or unresponsive, pull then replace the battery.
2. Press and hold the Volume Up and Volume Down buttons and power the phone back on.
3. Press Vol down for reset .
Thumps up if this works ..:-)
Aug 09, 2011 | HTC HD7 Cell Phone
We have a new Acer Aspire one and the mouse is frozen. When I try to turn off the unit nothing happens. How do I free the unit or turn off everything?
As this was posted a month ago, I'm presuming you've solved the problem?
However, when your laptop locks up completely, the mouse won't move and the keyboard is unresponsive (press the caps lock key and see if the caps lock LED comes on or off?)
Press and HOLD the power button for a few seconds until the laptop powers off, Wait a few seconds and then power it on again, the computer may moan that it wasn't shut down correctly, but this is normal (because you couldn't shut down correctly)
Jan 15, 2011 | Acer Aspire One A150-1006 Notebook
Hello, I have a prob with my Sony HCD-RV999D I just bought it from a friend, I plug the outlet everything is normal, I press the power button, the system turns on normally, but after 3 second it turns...
The reason this happens is because it takes about 3 to 5 sec. for the output circuit relay to kick in after power up, im sure at this point is when your receiver shuts off and flashes red. You have a bad output Transister its shorted to ground and the sony's protection circuit kicks in and shuts it down. Unless you are a electronic Tech. you will have to take it in to be repaired its going to be about 120 dollars to repair. Now im assuming your speakers are ok, if you have them hooked up when you do this try disconnecting them and try to power up if it does you have a shorted speaker, but normally Sony just displays overload protection on the display. Im sure you have a shorted Trans. sorry for the bad news good luck.
May 18, 2010 | Sony Audio Players & Recorders
How do I restart a Brother 210C 3 in one
Hold down the power button for about 3 seconds and it will shut down. Press the power button again and it will restart. You can also unplug it and plug it back in and press the power button if it is unresponsive.
Nov 13, 2009 | Brother MFC 210C All-In-One InkJet Printer
Presario v2000 stuck in hibernation, can't power it up
remove battery plug in power...see what happens ...nothing happens press and hold power button until you hear response(shut down)press power as usual to boot.if it doesnt work first time try a few times more remember to keep power button pressed to shut down.
Oct 19, 2008 | Compaq Presario R3000 Notebook
How to turn off burn-in mode if botton on Monitor
I didn't have the monitor connected to the computer, and that's why the power button was unresponsive. After connecting it, the solution above worked for me.(My KVM switch was set to a computer that was turned off)
Oct 07, 2008 | Sceptre DCL9a
Power button failure
  • Power Light Shuts Off
    If the power shuts off during game play (even as much as 30 minutes after the system is turned on), then turns off and won't turn back on or the fan isn't working, the system needs repair.
  • Power Light Flashes
    If the power light flashes once when power button is pressed, then turns off and won't turn back on, the system needs repair
  • Sep 11, 2008 | Nintendo GameCube Console
    HP Photosmart C4480 All-In-One InkJet Printer Logo
    139 people viewed this question
    Ben Johnson
    mukhtar21 shaikh
    mukhtar21 shaikh
