Question about MTX Thunder 81000D Car Audio Amplifier
MTX Thunder series 7402 Amp cutting out at Hard pound.
Pounds Great when volume is down on low, will pound even on loud for varies times then cuts out. Running Amp on Jl Audio W6's . Tried Bridged and Regular. Also running a Cap on Amp. Same problem. Not sure what Ohm's we are running. Would like to run at which ever is best for speakers and Amp. Just let me know how to run them please. Radio is a Sony Xplode 52w x4 .
Most likely the ohm load is too low, if you have the subs wired in parallel rewire them in series and see if that resolves the problem. if not then you do not have enough battery power to support the draw that the amplifier pulls. if the vehicles voltage drops below 11.5 volts the amplifier will momentarily shut off, similar to how the lights in your house dim when the a/c cuts on due to the sudden power draw. hope this helps. p.s. if you cant afford another battery right away, lowering the crossover frequency to around 65hz will greatly reduce the amount of current necessary to keep the amp pumping. (in my opinion it sound better that way anyhow.)
Posted on Sep 06, 2010
I got a mtx ta7801 amp every time I hook it up it says short even when no rca our speaker wires are attached any one have any clue as to whath is wrong
Im sure you have but check all the fuses and be sure ground/power is in the right spot, and check remote wire for cuts
Dec 17, 2010 | MTX Thunder TA7801 Car Audio Amplifier
I have a MTX 4105D amp and it cuts in and out what could it be
could be not enough voltage or the settings on the amp are not correct for the sub you have its a feature that MTX put on thier new amps
Aug 04, 2010 | MTX Thunder 4250D Car Audio Amplifier
I have hooked up my subwoofer and amp to my factory stereo in a 2011 camry. My power wire is hooked directly up to my battery, my ground to the chassis and my remote to my fuse. I have my RCA wires (RCA on...
Rewire your stereo cables as such:
Red- positive - battery
Black - ground - chassis
Remote (Yellow) - ignition switch
The "LINE OUT" should go to your SUB-WOOFER.
The while-lined wires paired with the solid colored wires are either your Front LR and/or Rear L/R.
Jun 14, 2010 | MTX Thunder 4500 T4510-04 Car Subwoofer
2 MTX Thunder Problem.. Bridging?
Is there a option on the chanels that say ''Bridged''? If so, you can hook the subs up in parellel or series to get different ohm loads. Usually the lower ohms, the more power amp puts out. Those subs can handle 225 watts RMS whitch means the power it can handle constantly. If the amp gives more than 225 watts RMs, you could be at risk of blowing the sub. If you could give me the model # of the amp, I can be of more help.
Feb 11, 2010 | MTX Thunder 4500 T4510-04 Car Subwoofer
Power issue
blown fuse?speakers on their way out? check the amp fuses, then the inline power fuse.
Feb 07, 2010 | MTX Thunder 81000D Car Audio Amplifier
I have a mtx thunder 421d. I've had it about 5 years,about a week ago it started going out from time to time. I checked my hot wire and fuses,they are ok.Now the amp stop working, and dont light up. Will...
If you have proof of purchase(invoice or receipt) showing the purchase date and you are still within the warranty period then yes it would be repaired by MTX under the warranty guidlines, and by the way MTX is great at customer service and they are great to work with(very fair)!!!!
Keep in mind that the seal on the bottom of the amp cannot be broken or that will void warranty coverage.
Give them a call, you will be glad you did!
800 225 5689 - MTX Customer Service & Amplifier Service Center
Good luck !
Jan 31, 2010 | MTX Thunder 421D Car Audio Amplifier
I have 4 MTX 10s and a JL 1400D amp and it cuts off if i turn it up to bang it what do i do
How do you have the subs wired and what impedance are they? Your amp is only stable to 2ohms. If they are 4ohm drivers, 2 have to be series & 2 have to be parallel. If their 8ohm drivers, parallel is fine. If your not sure, add a comment to this post with the model numbers on your subs and I will get you the correct info needed to do it right.
Jul 10, 2009 | MTX Thunder 4500 T4510-04 Car Subwoofer
Low output from T8302 MTX Thunder AMP
It sounds like an Ic is to blame, Check individual channels to find which one is not working?
Jun 11, 2009 | MTX Thunder 8302 Car Audio Amplifier
My subwoofer doesnt work
you mean that the SUBWOOFERS connected to the amp cuts off and come back on randomly?? did you bring the SUBS level to a high volume ? i suggest to check first the value of the speaker (ex. 4 , 8 , 16 ohms ) matches the same value with the amp . second , hows the subs connected , in series ? or parallel . you will need a multimeter for this task .
Apr 22, 2008 | MTX Thunder 8000 T8154A Car Subwoofer
MTX Thunder 81000D Car Audio Amplifier Logo
187 people viewed this question
Top MTX Car Audio & Video Experts
Professor_V
Professor_V
Matthew Spark
Matthew Spark
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
