Question about E-Machines eMachines Monitor E15T4
Change from a monitor to a flatscreen
I have a dell monitor and would like to replace it with a flat screen that is a machine.Every time I do it it reads Freqency Out Of Range.
  • 11,361 Answers
You need hook up your old monitor back and set the PC video resolution to 1024 × 768 @ 60Hz which is the native/max resolution of the E15T4, remove the old Dell monitor and connect your E15T4.
You are getting out of range because your PC video resolution is too high for the E15T4 to display.
Posted on Apr 29, 2010
What flatscreen monitor is OK to substitute for sanpo alphascan 520?
Hi. Almost all the crt type monitors should work, it's flat screen monitors that seem to give computers problems with aspect ratios, and resolution settings.
I personally use an NEC AccuSync 70.
It might not be the newest monitor in the world, but the colors are crisp, clear, and bright.
And It allows a setting of 1024x768@85 hz refresh rate, which works great for my games.
As far as flat screens, I would probably go with an Acer, or a Dell monitor, as these two companies seem to have better quality from their monitors than most other manufacturers.
I hope this helps you out!
Mar 06, 2011 | Sampo AlphaScan 520 (White) 15 in.CRT...
I have a wide screen Dell 21'' flatscreen lcd monitor....all my screens are stretched and photos do not look right.
change the resolution from the desktop properties(right click on desktop ..choose properties than settings ...in there you will find resolution ...setting ..change them one by one untill you get to one that fits...probably will be the last one in the right ..the largest if it is a wide screen on 21 inch ..
Jun 27, 2010 | Dell P1110 21" CRT Monitor
HPW2338h goes black after about 3 seconds. Push power button on, it turns on and then black after 3 seconds. Power light on monitor stays on.
hi,
you can try to change the screen resolution with a spare monitor to a different setting, usually higher 1024X768, then unplug the old monitor and then plug in the flat screen. try different resolutions untill it submits. if you cant get it to run on your machine, take it to another computer and see if you can get it to run on that. if it wont run on either then you have a problem with the monitor. pawn shops usually have flatscreens for way cheaper than new..
jm
Dec 15, 2009 | HP w19 19" LCD Monitor
What could cause a dell flatscreen monitor to go
Probably a bad power supply in the monitor. One of these days it will go black and stay that way.
Dec 08, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
Dell LCD TV won't turn on
check the cable who comes from the cpu
May 07, 2009 | Dell E173FP 17" LCD Flat Panel Monitor
I am trying to hook my 40 inch flat screen by samsung to my dell computer. i unplugged the cpu monitor and plugged it to my tv and the tv states that the mode is unsupported. What do i do?
Your computer is set to a resolution supported by your dell monitor but not the flat screen tv.
The easiest way to get it working is to turn the computer off, connect the flat panel to the computer and then turn the computer on.
To change the resolution of the flat-panel or monitor, right-click on the desktop, click on properties and then select the settings tab.
play with the screen resolution and find one that works best by trying each one and clicking apply. If you select a resolution not supported by your flat panel, computer will automatically revert to the previous resolution in 15 secs.
Feb 26, 2008 | Televison & Video
MAG monitor is all white
please change your ram immeditately or monitor itself because the life of monitor has been came to an end...
Dec 31, 2007 | Mag Innovision InnoVision LT765 17" Flat...
How to my flat screen monitor
This is a duplicate post, click the following link to see the active post: http://www.fixya.com/support/t136495-fix_flat_screen_monitor
Mar 06, 2007 | Dell E153FP 15" LCD Monitor
Dell 1702FP 'tearing' after warmup
It might be a failing electrlytic or a heat-related issue with a transistor in the power supply, or it may be a problem in the video board. Sounds like will need good old-fashioned component-level troubleshooting.
Jan 02, 2007 | Dell UltraSharp 1702FP 17" Flat Panel LCD...
E-Machines eMachines Monitor E15T4 Logo
99 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
