Question about Sansui CDVD9000
I can't program channels into my tv/dvd player
9'' sansui tv/dvd-how do I program channels into tv. can only get basic channels. when I try, it doesn't work
SOURCE: Programming remote for Zenith DVB412 DVD Player
Hi there!
I have the exact same problem...am wanting to program this same remote to control the TV.
There are no instructions in the manuel...however, in my hours of searching for information on "how to," I did discover that this LG manufactured remote is a "universal" remote.  Unfortunately, the Owners manual fails to address the TV Control feature.
This same remote was manufactured for Zenith's Allegro ABV441 and ABV511 DVD/VCR, Goldstar GBV-441, LG VC8410MS and VG8610MK, and as  Zenith Remote 6711R1P070H.  I've check the manufacturer's web sites and there is virtually no information on this remote.
I did come accross Zenith's Customer Support #, (888) 865-3026.
Hope this helps!
Posted on Oct 17, 2007
Pookeybrain
  • 51 Answers
SOURCE: 1999 sansui tvm1915 tv
You'll most likely need a Sansui remote made to work with your specific model TV. I have similar problems with my Toshiba TV. Check eBay.
Posted on Nov 10, 2007
  • 7 Answers
SOURCE: new dvd/vhs player but old tv
The easiest thing to do would be get a new TV plain and simple sounds as if you could use one n e ways. But first make sure you are hooked up through coaxal to the tv that will allow everything to run on channel 3. Let me know your current hookup.
Posted on Dec 25, 2007
SOURCE: dvd player does not work
Sell it to someone on ebay.
Just kidding, it's the guy who bought it.
now I am trying to sell it.
It works in the car with a cheap adapter.
Mike
Posted on Feb 05, 2008
SOURCE: Sansui SAN1880 80g dvd recorder no colour
Hi, I have a Sansui Model San1880, after I have manually program the TV channels, I don't get no sound at all only on the TV channels its got good pictures but no sound, would you please tell me what to do.
Thanks
Rod
Posted on Sep 12, 2008
I have a sansui flat with build in DVD but don't have a remote the DVD will load but when push play it says operation not possible with disk what is this do I just need a univ.remote
First, check which input you have the TV set on. There may be an Input button on the side of the TV. (On the SLEDVD197, the button just below the DVD Eject button.) Just press Input and use the Channel Up/Down arrows to navigate the menu to change to the DVD. Press Input again to Enter the selected option.
With the TV in DVD mode, try pressing Play again. If you still have the error, check the region code for the disc. The "Operation not permitted" messages is usually that something on the disc is locked. Frequently, it's the result of using a different region code disc than the DVD player knows how to interpret. Try a different DVD.
If your TV doesn't have the Input button on the TV, you absolutely need a universal remote. However, you will want one that can match the TV/DVD button, the Input/Select button and the Menu button. Usually this requires a higher end remote; you also need a remote that was programmed at least 6 months after Sansui released the TV. If you do have the Input button on the TV, a universal remote may make using the TV easier.
I hope this helps.
Apr 13, 2015 | Sansui Televison & Video
Instructions on how to program
Hi
Configuring codes:
1.Turn on a desired device (VCR or DVD player)
2. On the remote control, press a device key once (i.e., DVD/VCR,
CBL/SAT or TV).
NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo, or TV/VCR/DVD Player Combo press DVD/VCR once. After programming a VCR Combo device, you will be able to control channel selection,volume, and VCR functions.
To program control of a DVD Player,DVD Player/VCR
Combo, or TV/DVD Player Combo, press DVD/VCR once. After programming a DVD Combo device, you will be able to control channel selection, volume, and DVD functions.
To program control of a Cable Box, Cable Box/PVR (or DVR)
Combo, Satellite Receiver, or a Satellite Receiver/PVR (or DVR)
Combo, press CBL/SAT once.
3. Press and hold SET until the LED (red light) blinks twice,
then release SET.
4. Use the Manufacturer's Codes to locate the type of device and brand name and then enter the first four-digit code for your device. If performed correctly,
the LED will blink twice.
5. Aim the remote control at the device and press POWER once. The device should turn off. If it does not, repeat steps 2 to 5, trying each code for your brand until you find one that works. If it still doesn't work, try Searching For Your Code on next page
Auto Code Scan:
1.On the remote control, press TV once.
2. Press and hold SET until the LED (red light) blinks twice, then release SET.
3. Enter 9 - 9 - 1.The LED will blink twice.
4. Aim the remote control at the TV and slowly press POWER button.Stop when the TV turns off
5. To lock in the code, press and release SET.The LED will
blink twice.
6. To search for the codes of your other devices, repeat steps
1 to 5, but substitute the appropriate device key for the device you are searching for.
Thank You
Sep 18, 2010 | One For All URC4220 Remote Control
Im trying to program a remote the tv is a zenith
Configuring codes:
CBL/SAT or TV).
then release SET.
4. Use the Manufacturer’s Codes to locate the type of device and brand name and then enter the first four-digit code for your device. If performed correctly,
5. Aim the remote control at the device and press POWER once. The device should turn off. If it does not, repeat steps 2 to 5, trying each code for your brand until you find one that works. If it still doesn’t work, try Searching For Your Code on next page
Auto Code Scan:
blink twice.
Thanx
Aug 06, 2010 | One For All URC4110 Remote Control
I need a remote for a Sansui CDVD9000s 9"TV/DVD Combo
Try an ELECTROHOME universal remote this is the only one that worked, not RCA and I heard not phillips or sony either
May 18, 2010 | Sansui CDVD9000
Connections Information Requested
Yellow - Video cable
Red - Audio right channel
White - Audio left channel
From DVD to TV
DVD is output
TV is input
Hope this helps.
Jan 18, 2010 | Sansui VRDVD4000 DVD Player/VCR
How to program vcr to record digital channels?
Any VCR select to input source from where recording.
So select appropiate Euroscart or other AV connection.
Digital channel will be your digital cable set top box or sat receiver, DVD player, whatever. Very unlikely you use a digital capable set topbox to output to your VCR or TV with old fashioned RF coax cable where you have to tun in to cerain RF frequency under Channel 0 or so. So when in timer menu select that input source connection. Direct recording without timer select the source with remote. This solution applies to all brands
May 02, 2009 | Sansui VRDVD5000 DVD Recorder/VCR
I have a 2003 Sansui VRDVD4005 recorder. It currently playsback on channel 4 on my TV and I need to reset it so it plays back on channel 3. Do you know how I can make the change? All suggestions on the...
Turn off the unit. press and hold the "3" button on the remote until you see "rf 3" in the display on the VRDVD4005. This will change the output channel to 3.
Feb 18, 2009 | Sansui VRDVD4005 DVD Player/VCR
Sansui San0218-250GB
You need 2 antenna cables. wall socket ----> DVD antenna in and DVD antenna out ----> TV
Mar 07, 2008 | Sansui VRDVD5000 DVD Recorder/VCR
Thanks
Rod
Mar 01, 2008 | Sansui VRDVD5000 DVD Recorder/VCR
Sansui CDVD9000 Logo
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
