Question about Maytag Neptune MDE6700A Electric Dryer
Our drier is making a clunking noise, and the barrel has developed a small crack at the front.
  • 438 Answers
Your door seal, front drum bushing needs to be replaced it is a felt type soft unit that is installed directly at the front of the drum just behind the front cover
Posted on Apr 28, 2010
Why is there strut and axle noise in rear?
2005 TrailBlazer Clacking and Clunking From Rear End ...
? 4:10
https://www.youtube.com/watch?v=HIA151KxImM
Mar 14, 2013 - Uploaded by sameasiteverwas122
2005 TrailBlazer Clacking and Clunking From Rear End ...Trailblazer clunking noise over bumps (the number 1 and 2 ... How To Find Suspension Noises 101 - EricTheCarGuy - Duration: 23:57. by EricTheCarGuy 1,497,067 views ... How to Install a Water Pump: 2002 - 2009 Chevrolet Trailblazer 4.2L L6 ...
Trailblazer Driveline Noises Discovered - YouTube
? 2:27
https://www.youtube.com/watch?v=GLhTUoHWdNM
Nov 4, 2013 - Uploaded by Roland Caston
the Trailblazer has developed some nasty noises. ... loose in thedifferential and the right front strut has torn through it's bushing.... How To Install Replace Front Axle Disconnect Housing 2002-09 GMC Envoy Chevy Trailblazer ... How Much Abuse Can a Trailblazer Take Part 2 : How to Replace a Rear Axle ...
Noise coming from back on trailblazer - YouTube
Jan 01, 2016 | 2002 Chevrolet TrailBlazer
Why is my Fisher and Paykel dryer making a clunking sound as it spins?
UNPLUG YOUR MACHINE FROM YOUR ELECTRICAL SOCKET AND OPEN THE DOOR , PUT A TOWEL DOWN AT THE FRONT OF THE MACHINE,GET DOWN ON YOUR KNEES AND GRIP ONE HAND AT THE TOP OF THE INTERNAL BARREL AND GRIP THE INTERNAL BARREL AT THE BOTTOM TO SEE IF THERE IS ANY 'PLAY' IN THE BARREL BEARINGS, REPEAT THE SAME ON EACH SIDE OF THE BARREL, IF THERE IS SIGNIFICANT MOVEMENT IT COULD MEAN THE BEARINGS ARE LOOSE. IF THERE IS NO 'PLAY' IN THE BEARINGS, REMOVE THE COVER PANEL ON THE LOWER FRONT PART OF THE WASHING MACHINE AND PUSH THE LID INWARDS AND UNSCREW THE LID ANTICLOCKWISE TO THE PUMP DRAIN. A LITTLE WATER MAY TRICKLE OUT BUT THIS IS NORMAL , BUT ALSO YOU MAY FIND SMALL ITEMS LIKE PAPER CLIPS, SMALL COINS OR BUTTONS ONE OF WHICH WILL TURN OUT TO BE THE CULPRIT WHICH HAS CAUSED THE DRUM TO 'CLUNK' WHILSTI N MOTION. 99% IT NORMALLY IS EITHER THE BEARINGS OR ONE OF THE OTHER ITEMS AS MENTIONED.GOOD LUCK!
Oct 16, 2014 | Fisher and Paykel Dryers
Subframe bushings symptoms
Micpherson strut or independent front. If its the MacPherson strut design of the car on your picture, then clunks on rough pot holed roads or rough dirt. Al's a weird one is a clunk may or may not be heard and /or felt upon first application of breaks. Sometimes noticeable that car travels straight then when brakes applied it suddenly pulls to right or left. If accompanied with a brake squeak then Its a wheel bearing. On independent front suspension all previous symptoms plus one. A ticking sound that is repetative or described as a clicking noise, very faint though. Usually only heard with windows rolled down and driving 20 to 30 mph with a concrete wall next to lane, which echo's the noise to driver but not when in open country, could also be symptoms of control arm bushings. Sway bar bushings only make noise on rough roads. Cabin bushings and all others can usually be visabily checked. If no cracks then its good if small hair line cracks, keep an eye on it, if large cracks and possibly with pieces missing, replace . if its a Chevy replace control arm bushing adjuster bolts. They get grooves wore in them defeating the reason your replacing the bushings as it will still have play, make noise. Etxc. Oh the other symptom is when road tilts to the right side being lower then left then vehicle pulls to right. But if road sloped the other way then pulls that way and usually no pull either way on level ground.. Some pull is natural but too much is bad. Hope it helps. What noise and when does it do it? Where and what are you doing as well as how fast and I could help narrow your possible problems.
May 15, 2014 | 1997 Acura CL
Symptoms of a bad cv joint
x10 , lug bolts,
or even cracked rims
or even bad wheel bearings
or even brake rotor bad. warped.
doing a hands on full inspection (man handling parts)
is the only way, guessing on the net is zero solution.
I can list maybe 25 ways to make noise. on car.
why do that.?
Mar 24, 2014 | 1996 Geo Metro
How do you check for cv joints on 2001chyr toun n country
cv joints make noise when bad when turning check the sway bar bushings
Apr 26, 2012 | 1999 Chrysler Town & Country
1966 mustang coupe motor 289,4 barrel carb.automatic trans. makes a noise when put in reverse,is this normal?
What kind of noise? A clunk, chatter, whir, grinding, or what? If it's a clunk, you may have a worn U-joint. Test by holding brake on and change between drive and reverse and back. If you hear a "clunk" when the tranny engages, it's probably a worn U-joint. Not a hard repair to do in the driveway. Always change BOTH front and rear U-joints - if one's worn, so's the other.
Oct 28, 2009 | 1966 Ford Mustang
LG DRYER MAKING CLUNKING NOISE
Look inside the drum at the seam, front and back side. The weld on the stainless steel drum may have cracked. You would need to replace part number 3045EL1002F. It is moderatly difficult to replace.
Oct 16, 2008 | LG DLE5977 Electric Dryer
Clunking during spin
see if the shocks are not broken. if you spin the wash basket by hand and hear a grinding noise, then your bearing would most likely be bad
Dec 17, 2007 | Frigidaire GLTR1670A Front Load Washer
Maytag Neptune MDE6700A Electric Dryer Logo
124 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
