Question about Toshiba Satellite Pro A200-EZ2204X Notebook
DVD door keeps opening
How can I stop the DVD door from coming opening all the time, its so annoying. When I shut it closed, it just pops open again
    Sergeant:
    Champion:
  • 305 Answers
Sometimes they need to be pushed that little bit further in and make sure the eject button or open button is not stuck in .
hope this helps.
Posted on Apr 28, 2010
My Craftsman garage door will not close, only a few inches at a time
have a problem which returns every year when outdoor temperatures drop close to freezing. garage door will open only a few inches, then stops. I can close it and try opening it again... same result. After five or six such attempts it typically will open. Interestingly, when I push the switch button mounted on the interior wall of my garage and keep it pushed, the door will open, until I release the button at which point it stops opening.
Dec 19, 2013 | Building Materials
Magnavox ZC320MW8 door stays open
f the tray won't open or close properly, check the belt for dirt or wear. Then check the tray for misalignment. If needed, remove, clean, lubricate, and reinstall the tray following the instructions in the owner's manual.
God bless you
Sep 27, 2012 | Magnavox ZC320MW8 DVD Recorder Refurbished
Jaguar S-type --- drivers door open idicator will not shut off
the switch should be by the bottom of the door or near the hinge it gets depressed when the door is closed and it pops out when the door is opened some times it gets dirty and wont function correctly fairly easy to change on most cars also same location on most cars.
Dec 01, 2009 | Jaguar S-Type Cars & Trucks
Freezer door closing problem
to keep freezer door from popping open close main door more gently try extending front legs a little to help the door swing shut
Aug 04, 2009 | Refrigerators
Our Rodeo 2000 model has a problem with the two front doors..
it may be the metal in the door opening is cracking or on the door itself, may be the prob
May 12, 2009 | 2000 Isuzu Rodeo
Freezer door won't stay shut
This indicates that you do not have good airflow and return airflow between your freezer and refrigerator sections. That is why the pressure from closing one door is causing the other one to pop open.
Check the drain tube on the back of the machine to make sure it is not clogged or blocked with frozen water inside. Also check any return air flow vents inside the unit for clear ice.
Jan 18, 2009 | Refrigerators
Freezer Door Popping Open
Look at the bottom of the freezer door, there is a little plastic stopper there. It may be worn out or broken. When you close the door this is what holds it there. Start there first.
Sgt 48
Jun 17, 2008 | LG LRSC-26922 Side by Side Refrigerator
Keeps opening
may have a microswitch that signals that the door is closed that may be faulty. look for a switch that is actuated when the door closes.
Nov 06, 2007 | Emerson EWR20V4 DVD Recorder/VCR
Door won't close
Had this problem and all i did is pushed the eject button while it was open and it made some noise like it was ejecting and then after that i could shut it again. Hope this helped.
Jan 27, 2007 | Panasonic NV-DS60 Mini DV Digital...
DVD loader mechanism
It is called the slider assy. The slider moves the laser assy back to home or start position. It is a small belt underneath or there is gunk or hair in the gear mechanism. A very common problem with CD/DVD players/recorders. Very good though that you saw it was not comming back to home place. I wish I had a manual to assist you but I do not. Im telling you the most common problems with the slider mechanism. Good Lck
Oct 08, 2006 | Sanyo DVW-6000 DVD Player/VCR
Toshiba Satellite Pro A200-EZ2204X Notebook Logo
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
