Question about Husqvarna 26 Hp 54" Deck Zero Turn Riding Mower
I have a husqvarna Yth2454 riding mower and it keeps stalling after a few minutes as if there is a carburator problem or it is overheating. Any idea what may be causing this or what I can do to fix it. The gas is fresh and the oil and air filters have been replaced.
4 Suggested Answers
panilling9
  • 284 Answers
SOURCE: what kind of oil for a husqvarna riding mower?
Yes Briggs and Stratton recommends sae 30 in most all their engines even overhead valve (OHV)
Kohler uses 10w-30 in most of their overhead valve engines
Briggs has their own bottled oil with their label and additives and can find at lowes
Kohler the same
Posted on Jun 14, 2009
ginko
  • 19396 Answers
SOURCE: Husqvarna riding mower w/20 hp
Hi.
There is gas smell in the carburetor because the engine is not starting and carburetor is flooding.
As first thing ensure that there is spark, pull the spark plug wire and put the end near to engine block while cranking. You will see the spark. If there is no spark, check distribution coil and wires.
If there is spark, check if there is fuel pressure, if there is smell from carb, then the fuel pressure should be Ok.
Once you are sure that the pump is doing its job, and that there is pressure, check the carburetor settings. The mixture is probably too rich or too lean, and for that reason it is not igniting.
If it is not a matter of carburetor settings, then the carb must be taken apart to check carburetor filter.
To get parts and diagrams see: Outdoor Distributors - Lawn Mower Parts
Posted on Sep 26, 2010
MOTORWIZJ
  • 1363 Answers
SOURCE: How to remove the oil
FROM THE TOP OF THE FILTER(THE SIDE THAT DOESN'T HAVE THE TREADS IN IT), IT'S ON TO THE RIGHT OFF TO THE LEFT, YOU CAN USE A RAG AND WRAP IT AROUND THE FILTER TO GIVE YOU MORE LEVERAGE , KEEP STEADY PRESSURE ON IT, AND SWAY WITH YOUR BODY , I FIND IT HELPS GIVE THAT LITTLE EXTRA TORQUE NEED TO GET THE STUBBORN ONES LOOSE.. JAY
Posted on Jun 04, 2011
New husqvarna riding mower burns my foot when i press the gas petal
do you have a leak on the exhaust letting exhaust out in the wrong place?
Aug 09, 2012 | Husqvarna YTH2454 54in 25 HP Lawn Tractor
White smoke is coming out of exhaust of husqvarna yth2454
smell the oil and if it smells like gas you have a bad seal on the needle valve in the carb and gas overflows into the crankcase change the needle and seat change the oil and if possible add a fuel shut of valve and close it when not in use
Jun 24, 2012 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
My 2 year old Husqvarna riding mower, with the welded steel deck, has the mulch kit installed ( I installed it). When cutting, the mower ususally leaves a thin line of uncut grass. More, when the grass...
I too have had that same problem. I found that "old" blades when repeatidly sharpened and worn will cause the same problem, also aftermarket blades instead of original manufactures recommended blades may not be dimensionally correct, too short. I have had to go back to using original blades to correct the problem.
This should work for you.
Good luck.
Sep 06, 2011 | Husqvarna Lawn Tractor  25 HP 54in Deck...
The mower has spark and good gas flow to the carb but will not start it cranks over good and has a new battery
Sounds to me like you have water in your carburator bowl , or your needle valve is stuck in it's seat. Shut off your fuel tank to carburator, remove the carburator bowl with container underneath, careful of the gasket, and see what comes out. If needle is stuck up into carburator gently pull down.
Also check the container for water. This could be one, or both of your problems. Clean parts , replace , and it might be a good idea to drain your fuel tank you may have some water in there. Start with fresh gas. GOOD LUCK.
Jul 26, 2011 | Husqvarna YTH2454 54in 25 HP Lawn Tractor
I have a yth2454 and the oil light stays on. the machine is full of oil.
the sending unit is clogged, take off and try clearing, then reinstall and should be fine. Tim
May 23, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
Husqvarna 26 Hp 54" Deck Zero Turn Riding Mower Logo
191 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
