Question about Toshiba 42H81 42" Rear Projection Television
42H81 dark screen
Hi my toshiba 42H81 screen has gone dark.i have set the brightness to 100% and its still only around 30% bright. wot could this be?
thank you
  • 61 Answers
Try to adjust the sharpnes
Posted on Apr 08, 2008
  • Francisco Punzalan May 01, 2008
    did you see the small thing that look like a small stick, try to pull it softly, i have already expirienced tha before on my laptop,
SOURCE:
Monitor is set to 100%--still too dull
If the picture is dark, on screen brightness will not overcome this.
Apr 01, 2014 | IBM E74 Monitor
I had to adjust the brightness to 100% and you can still barely see it and it has a blue tint
This TV is CRT driven and when the brightness is a issue you would need to diagnose the Blue CRT and or the Fly back transformer.
Many times the transformer is not providing enough power to that CRT witch can cause this to happen.
Without the TV in front of me it would be difficult to pin point.
Also you would want to consider if the TV is out of Focus thus causing this blue tint, Here is a on line part store that can help you in purchasing the parts for the tv if your interested in Do It Yourself repair.
http://www.partstore.com/Model/Toshiba/Toshiba/42H81.aspx?p=4&z=50&c=3b663bdcbb0b5634f5cc800d37496d25&bs=Category&bd=Asc&ms=Category&md=Asc&k=#1
First if the TV is not illuminating with the brightness function you would consider at this point the TUBE "CRT" or the Fly back witch drives them.
Thanks for your questions
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Dec 13, 2010 | Toshiba 42H81 42" Rear Projection...
Toshiba 35A44 Screen dark despite max brightness setting some OK
could be the sharpness, color, brightness, or a combination of them
May 05, 2009 | Toshiba 35A44 35" TV
TV screen became a lot darker than normal.
Hi.
yeah, opened the front flap of the TV>menu> brightness> increase. Sorted. No problem.
ain't gonna bother asking any more questions on this forum..........no help at all .
cheers, Pat
Mar 30, 2009 | Toshiba Televison & Video
Real dark screen on Toshiba A135-s4437
First I would check to make sure that the contrast/brightness buttons on the laptop weren't accidentally changed, making the screen dark. Also, try with and without the battery and power supply. Otherwise, unless it is actually the screen that is defective, it is usually a power converter replacement, which is a small circuit board, usually under the plastic cover directly under the monitor, which supplies power to the monitor. You may want to take it to a shop as they can isolate the issue easier.....
Mar 10, 2009 | Toshiba Satellite A135-S4437...
How do I fix contrast and brightness on 36" toshiba tv?
you can bring more brightness by removing cover on your tv and then you will see ther 2 button ther in back of your tv one is FoCUs and other is G2 rotate the G2 button till you see more brightness on your screen put the cover back and that is if you dont know to do that go to one authorised service
Dec 10, 2008 | Toshiba 36AF41 36" TV
Screen Brightness gone too low on toshiba satellite 1110 laptop
Hello Tim,
Sorry to answer u by this news :
this problem u have happening by 2 cases ..
1st Case :::: that's maybe ur screen lamps is broken ..so u can see the data but very dark or no Back-light .. so u will need to replace the screen..or advanced option but with expret person to change the lamps from another broken sceen,,
2nd Case ::::: The high-voltage board..it's small board built below the screen to give the screen the right voltage to light on .. so u will need to replace it also ..or Advanced option also but with expert electronic person to check it ..
best luck.
Dec 01, 2008 | Toshiba Satellite 1115-S103 Notebook
LG Flatron E700SH
Hi its not problem it is just setting difference
Try this one
go to menu setting and increase TEMPERATURE to 8300 or between 8300 to 9300
this will help you to solve your problem
thanks and regards
Teknas
Aug 17, 2008 | LG Flatron Ez T910BU 19" CRT Monitor
Darks too dark
try to open your tv and you can find the flyback ,in flyback you can see the screen and focus to adjust.use and try to rotate the screen,it control the brightness of your unit
Oct 15, 2007 | Toshiba 32AF43 32" TV
Screen brightness keeps going down.
its because it has gone into power saving mode, you need to go into the power/battery settings and set the brightness at 100% and then choose that setting as default.
Sep 06, 2007 | Toshiba Satellite M30X Notebook
Toshiba 42H81 42" Rear Projection Television Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
