Question about Wurlitzer Jukebox 1015 One More Time 100-Disc CD Changer
Door star lamp on OMT faulty - Wurlitzer Jukebox 1015 One More Time 100-Disc CD Changer
    Scholar:
  • 195 Answers
Have you tried to replace the lamp? A good source of supply is at www.victoryglass.com
If the lamp is ok then trace out the cables that supply the lamp back to the jukebox power supply. It could be a dry joint (cold joint in the USA) on the connection pins on the board. It could also be a problem with the lampholder.
Regards
Alan Hood
ami-man
UK
Posted on May 14, 2010
I need a manual...can you help?
Manuals are here. Real PDF's no charge as in FREE!
1987: One More Time (OMT) Introduction of the reproduction of the 1946-47 1015, but with a "Modern" 100 selection
45RPM record mechanism. (download PDF manual for OMT-45 - 2MB in size) ( OMT-45 Parts Manual ) (PDF of schematic for animated lights for very first OMTs - no bubble tubes!)
1989?: OMT-CD The new CD bubbler introduced! (download late 1990s PDF manual #22 - does not cover early OMT nor the New Orleans or New York, NY models) (OMT-CD Parts Manual #14 - !!errata!! - Pg 12 has the curved bubble tubes miss-numbered), (revised colour cylinders after serial #4003XXXX)
1995?: Elvis model OMT-CD
ALL THESES LINKS AND MUCH MUCH MOIRE INFO AND TROUBLESHOOTING CAN BE FOUND HERE - https://www.flippers.com/wurlitzr.html
You may have to poke around as I have found some manual links are incorrectly labeled.
Aug 05, 2015 | Wurlitzer Jukebox 1015 One More Time...
My Box Was Damaged in shipping, Where can I buy Replacement Plastics and Bubble Tubes.
If you google for "cd jukebox parts" you can find a list of suppliers of all kinds of jukeboxes. You check with a few that work for Wurlitzer and I think you can find what you need.
Mar 16, 2015 | Wurlitzer Jukebox 1015 One More Time...
The screen shows multiple tiny dots. (stars)
Are they sharp and defined, or 'blob'-like? If they are sharp, that would indicate a faulty DLP block (not worth repairing, unless under-warranty.) If they're more 'blob'-like, it's probably just dust in the optical block. That can usually be remedied by removing the lamp, and blowing-out the unit with an air compressor. Canned air won't do the job, as there's not enough pressure.
Apr 26, 2013 | Dell 1410X DLP projector 2700 ANSI...
94 Mercury Cougar 4.6L Int Lamps 10Amp fuse blows
replace the door jamb light button, it's probably bent therefore not pushing in when door is shut, and when door is shut it grounds out, and it wld'nt effect the dome light because it's in the circuit befor the dome if this is the case and you find it's bent or crimped try to bend it back out,
Aug 25, 2012 | 1994 Mercury Cougar
GE Energy Star WCVH6260F Front Load Washer washer wont fill with water and does the error beeping after about a minute and continually says door is locked when it isn't
Sounds like the door sensor has become faulty. Unfortunately this is only a vague symptom,of the actual Root cause Are there any other error codes?.
Mar 14, 2010 | GE Energy Star WCVH6260F Front Load Washer
The drivers side door and passenger side door does not operate the dome light, no other problems.
its likely to be either the lamp is out, the door switches are faulty, or the lamp switch is faulty...most likely the lamp switch as both doors aren't working. Give them a clean or a drop of WD40
Jan 07, 2010 | 2004 Dodge Ram 1500
Im looking for laser for model omt cd 100
You are looking for a CDM12 or CDMPro or CDM Pro2
Mar 20, 2009 | Wurlitzer Jukebox 1015 One More Time...
My RCA is screeching
To install the color wheel, turn off and unplug the tv, take off the lower back casing (17 star type screws), remove the lamp door, remove the lower back casing. Look just left of the lamp you will see 3 smaller star type screws near a small circuit board (which is on the color wheel), remove those screws unplug cable from color wheel, unplug other end of 2nd cable from tv circuit board (just to the upper left nearest to the color wheel.
All you have to do is install the color wheel, plug in both cables, put the back on and place the lamp door back in its position, the lamp door pushes in a lillte blue lever which allows the lamp bulb to light up.
I'm in the process of doing the same myself on my RCA same model. Where did you buy the color wheel from?
rw9704
Jan 06, 2009 | RCA HD50LPW42 50" Rear Projection HDTV
It doesn't Light Up
if the problem is nor related to just one bulb as it sounds like it isnt then most likely you have a fuse blown or a defective lamp or 24v circuit. Check out www.flippers.com as they have the OMT manual in pdf format assuming you dont already have it.
Dec 08, 2007 | Wurlitzer Jukebox 1015 One More Time...
Wurlitzer Jukebox 1015 One More Time 100-Disc CD Changer Logo
Top Wurlitzer Audio Players & Recorders Experts
phil
Donald Chadwick
Donald Chadwick
Level 1 Expert
Are you a Wurlitzer Audio Player and Recorder Expert? Answer questions, earn points and help others
